pi@raspberrypi ~ $ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages have been kept back:
nuscratch
The following packages will be upgraded:
bind9-host isc-dhcp-client isc-dhcp-common libbind9-80 libdns88 libisc84
libisccc80 libisccfg82 liblwres80 libpng12-0 libpng12-dev libsmbclient
libssl1.0.0 libwbclient0 openssh-client openssh-server openssl
python-rpi.gpio python3-rpi.gpio samba-common smbclient ssh sudo
23 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed.
Need to get 13.1 MB of archives.
After this operation, 376 kB disk space will be freed.
Do you want to continue [Y/n]?
Get:1
http://archive.raspberrypi.org/debian/ wheezy/main python-rpi.gpio armhf 0.6.1~wheezy-1 [47.9 kB]
Get:2
http://archive.raspberrypi.org/debian/ wheezy/main python3-rpi.gpio armhf 0.6.1~wheezy-1 [28.1 kB]
Get:3
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libssl1.0.0 armhf 1.0.1e-2+rvt+deb7u19 [1,053 kB]
Get:4
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpng12-dev armhf 1.2.49-1+deb7u2 [260 kB]
Get:5
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpng12-0 armhf 1.2.49-1+deb7u2 [179 kB]
Get:6
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libwbclient0 armhf 2:3.6.6-6+deb7u6 [92.3 kB]
Get:7
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libsmbclient armhf 2:3.6.6-6+deb7u6 [1,263 kB]
Get:8
http://mirrordirector.raspbian.org/raspbian/ wheezy/main smbclient armhf 2:3.6.6-6+deb7u6 [4,518 kB]
Get:9
http://mirrordirector.raspbian.org/raspbian/ wheezy/main ssh all 1:6.0p1-4+deb7u3 [1,242 B]
Get:10
http://mirrordirector.raspbian.org/raspbian/ wheezy/main samba-common all 2:3.6.6-6+deb7u6 [214 kB]
Get:11
http://mirrordirector.raspbian.org/raspbian/ wheezy/main isc-dhcp-client armhf 4.2.2.dfsg.1-5+deb70u8 [743 kB]
Get:12
http://mirrordirector.raspbian.org/raspbian/ wheezy/main isc-dhcp-common armhf 4.2.2.dfsg.1-5+deb70u8 [803 kB]
Get:13
http://mirrordirector.raspbian.org/raspbian/ wheezy/main bind9-host armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u9 [71.9 kB]
Get:14
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libisc84 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u9 [169 kB]
Get:15
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdns88 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u9 [710 kB]
Get:16
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libisccc80 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u9 [33.8 kB]
Get:17
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libisccfg82 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u9 [55.1 kB]
Get:18
http://mirrordirector.raspbian.org/raspbian/ wheezy/main libbind9-80 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u9 [42.1 kB]
Get:19
http://mirrordirector.raspbian.org/raspbian/ wheezy/main liblwres80 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u9 [52.0 kB]
Get:20
http://mirrordirector.raspbian.org/raspbian/ wheezy/main openssh-server armhf 1:6.0p1-4+deb7u3 [315 kB]
Get:21
http://mirrordirector.raspbian.org/raspbian/ wheezy/main openssh-client armhf 1:6.0p1-4+deb7u3 [949 kB]
Get:22
http://mirrordirector.raspbian.org/raspbian/ wheezy/main openssl armhf 1.0.1e-2+rvt+deb7u19 [702 kB]
Get:23
http://mirrordirector.raspbian.org/raspbian/ wheezy/main sudo armhf 1.8.5p2-1+nmu3+deb7u1 [840 kB]
Fetched 13.1 MB in 9s (1,329 kB/s)
Preconfiguring packages ...
(Reading database ... 83026 files and directories currently installed.)
Preparing to replace libssl1.0.0:armhf 1.0.1e-2+rvt+deb7u18 (using .../libssl1.0.0_1.0.1e-2+rvt+deb7u19_armhf.deb) ...
Unpacking replacement libssl1.0.0:armhf ...
Preparing to replace libpng12-dev 1.2.49-1+deb7u1 (using .../libpng12-dev_1.2.49-1+deb7u2_armhf.deb) ...
Unpacking replacement libpng12-dev ...
Preparing to replace libpng12-0:armhf 1.2.49-1+deb7u1 (using .../libpng12-0_1.2.49-1+deb7u2_armhf.deb) ...
Unpacking replacement libpng12-0:armhf ...
Preparing to replace libwbclient0:armhf 2:3.6.6-6+deb7u5 (using .../libwbclient0_2%3a3.6.6-6+deb7u6_armhf.deb) ...
Unpacking replacement libwbclient0:armhf ...
Preparing to replace libsmbclient:armhf 2:3.6.6-6+deb7u5 (using .../libsmbclient_2%3a3.6.6-6+deb7u6_armhf.deb) ...
Unpacking replacement libsmbclient:armhf ...
Preparing to replace smbclient 2:3.6.6-6+deb7u5 (using .../smbclient_2%3a3.6.6-6+deb7u6_armhf.deb) ...
Unpacking replacement smbclient ...
Preparing to replace samba-common 2:3.6.6-6+deb7u5 (using .../samba-common_2%3a3.6.6-6+deb7u6_all.deb) ...
Unpacking replacement samba-common ...
Preparing to replace isc-dhcp-client 4.2.2.dfsg.1-5+deb70u6 (using .../isc-dhcp-client_4.2.2.dfsg.1-5+deb70u8_armhf.deb) ...
Unpacking replacement isc-dhcp-client ...
Preparing to replace isc-dhcp-common 4.2.2.dfsg.1-5+deb70u6 (using .../isc-dhcp-common_4.2.2.dfsg.1-5+deb70u8_armhf.deb) ...
