Обновление PHP 5.3 до PHP 7.2.2
Re: Обновление PHP 5.3 до PHP 7.2.2
на форуме было такое, через пма решали, насколько помню
- webms
а как именно решили?Logrus писал(а):на форуме было такое, через пма решали, насколько помню
хз, вроде б вовикс писал, в таблицу админа вбивал, загугли ошибку на форуме
- webms
удалил .htaccess и хотябы myphpadmin открывает
но если зайти на мд, то скидывает на страницу выбора языка
[Sun Mar 04 23:27:44.691253 2018] [ssl:warn] [pid 5656:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:27:44.692253 2018] [ssl:warn] [pid 5656:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:27:44.726255 2018] [core:warn] [pid 5656:tid 236] AH00098: pid file C:/_majordomo/server/Apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Mar 04 23:27:44.855262 2018] [ssl:warn] [pid 5656:tid 236] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:27:44.856263 2018] [ssl:warn] [pid 5656:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:27:44.856263 2018] [ssl:warn] [pid 5656:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
MIB search path: c:/usr/share/snmp/mibs
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (SNMPv2-SMI): At line 0 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 0 in (none)
Cannot find module (UCD-SNMP-MIB): At line 0 in (none)
Cannot find module (UCD-DEMO-MIB): At line 0 in (none)
Cannot find module (SNMP-TARGET-MIB): At line 0 in (none)
Cannot find module (NET-SNMP-AGENT-MIB): At line 0 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 0 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 0 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 0 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 0 in (none)
Cannot find module (SNMP-NOTIFICATION-MIB): At line 0 in (none)
Cannot find module (SNMPv2-TM): At line 0 in (none)
[Sun Mar 04 23:27:44.896265 2018] [mpm_winnt:notice] [pid 5656:tid 236] AH00455: Apache/2.4.18 (Win32) OpenSSL/1.0.2f PHP/7.2.2 configured -- resuming normal operations
[Sun Mar 04 23:27:44.896265 2018] [mpm_winnt:notice] [pid 5656:tid 236] AH00456: Server built: Jan 28 2016 09:58:25
[Sun Mar 04 23:27:44.896265 2018] [core:notice] [pid 5656:tid 236] AH00094: Command line: 'C:\\_majordomo\\server\\Apache\\bin\\Apache.exe -d C:/_majordomo/server/Apache -f C:\\_majordomo\\\\server\\apache\\conf\\\\httpd.conf'
[Sun Mar 04 23:27:44.898265 2018] [mpm_winnt:notice] [pid 5656:tid 236] AH00418: Parent: Created child process 5732
[Sun Mar 04 23:27:45.612306 2018] [ssl:warn] [pid 5732:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:27:45.613306 2018] [ssl:warn] [pid 5732:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:27:45.768315 2018] [ssl:warn] [pid 5732:tid 252] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:27:45.769315 2018] [ssl:warn] [pid 5732:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:27:45.769315 2018] [ssl:warn] [pid 5732:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:27:45.801317 2018] [mpm_winnt:notice] [pid 5732:tid 252] AH00354: Child: Starting 64 worker threads.
[Sun Mar 04 23:27:47.746428 2018] [core:alert] [pid 5732:tid 968] [client 192.168.0.62:60288] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:28:09.562676 2018] [core:alert] [pid 5732:tid 968] [client 192.168.0.200:3024] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:28:12.291832 2018] [mpm_winnt:notice] [pid 5656:tid 236] AH00428: Parent: child process 5732 exited with status 1073807364 -- Restarting.
[Sun Mar 04 23:29:49.878493 2018] [ssl:warn] [pid 4492:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:29:49.897494 2018] [ssl:warn] [pid 4492:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:29:49.951497 2018] [core:warn] [pid 4492:tid 236] AH00098: pid file C:/_majordomo/server/Apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Mar 04 23:29:50.067504 2018] [ssl:warn] [pid 4492:tid 236] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:29:50.067504 2018] [ssl:warn] [pid 4492:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:29:50.067504 2018] [ssl:warn] [pid 4492:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:29:56.435868 2018] [mpm_winnt:notice] [pid 4492:tid 236] AH00455: Apache/2.4.18 (Win32) OpenSSL/1.0.2f PHP/7.2.2 configured -- resuming normal operations
[Sun Mar 04 23:29:56.435868 2018] [mpm_winnt:notice] [pid 4492:tid 236] AH00456: Server built: Jan 28 2016 09:58:25
[Sun Mar 04 23:29:56.435868 2018] [core:notice] [pid 4492:tid 236] AH00094: Command line: 'C:\\_majordomo\\server\\Apache\\bin\\Apache.exe -d C:/_majordomo/server/Apache -f C:\\_majordomo\\\\server\\apache\\conf\\\\httpd.conf'
[Sun Mar 04 23:29:56.437868 2018] [mpm_winnt:notice] [pid 4492:tid 236] AH00418: Parent: Created child process 4940
[Sun Mar 04 23:29:57.078905 2018] [ssl:warn] [pid 4940:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:29:57.078905 2018] [ssl:warn] [pid 4940:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:29:57.220913 2018] [ssl:warn] [pid 4940:tid 252] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:29:57.221913 2018] [ssl:warn] [pid 4940:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:29:57.221913 2018] [ssl:warn] [pid 4940:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:29:57.400923 2018] [mpm_winnt:notice] [pid 4940:tid 252] AH00354: Child: Starting 64 worker threads.
