При добавлении трека вижу вот такую картину.
Error
Details
http://192.168.1.125/index.php?pd=pz_YXBwbGljYXRpb246e2FjdGlvbj1hcHBfUG9zdFRyYWNrZXIscG9wdXA9MX0%3Dpz_&md=app_PostTracker&inst=&
1364: Field 'PROVIDER_ID' doesn't have a default value
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `TRACK_ID`, `PROVIDER`) VALUES('2018-11-28 20:44:59', 'Add track code to module', '45', '-1')
Backtrace
#0 /var/www/lib/mysqli.class.php(396): custom_error->__construct('1364: Field 'PR...', 0)
#1 /var/www/lib/mysqli.class.php(185): mysql->Error('INSERT INTO `pt...', 0)
#2 /var/www/lib/mysqli.class.php(329): mysql->Exec('INSERT INTO `pt...')
#3 /var/www/lib/sqlFunctions.class.php(111): mysql->Insert('pt_status', Array)
#4 /var/www/modules/app_PostTracker/app_PostTracker.class.php(201): SQLInsert('pt_status', Array)
#5 /var/www/modules/app_PostTracker/app_PostTracker.class.php(90): app_PostTracker->usual(Array)
#6 /var/www/lib/jTemplate.class.php(713) : eval()'d code(6): app_PostTracker->run()
#7 /var/www/lib/jTemplate.class.php(713): eval()
#8 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#9 /var/www/lib/jTemplate.class.php(840): jTemplate->parse('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#10 /var/www/lib/jTemplate.class.php(201): jTemplate->parseIncludes('\n\n<...', Array, './templates/')
#11 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('\n\n<...', Array, './templates/')
#12 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/app...', Array, Object(application))
#13 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/app...', Array)
#14 /var/www/modules/application.class.php(382): parser->__construct('./templates/app...', Array, Object(application))
#15 /var/www/index.php(71): application->run()
#16 {main}
Error
Details
Backtrace
#1 /var/www/lib/mysqli.class.php(331): mysql->Error('INSERT INTO `pt...')
#2 /var/www/lib/sqlFunctions.class.php(111): mysql->Insert('pt_status', Array)
#3 /var/www/modules/app_PostTracker/app_PostTracker.class.php(201): SQLInsert('pt_status', Array)
#4 /var/www/modules/app_PostTracker/app_PostTracker.class.php(90): app_PostTracker->usual(Array)
#5 /var/www/lib/jTemplate.class.php(713) : eval()'d code(6): app_PostTracker->run()
#6 /var/www/lib/jTemplate.class.php(713): eval()
#7 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#8 /var/www/lib/jTemplate.class.php(840): jTemplate->parse('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#9 /var/www/lib/jTemplate.class.php(201): jTemplate->parseIncludes('\n\n<...', Array, './templates/')
#10 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('\n\n<...', Array, './templates/')
#11 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/app...', Array, Object(application))
#12 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/app...', Array)
#13 /var/www/modules/application.class.php(382): parser->__construct('./templates/app...', Array, Object(application))
#14 /var/www/index.php(71): application->run()
#15 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-11-05 08:00:59', 'Airline departure from original country', '', '', '45', '4')
Backtrace
#4 /var/www/modules/app_PostTracker/app_PostTracker.class.php(451): SQLInsert('pt_status', Array)
#5 /var/www/modules/app_PostTracker/app_PostTracker.class.php(420): app_PostTracker->updateStatus(Object(Moyaposylka), Array, false)
#6 /var/www/modules/app_PostTracker/app_PostTracker.class.php(204): app_PostTracker->updateStatusInit(Array)
#7 /var/www/modules/app_PostTracker/app_PostTracker.class.php(90): app_PostTracker->usual(Array)
#8 /var/www/lib/jTemplate.class.php(713) : eval()'d code(6): app_PostTracker->run()
#9 /var/www/lib/jTemplate.class.php(713): eval()
#10 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#11 /var/www/lib/jTemplate.class.php(840): jTemplate->parse('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#12 /var/www/lib/jTemplate.class.php(201): jTemplate->parseIncludes('\n\n<...', Array, './templates/')
#13 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('\n\n<...', Array, './templates/')
#14 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/app...', Array, Object(application))
#15 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/app...', Array)
#16 /var/www/modules/application.class.php(382): parser->__construct('./templates/app...', Array, Object(application))
#17 /var/www/index.php(71): application->run()
#18 {main}
Error
Details
Backtrace
#3 /var/www/modules/app_PostTracker/app_PostTracker.class.php(451): SQLInsert('pt_status', Array)
#4 /var/www/modules/app_PostTracker/app_PostTracker.class.php(420): app_PostTracker->updateStatus(Object(Moyaposylka), Array, false)
#5 /var/www/modules/app_PostTracker/app_PostTracker.class.php(204): app_PostTracker->updateStatusInit(Array)
#6 /var/www/modules/app_PostTracker/app_PostTracker.class.php(90): app_PostTracker->usual(Array)
#7 /var/www/lib/jTemplate.class.php(713) : eval()'d code(6): app_PostTracker->run()
#8 /var/www/lib/jTemplate.class.php(713): eval()
#9 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#10 /var/www/lib/jTemplate.class.php(840): jTemplate->parse('\n\n\n\n\n\n\n \n [#mo...', Array, './templates/')
#11 /var/www/lib/jTemplate.class.php(201): jTemplate->parseIncludes('\n\n<...', Array, './templates/')
#12 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('\n\n<...', Array, './templates/')
#13 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/app...', Array, Object(application))
#14 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/app...', Array)
#15 /var/www/modules/application.class.php(382): parser->__construct('./templates/app...', Array, Object(application))
#16 /var/www/index.php(71): application->run()
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-31 14:43:59', 'Передано авиа перевозчику', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-31 11:10:59', 'Покинуло транзитную страну', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-30 19:10:59', 'Заказ принят местным отделением службы доставки', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-30 19:10:58', 'Прибыло в транзитную страну', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-30 08:51:59', 'Export clearance success', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-30 07:58:59', 'Получена информация о заказе перевозчиком', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-30 07:58:58', 'Покинуло сортировочный центр', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-30 00:09:59', 'Прибыло в сортировочный центр', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Error
Details
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `LOCATION`, `LOCATION_ZIP`, `TRACK_ID`, `PROVIDER`) VALUES('2018-10-29 23:39:59', 'Отправление принято перевозчиком', '', '', '45', '4')
Backtrace
#18 {main}
Error
Details
Backtrace
#17 {main}
Headers already sent in on line
Cannot redirect instead
