Проблема с установкой
mikefluff
Сообщение mikefluff » Пн сен 22, 2014 1:27 pm
После установки системы при попытке захода на любую страницу с расширением .html вылетает ошибка (админка работает).
Кто-нибудь сталкивался с подобным?
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined variable: found in /private/var/www/majordomo/nf.php on line 63, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined variable: res_str in /private/var/www/majordomo/lib/module.class.php on line 733, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined offset: 1 in /private/var/www/majordomo/lib/module.class.php on line 727, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined offset: 1 in /private/var/www/majordomo/lib/module.class.php on line 728, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined offset: 1 in /private/var/www/majordomo/lib/module.class.php on line 731, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined variable: params1 in /private/var/www/majordomo/lib/module.class.php on line 142, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined offset: 2 in /private/var/www/majordomo/lib/module.class.php on line 727, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined offset: 2 in /private/var/www/majordomo/lib/module.class.php on line 728, referer: http://localhost/
[Mon Sep 22 14:26:29 2014] [error] [client ::1] PHP Notice: Undefined variable: param_str in /private/var/www/majordomo/lib/module.class.php on line 708, referer: http://localhost/
