Module Contacts
#ifdef CONTACTS_FEATURE
#define CONT1_PIN 27
#define CONT2_PIN 31
#define OPEN 1
#define CLOSE 0
char cont1object[] = "cont1";
char cont2object[] = "cont2";
char cont1openMess[] = "Open"; char cont1closeMess[] = "Closed";
char cont2openMess[] = "Down"; char cont2closeMess[] = "Norm";
// states
// 0 - open
// 1 - close
// 2 - not defined
byte cont1state = 2; byte old_cont1state = 2; byte cont1objectState = 2;
byte cont2state = 2; byte old_cont2state = 2; byte cont2objectState = 2;
void contactsInit() {
pinMode(CONT1_PIN, INPUT);
pinMode(CONT2_PIN, INPUT);
moduleContacts = MODULE_ENABLE;
started("Contacts");
void printContMess(char obj[], char mess[]) {
timeStamp(); Serial.print(obj); Serial.print(F(": ")); Serial.println(mess);
void contactsWorks() {
// cont1
cont1state = digitalRead(CONT1_PIN);
if (cont1state != old_cont1state) {
old_cont1state = cont1state;
if (cont1state == 0) {
cont1objectState = OPEN;
printContMess(cont1object, cont1openMess);
#ifdef MAJORDOMO_FEATURE
sendRequestM(cont1object, OPEN);
#endif
cont1objectState = CLOSE;
printContMess(cont1object, cont1closeMess);
sendRequestM(cont1object, CLOSE);
#endif
// cont2
cont2state = digitalRead(CONT2_PIN);
if (cont2state != old_cont2state) {
old_cont2state = cont2state;
if (cont2state == 1) {
cont2objectState = OPEN;
printContMess(cont2object, cont2openMess);
cont2objectState = CLOSE;
printContMess(cont2object, cont2closeMess);
} // contactsWorks()
#endif // CONTACTS_FEATURE
String makeContacts() {
String s = "";
s += makeTag(BASE_CONTACT, "1", String(cont1objectState));
s += makeTag(BASE_CONTACT, "2", String(cont2objectState));
return s;
#endif
s += makeContacts();// В void respDash(EthernetClient cl) {
#endif
// Contacts
for (var i = 0; i < contName.length; i++) {
try {
var dcont = this.responseXML.getElementsByTagName(contXml[i])[0].childNodes[0].nodeValue;
} catch (err) {
dcont = '-1';
try {
document.getElementById(contId[i]).innerHTML = contName[i];
document.getElementById(contId[i]).style.background = contactBackground(dcont);
document.getElementById(contId[i]).style.color = contactColor(dcont);
} catch (err) { }