[Sun Mar 04 23:30:00.427096 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60318] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:00.497100 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60319] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:30:02.444212 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60320] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:02.492215 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60321] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:30:03.169253 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60322] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:03.217256 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60323] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:30:09.445612 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60327] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:09.969642 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60328] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:30:34.435042 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.200:2834] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:40.441385 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.62:60365] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:40.493388 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.62:60366] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:30:42.254489 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.62:60367] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:42.304492 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.62:60368] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:30:55.577251 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60395] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:56.035277 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60396] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:30:59.055450 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60397] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:30:59.101452 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60398] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:31:29.946217 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60412] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:31:29.997220 2018] [core:alert] [pid 4940:tid 940] [client 192.168.0.62:60413] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:32:12.871672 2018] [core:alert] [pid 4940:tid 924] [client 192.168.0.200:2867] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:32:36.645316 2018] [core:alert] [pid 4940:tid 924] [client 192.168.0.200:2900] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:32:46.440876 2018] [core:alert] [pid 4940:tid 924] [client 192.168.0.62:60427] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:32:46.490879 2018] [core:alert] [pid 4940:tid 924] [client 192.168.0.62:60428] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:33:36.707751 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.200:2933] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:34:36.777187 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.200:2966] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:35:36.847623 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.200:2999] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:36:36.914058 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.200:3032] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:37:36.979494 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.200:3065] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:38:37.050930 2018] [core:alert] [pid 4940:tid 932] [client 192.168.0.200:2842] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:39:18.337291 2018] [mpm_winnt:notice] [pid 4492:tid 236] AH00428: Parent: child process 4940 exited with status 1073807364 -- Restarting.
[Sun Mar 04 23:41:14.859103 2018] [ssl:warn] [pid 4880:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:41:14.925107 2018] [ssl:warn] [pid 4880:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:41:15.069115 2018] [core:warn] [pid 4880:tid 236] AH00098: pid file C:/_majordomo/server/Apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Mar 04 23:41:15.204122 2018] [ssl:warn] [pid 4880:tid 236] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:41:15.207123 2018] [ssl:warn] [pid 4880:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:41:15.207123 2018] [ssl:warn] [pid 4880:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:41:16.293185 2018] [mpm_winnt:notice] [pid 4880:tid 236] AH00455: Apache/2.4.18 (Win32) OpenSSL/1.0.2f PHP/7.2.2 configured -- resuming normal operations
[Sun Mar 04 23:41:16.293185 2018] [mpm_winnt:notice] [pid 4880:tid 236] AH00456: Server built: Jan 28 2016 09:58:25
[Sun Mar 04 23:41:16.293185 2018] [core:notice] [pid 4880:tid 236] AH00094: Command line: 'C:\\_majordomo\\server\\Apache\\bin\\Apache.exe -d C:/_majordomo/server/Apache -f C:\\_majordomo\\\\server\\apache\\conf\\\\httpd.conf'
[Sun Mar 04 23:41:16.295185 2018] [mpm_winnt:notice] [pid 4880:tid 236] AH00418: Parent: Created child process 2180
[Sun Mar 04 23:41:16.965223 2018] [ssl:warn] [pid 2180:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:41:16.965223 2018] [ssl:warn] [pid 2180:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:41:17.153234 2018] [ssl:warn] [pid 2180:tid 252] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:41:17.154234 2018] [ssl:warn] [pid 2180:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:41:17.154234 2018] [ssl:warn] [pid 2180:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:41:17.340245 2018] [mpm_winnt:notice] [pid 2180:tid 252] AH00354: Child: Starting 64 worker threads.
