if ($params['VALUE']) {
getURL('http://127.0.0.1/rc/?command=vlc_close', 0);
$token = 'fd203e6673e047c042cd7357284abcd6cb98e8e5f9eae811111111111111111111111111111111111111';
if (isset($params['COUNT'])) {
$trackCount = $params['COUNT'];
$trackCount = 1;
if ($params['MODE'] == 0) {
$uid = $params['VALUE'];
$link = 'https://api.vk.com/method/audio.get.xml?owner_id=' . urlencode($uid) . '&access_token=' . $token;
} elseif ($params['MODE'] == 1) {
$trackName = $params['VALUE'];
$link = 'https://api.vk.com/method/audio.search.xml?q=' . urlencode($trackName) . '&count=' . $trackCount . '&auto_complete=1&sort=2&access_token=' . $token;
} elseif ($params['MODE'] == 2) {
$performerName = $params['VALUE'];
$link = 'https://api.vk.com/method/audio.search.xml?q=' . urlencode($performerName) . '&count=' . $trackCount . '&auto_complete=1&performer_only=1&sort=2&access_token=' . $token;
if (isset($params['ALBUM'])) {
$link = 'https://api.vk.com/method/audio.getAlbums.xml?owner_id=' . urlencode($uid) . '&access_token=' . $token;
$res = getURL($link,0);
$xml = new SimpleXMLElement($res);
foreach ($xml->album as $item) {
if ($item->title == $params['ALBUM']) {
$albumId = $item->album_id;
break;
$link = 'https://api.vk.com/method/audio.get.xml?owner_id=' . urlencode($uid) . '&access_token=' . $token . '&album_id=' . $albumId;
$tempPlaylist = sys_get_temp_dir() .DIRECTORY_SEPARATOR. "playlist.m3u";
$fp = fopen($tempPlaylist, "w");
fwrite($fp, '#EXTM3U' . "\r\n");
foreach ($xml->audio as $item) {
fwrite($fp, '#EXTINF:' . $item->duration . ', ' . $item->artist . ' - ' . $item->title . "\r\n");
fwrite($fp, $item->url . "\r\n");
fwrite($fp, "\r\n");
fclose($fp);
getURL('http://127.0.0.1/rc/?command=vlc_play¶m='.$tempPlaylist, 0);
runScript("VkMusic", array('VALUE'=>$matches[2], 'MODE'=>1));Позволяет так же прослушать плейлист пользователя.
runScript("VkMusic", array('VALUE'=>Ид_Пользователя, 'MODE'=>0)); Код: Выделить всё
runScript("VkMusic", array('VALUE'=>'Король и шут', 'MODE'=>2, 'COUNT'=>'10')); Можно так же проиграть альбом пользователя.
runScript("VkMusic", array('VALUE'=>ID_ПользователяВК, 'MODE'=>3, 'ALBUM'=>НазваниеАльбома)); VALUE - Идентификатор пользователя в ВК (или исполнитель для MODE = 2)
MODE - Параметры поиска (0 - Плейлист пользователя, 1 - Поиск конкретной песни, 2 - Поиск по исполнителю, 3 - Альбом пользователя)
COUNT - это количество возвращаемых треков и параметр
ALBUM - название альбома пользователя.
Так же для корректной работы желательно получить токен, для этого надо перейти по ссылке http://oauth.vk.com/authorize?client_id ... type=token и скопировать из адресной строки access_token. Полученный токе необходимо присвоить переменной $token.