Unpacking replacement isc-dhcp-common ...
Preparing to replace bind9-host 1:9.8.4.dfsg.P1-6+nmu2+deb7u8 (using .../bind9-host_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u9_armhf.deb) ...
Unpacking replacement bind9-host ...
Preparing to replace libisc84 1:9.8.4.dfsg.P1-6+nmu2+deb7u8 (using .../libisc84_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u9_armhf.deb) ...
Unpacking replacement libisc84 ...
Preparing to replace libdns88 1:9.8.4.dfsg.P1-6+nmu2+deb7u8 (using .../libdns88_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u9_armhf.deb) ...
Unpacking replacement libdns88 ...
Preparing to replace libisccc80 1:9.8.4.dfsg.P1-6+nmu2+deb7u8 (using .../libisccc80_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u9_armhf.deb) ...
Unpacking replacement libisccc80 ...
Preparing to replace libisccfg82 1:9.8.4.dfsg.P1-6+nmu2+deb7u8 (using .../libisccfg82_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u9_armhf.deb) ...
Unpacking replacement libisccfg82 ...
Preparing to replace libbind9-80 1:9.8.4.dfsg.P1-6+nmu2+deb7u8 (using .../libbind9-80_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u9_armhf.deb) ...
Unpacking replacement libbind9-80 ...
Preparing to replace liblwres80 1:9.8.4.dfsg.P1-6+nmu2+deb7u8 (using .../liblwres80_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u9_armhf.deb) ...
Unpacking replacement liblwres80 ...
Preparing to replace openssh-server 1:6.0p1-4+deb7u2 (using .../openssh-server_1%3a6.0p1-4+deb7u3_armhf.deb) ...
Unpacking replacement openssh-server ...
Preparing to replace openssh-client 1:6.0p1-4+deb7u2 (using .../openssh-client_1%3a6.0p1-4+deb7u3_armhf.deb) ...
Unpacking replacement openssh-client ...
Preparing to replace openssl 1.0.1e-2+rvt+deb7u18 (using .../openssl_1.0.1e-2+rvt+deb7u19_armhf.deb) ...
Unpacking replacement openssl ...
Preparing to replace python-rpi.gpio 0.5.11-1 (using .../python-rpi.gpio_0.6.1~wheezy-1_armhf.deb) ...
Unpacking replacement python-rpi.gpio ...
Preparing to replace python3-rpi.gpio 0.5.11-1 (using .../python3-rpi.gpio_0.6.1~wheezy-1_armhf.deb) ...
Unpacking replacement python3-rpi.gpio ...
Preparing to replace sudo 1.8.5p2-1+nmu3 (using .../sudo_1.8.5p2-1+nmu3+deb7u1_armhf.deb) ...
Unpacking replacement sudo ...
Preparing to replace ssh 1:6.0p1-4+deb7u2 (using .../ssh_1%3a6.0p1-4+deb7u3_all.deb) ...
Unpacking replacement ssh ...
Processing triggers for man-db ...
Setting up libssl1.0.0:armhf (1.0.1e-2+rvt+deb7u19) ...
Setting up xrdp (0.5.0-2) ...
insserv: warning: script 'nooliterx' missing LSB tags and overrides
insserv: There is a loop between service watchdog and nooliterx if stopped
insserv: loop involving service nooliterx at depth 2
insserv: loop involving service watchdog at depth 1
insserv: Stopping nooliterx depends on watchdog and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing xrdp (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up libpng12-0:armhf (1.2.49-1+deb7u2) ...
Setting up libpng12-dev (1.2.49-1+deb7u2) ...
Setting up libwbclient0:armhf (2:3.6.6-6+deb7u6) ...
Setting up libsmbclient:armhf (2:3.6.6-6+deb7u6) ...
Setting up samba-common (2:3.6.6-6+deb7u6) ...
Setting up smbclient (2:3.6.6-6+deb7u6) ...
Setting up isc-dhcp-common (4.2.2.dfsg.1-5+deb70u8) ...
Setting up isc-dhcp-client (4.2.2.dfsg.1-5+deb70u8) ...
Setting up libisc84 (1:9.8.4.dfsg.P1-6+nmu2+deb7u9) ...
Setting up libdns88 (1:9.8.4.dfsg.P1-6+nmu2+deb7u9) ...
Setting up libisccc80 (1:9.8.4.dfsg.P1-6+nmu2+deb7u9) ...
Setting up libisccfg82 (1:9.8.4.dfsg.P1-6+nmu2+deb7u9) ...
Setting up libbind9-80 (1:9.8.4.dfsg.P1-6+nmu2+deb7u9) ...
Setting up liblwres80 (1:9.8.4.dfsg.P1-6+nmu2+deb7u9) ...
Setting up bind9-host (1:9.8.4.dfsg.P1-6+nmu2+deb7u9) ...
Setting up openssh-client (1:6.0p1-4+deb7u3) ...
Setting up openssh-server (1:6.0p1-4+deb7u3) ...
dpkg: error processing openssh-server (--configure):
Setting up openssl (1.0.1e-2+rvt+deb7u19) ...
Setting up python-rpi.gpio (0.6.1~wheezy-1) ...
Setting up python3-rpi.gpio (0.6.1~wheezy-1) ...
Setting up sudo (1.8.5p2-1+nmu3+deb7u1) ...
dpkg: error processing sudo (--configure):
dpkg: dependency problems prevent configuration of ssh:
ssh depends on openssh-server; however:
Package openssh-server is not configured yet.
dpkg: error processing ssh (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
xrdp
openssh-server
sudo
ssh
E: Sub-process /usr/bin/dpkg returned an error code (1)
pi@raspberrypi ~ $
