[Модуль] PostTracker (app_PostTracker)
VladPTZ
Re: [Модуль] PostTracker (app_PostTracker)
Сообщение VladPTZ »
Error
Details
http://192.168.1.125/index.php?pd=pz_YXBwbGljYXRpb246e2FjdGlvbj1hcHBfUG9zdFRyYWNrZXIscG9wdXA9MX0%3Dpz_&md=app_PostTracker&inst=&
1364: Field 'PROVIDER_ID' doesn't have a default value
INSERT INTO `pt_status`(`DATE_STATUS`, `STATUS_INFO`, `TRACK_ID`, `PROVIDER`) VALUES('2018-11-25 10:40:56', 'Add track code to module', '46', '-1')
Backtrace
#0 /var/www/lib/mysqli.class.php(396): custom_error->__construct('1364: Field 'PR...', 0)
#1 /var/www/lib/mysqli.class.php(185): mysql->Error('INSERT INTO `pt...', 0)
#2 /var/www/lib/mysqli.class.php(329): mysql->Exec('INSERT INTO `pt...')
#3 /var/www/lib/sqlFunctions.class.php(111): mysql->Insert('pt_status', Array)
#4 /var/www/modules/app_PostTracker/app_PostTracker.class.php(201): SQLInsert('pt_status', Array)
#5 /var/www/modules/app_PostTracker/app_PostTracker.class.php(90): app_PostTracker->usual(Array)
#6 /var/www/lib/jTemplate.class.php(713) : eval()'d code(6): app_PostTracker->run()
#7 /var/www/lib/jTemplate.class.php(713): eval()
#8 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('\n\n\n\n\n\n\n \n  [#mo...', Array, './templates/')
#9 /var/www/lib/jTemplate.class.php(840): jTemplate->parse('\n\n\n\n\n\n\n \n  [#mo...', Array, './templates/')
#10 /var/www/lib/jTemplate.class.php(201): jTemplate->parseIncludes('\n\n<...', Array, './templates/')
#11 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('\n\n<...', Array, './templates/')
#12 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/app...', Array, Object(application))
#13 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/app...', Array)
#14 /var/www/modules/application.class.php(382): parser->__construct('./templates/app...', Array, Object(application))
#15 /var/www/index.php(71): application->run()
#16 {main}
Error
Details
Backtrace
#1 /var/www/lib/mysqli.class.php(331): mysql->Error('INSERT INTO `pt...')
#2 /var/www/lib/sqlFunctions.class.php(111): mysql->Insert('pt_status', Array)
#3 /var/www/modules/app_PostTracker/app_PostTracker.class.php(201): SQLInsert('pt_status', Array)
#4 /var/www/modules/app_PostTracker/app_PostTracker.class.php(90): app_PostTracker->usual(Array)
#5 /var/www/lib/jTemplate.class.php(713) : eval()'d code(6): app_PostTracker->run()
#6 /var/www/lib/jTemplate.class.php(713): eval()
#7 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('\n\n\n\n\n\n\n \n  [#mo...', Array, './templates/')
#8 /var/www/lib/jTemplate.class.php(840): jTemplate->parse('\n\n\n\n\n\n\n \n  [#mo...', Array, './templates/')
#9 /var/www/lib/jTemplate.class.php(201): jTemplate->parseIncludes('\n\n<...', Array, './templates/')
#10 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('\n\n<...', Array, './templates/')
#11 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/app...', Array, Object(application))
#12 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/app...', Array)
#13 /var/www/modules/application.class.php(382): parser->__construct('./templates/app...', Array, Object(application))
#14 /var/www/index.php(71): application->run()
#15 {main}
При добалении трека происходит это, почему?
Короче модуль не работоспособен вообще, систему переустановил, модуль переустановил, все треки удалялю
Eraser
Сообщение Eraser »
VladPTZ писал(а): Вс ноя 25, 2018 10:43 am
Error
Details
Backtrace
#16 {main}
Error
Details
Backtrace
#15 {main}
в настройках какой провайдер выбран?
Connect ---- Telegram
VladPTZ
Сообщение VladPTZ »
Пробовал на 17Track и моя посылка.
Может с базы надо остатки модуля удалить и по новой поставить, что и где в базе хронит модуль??
VladPTZ
Сообщение VladPTZ »
Как в итоге настроить модуль чтобы снова заработал?
Какой с каким провайдером точно работает?
Какие настройки обязательны?
Какие действия на сайте провайдера обязательны?
Eraser
Сообщение Eraser »
VladPTZ писал(а): Вс ноя 25, 2018 5:38 pm Как в итоге настроить модуль чтобы снова заработал?
на последней альфе
провайдер Моя посылка, нужен ключ для доступа к API https://moyaposylka.ru/profile/api-settings/
VladPTZ
Сообщение VladPTZ »
Альфу пока не пробовал.
На Мастере сделал на вмвари чистую машину с ubuntu 18, поставил и настроил модуль на чистой базе, проблемы теже самые, не работает и виснет.
Завтра попробую на тестовой машине обновится с альфы.
VladPTZ
Сообщение VladPTZ »
Попробовал обновить мд с альфы.
Результат аналогичный.
Не хочет проверять и виснет при добавления трека и нажатия кнопки проверки.
Ключ генерировал новый, машина залита свежая, база чистая. Модуль удалял и устанавливал по новой.
Eraser
Сообщение Eraser »
VladPTZ писал(а): Вт ноя 27, 2018 5:48 pm Попробовал обновить мд с альфы.
ок, давайте разбираться
что в логах пишет? какая ошибка?
VladPTZ
Сообщение VladPTZ »
Подскажите пожалуйста, в каком конкретно логе смотреть, копался в логах но не понял что относится к работе модуля?
Eraser
Сообщение Eraser »
VladPTZ писал(а): Вт ноя 27, 2018 7:30 pm Подскажите пожалуйста, в каком конкретно логе смотреть, копался в логах но не понял что относится к работе модуля?
для начала что пишет в логе апача