[Sun Mar 04 23:41:24.419650 2018] [core:alert] [pid 2180:tid 964] [client 192.168.0.62:60605] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:41:24.711666 2018] [core:alert] [pid 2180:tid 964] [client 192.168.0.62:60606] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:42:38.596892 2018] [core:alert] [pid 2180:tid 964] [client 192.168.0.200:2941] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:43:38.666328 2018] [core:alert] [pid 2180:tid 944] [client 192.168.0.200:2974] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:43:38.899341 2018] [core:alert] [pid 2180:tid 944] [client 192.168.0.62:60731] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:43:38.964345 2018] [core:alert] [pid 2180:tid 944] [client 192.168.0.62:60732] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:43:40.560436 2018] [core:alert] [pid 2180:tid 944] [client 192.168.0.62:60735] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:43:40.613439 2018] [core:alert] [pid 2180:tid 944] [client 192.168.0.62:60736] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:44:34.054799 2018] [mpm_winnt:notice] [pid 4880:tid 236] AH00428: Parent: child process 2180 exited with status 1073807364 -- Restarting.
[Sun Mar 04 23:46:26.959997 2018] [ssl:warn] [pid 4784:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:46:27.019001 2018] [ssl:warn] [pid 4784:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:46:27.482027 2018] [core:warn] [pid 4784:tid 236] AH00098: pid file C:/_majordomo/server/Apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Mar 04 23:46:27.603034 2018] [ssl:warn] [pid 4784:tid 236] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:46:27.603034 2018] [ssl:warn] [pid 4784:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:46:27.603034 2018] [ssl:warn] [pid 4784:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:46:55.474628 2018] [mpm_winnt:notice] [pid 4784:tid 236] AH00455: Apache/2.4.18 (Win32) OpenSSL/1.0.2f PHP/7.2.2 configured -- resuming normal operations
[Sun Mar 04 23:46:55.474628 2018] [mpm_winnt:notice] [pid 4784:tid 236] AH00456: Server built: Jan 28 2016 09:58:25
[Sun Mar 04 23:46:55.474628 2018] [core:notice] [pid 4784:tid 236] AH00094: Command line: 'C:\\_majordomo\\server\\Apache\\bin\\Apache.exe -d C:/_majordomo/server/Apache -f C:\\_majordomo\\\\server\\apache\\conf\\\\httpd.conf'
[Sun Mar 04 23:46:55.480629 2018] [mpm_winnt:notice] [pid 4784:tid 236] AH00418: Parent: Created child process 5204
[Sun Mar 04 23:46:56.489686 2018] [ssl:warn] [pid 5204:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:46:56.489686 2018] [ssl:warn] [pid 5204:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:46:56.929711 2018] [ssl:warn] [pid 5204:tid 252] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:46:56.930712 2018] [ssl:warn] [pid 5204:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:46:56.930712 2018] [ssl:warn] [pid 5204:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:46:57.164725 2018] [mpm_winnt:notice] [pid 5204:tid 252] AH00354: Child: Starting 64 worker threads.
[Sun Mar 04 23:46:57.412739 2018] [core:alert] [pid 5204:tid 956] [client 192.168.0.62:60782] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:46:57.412739 2018] [core:alert] [pid 5204:tid 952] [client 192.168.0.62:60781] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:46:57.582749 2018] [core:alert] [pid 5204:tid 952] [client 192.168.0.62:60814] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:47:28.836536 2018] [core:alert] [pid 5204:tid 952] [client ::1:49246] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:47:31.007661 2018] [core:alert] [pid 5204:tid 952] [client ::1:49247] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:47:32.496746 2018] [core:alert] [pid 5204:tid 952] [client ::1:49248] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:47:32.516747 2018] [core:alert] [pid 5204:tid 952] [client ::1:49249] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:47:40.491203 2018] [core:alert] [pid 5204:tid 956] [client 192.168.0.200:3041] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:48:20.322481 2018] [core:alert] [pid 5204:tid 956] [client 192.168.0.62:60827] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:48:20.374484 2018] [core:alert] [pid 5204:tid 956] [client 192.168.0.62:60828] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:48:25.240763 2018] [mpm_winnt:notice] [pid 4784:tid 236] AH00428: Parent: child process 5204 exited with status 1073807364 -- Restarting.
