На что поставить сервер MD
Boom777
Сообщение Boom777 » Сб фев 04, 2017 2:48 am
Посоветуйте новичку. Графиков не будет. Несколько сценариев и работа через mqtt. Около 10 датчиков температуры.И голос Алисы с запуском музычки Ставить на винду 7 плвнирую.Хватит ли вот этой материнки VIA EPIA- C3 800MHz Mini-ITX?
Processor
- VIA C3 E-Series processor (EBGA package) - 800MHz with 29DB(a) 40mm fan
- 100/133MHz Front Side Bus (depending upon what speed memory you use)
- 128K L1 and 64K L2 cache
Chipset
- VIA Apollo PLE133
- VT8601A North Bridge
- Featuring integrated AGP 2X graphics
- VIA VT8231 South Bridge
TV-Out
- Integrated Macro Vision 7.01
- High quality scaling and filtering
- S-Video or Composite video output
- Supports NTSC/PAL TV formats
Main Memory
- Two 168-pin DIMM memory sockets (Supports up to 1GB)
- PC100/133 SDRAM support
LAN
- VIA 10/100 Ethernet LAN onboard (VIA VT6102 Rhine II Fast Ethernet Adapter)
Graphics
- Integrated AGP4X with 2D/3D Graphics Acceleration (Trident Blade 3D, uses system RAM)
- Motion Compensation for DVD playback
- VIP port for video overlay function
Audio
- VIA VT1612A AC'97 onboard
- 3 Audio Jacks - Line-Out, Line-In and Microphone-In
- Sound Blaster, Sound Blaster Pro Compatible
- Digital I/O compatible with consumer mode S/PDIF
Expansion Slots
- ATA/100/66/33 Support
- 1 PCI slots
Onboard IDE
- ATA/100/66 (2 ports, up to 4 devices - no floppy drive connector)
I/O Ports
- 3 Audio Jacks - Line-out, Mic-in and Line-in
- Four USB ports (two USB ports located at rear side - the 2 additional ones you would have to add)
- 1 EPP/ECP parallel port
- 1 16C550 compatible serial port
- 2 External PS/2 Compatible Keyboard /Mouse ports
- 2 TV output ports (S-Video or optional RCA TV out)
- 1 S/PDIF out (optional and multiplex with RCA TV out)
- 1 RJ-45 LAN port
- 1 PCI slot (Note: support for two PCI devices - with additional riser)
immortal
Re: На что поставить сервер MD
Сообщение immortal » Сб фев 04, 2017 8:38 am
хватит
Boom777
Сообщение Boom777 » Сб фев 04, 2017 10:17 am
А какие еще есть бюджетные варианты на mini itx? Какой hhd посоветуете поставить 80gb хватит?
Amarok
Сообщение Amarok » Сб фев 04, 2017 1:16 pm
Boom777 писал(а):Какой hhd посоветуете поставить 80gb хватит?
Да. Но на моей Алиске 320гиг ноутбучного форм-фактора.
