Имеется будущее сердец моего умного дома iBoardPro
(помесь atnega2560 и w5100)
Я уже скатился до элементарного - пытаюсь помигать диодом - и не вкакую
вот скетч
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and
Leonardo, it is attached to digital pin 13. If you're unsure what
pin the on-board LED is connected to on your Arduino model, check
the documentation at http://arduino.cc
// the setup function runs once when you press reset or power the board
void setup() {
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
pinMode(37, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(37, HIGH); // turn the LED on (HIGH is the voltage level)
delay(500); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
digitalWrite(37, LOW); // turn the LED off by making the voltage LOW
вот лог
Sketch uses 1 536 bytes (0%) of program storage space. Maximum is 258 048 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8 183 bytes for local variables. Maximum is 8 192 bytes.
C:\arduino-1.6.1/hardware/tools/avr/bin/avrdude -CC:\arduino-1.6.1/hardware/tools/avr/etc/avrdude.conf -v -patmega2560 -cusbasp -Pusb -Uflash:w:C:\Users\Mk\AppData\Local\Temp\build8103354451921061320.tmp/Blink-iBoradPro.cpp.hex:i
avrdude: Version 6.0.1, compiled on Jan 15 2015 at 16:58:43
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\arduino-1.6.1/hardware/tools/avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbasp
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9801
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\Mk\AppData\Local\Temp\build8103354451921061320.tmp/Blink-iBoradPro.cpp.hex"
avrdude: writing flash (1536 bytes):
Writing | ################################################## | 100% 1.02s
avrdude: 1536 bytes of flash written
avrdude: verifying flash memory against C:\Users\Mk\AppData\Local\Temp\build8103354451921061320.tmp/Blink-iBoradPro.cpp.hex:
avrdude: load data flash data from input file C:\Users\Mk\AppData\Local\Temp\build8103354451921061320.tmp/Blink-iBoradPro.cpp.hex:
avrdude: input file C:\Users\Mk\AppData\Local\Temp\build8103354451921061320.tmp/Blink-iBoradPro.cpp.hex contains 1536 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.87s
avrdude: verifying ...
avrdude: 1536 bytes of flash verified
avrdude done. Thank you.
как заставить ее работать ?????????