[Sun Mar 04 23:50:02.225604 2018] [ssl:warn] [pid 4632:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:50:02.243605 2018] [ssl:warn] [pid 4632:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:50:02.324610 2018] [core:warn] [pid 4632:tid 236] AH00098: pid file C:/_majordomo/server/Apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Mar 04 23:50:02.454617 2018] [ssl:warn] [pid 4632:tid 236] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:50:02.455617 2018] [ssl:warn] [pid 4632:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:50:02.455617 2018] [ssl:warn] [pid 4632:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:50:04.428730 2018] [mpm_winnt:notice] [pid 4632:tid 236] AH00455: Apache/2.4.18 (Win32) OpenSSL/1.0.2f PHP/7.2.2 configured -- resuming normal operations
[Sun Mar 04 23:50:04.428730 2018] [mpm_winnt:notice] [pid 4632:tid 236] AH00456: Server built: Jan 28 2016 09:58:25
[Sun Mar 04 23:50:04.428730 2018] [core:notice] [pid 4632:tid 236] AH00094: Command line: 'C:\\_majordomo\\server\\Apache\\bin\\Apache.exe -d C:/_majordomo/server/Apache -f C:\\_majordomo\\\\server\\apache\\conf\\\\httpd.conf'
[Sun Mar 04 23:50:04.434731 2018] [mpm_winnt:notice] [pid 4632:tid 236] AH00418: Parent: Created child process 5016
[Sun Mar 04 23:50:05.126770 2018] [ssl:warn] [pid 5016:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:50:05.126770 2018] [ssl:warn] [pid 5016:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:50:05.428787 2018] [ssl:warn] [pid 5016:tid 252] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:50:05.429788 2018] [ssl:warn] [pid 5016:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:50:05.429788 2018] [ssl:warn] [pid 5016:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:50:05.578796 2018] [mpm_winnt:notice] [pid 5016:tid 252] AH00354: Child: Starting 64 worker threads.
[Sun Mar 04 23:50:09.224005 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:60853] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:50:09.299009 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:60854] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:50:11.498135 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.200:2851] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:51:11.565570 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.200:2884] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:52:10.597947 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:61033] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:52:10.649950 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:61034] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:52:11.633006 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.200:2917] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:52:59.452741 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:61043] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:52:59.502744 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:61044] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:53:11.701442 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.200:2950] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:21.004974 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:61091] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:21.054977 2018] [core:alert] [pid 5016:tid 940] [client 192.168.0.62:61092] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:53:27.026318 2018] [core:alert] [pid 5016:tid 940] [client ::1:49299] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:27.376338 2018] [core:alert] [pid 5016:tid 940] [client ::1:49300] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/sql.php?db=db_terminal
[Sun Mar 04 23:53:32.232616 2018] [core:alert] [pid 5016:tid 940] [client ::1:49301] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:32.359623 2018] [core:alert] [pid 5016:tid 940] [client ::1:49302] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:53:36.811878 2018] [core:alert] [pid 5016:tid 940] [client ::1:49303] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:36.839879 2018] [core:alert] [pid 5016:tid 940] [client ::1:49304] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:53:37.440914 2018] [core:alert] [pid 5016:tid 940] [client ::1:49314] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:37.463915 2018] [core:alert] [pid 5016:tid 940] [client ::1:49315] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:53:37.637925 2018] [core:alert] [pid 5016:tid 940] [client ::1:49317] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:37.670927 2018] [core:alert] [pid 5016:tid 940] [client ::1:49318] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:53:37.812935 2018] [core:alert] [pid 5016:tid 940] [client ::1:49319] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:53:37.840937 2018] [core:alert] [pid 5016:tid 940] [client ::1:49320] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:54:02.987375 2018] [core:alert] [pid 5016:tid 936] [client ::1:49340] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:54:03.170386 2018] [core:alert] [pid 5016:tid 936] [client ::1:49341] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Sun Mar 04 23:54:11.768877 2018] [core:alert] [pid 5016:tid 928] [client 192.168.0.200:2983] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:54:43.591826 2018] [mpm_winnt:notice] [pid 4632:tid 236] AH00428: Parent: child process 5016 exited with status 1073807364 -- Restarting.
[Sun Mar 04 23:56:13.889186 2018] [ssl:warn] [pid 4644:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:56:13.915187 2018] [ssl:warn] [pid 4644:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:56:13.975191 2018] [core:warn] [pid 4644:tid 236] AH00098: pid file C:/_majordomo/server/Apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Mar 04 23:56:14.109199 2018] [ssl:warn] [pid 4644:tid 236] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:56:14.110199 2018] [ssl:warn] [pid 4644:tid 236] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:56:14.110199 2018] [ssl:warn] [pid 4644:tid 236] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:56:27.968991 2018] [mpm_winnt:notice] [pid 4644:tid 236] AH00455: Apache/2.4.18 (Win32) OpenSSL/1.0.2f PHP/7.2.2 configured -- resuming normal operations
[Sun Mar 04 23:56:27.968991 2018] [mpm_winnt:notice] [pid 4644:tid 236] AH00456: Server built: Jan 28 2016 09:58:25
[Sun Mar 04 23:56:27.968991 2018] [core:notice] [pid 4644:tid 236] AH00094: Command line: 'C:\\_majordomo\\server\\Apache\\bin\\Apache.exe -d C:/_majordomo/server/Apache -f C:\\_majordomo\\\\server\\apache\\conf\\\\httpd.conf'
[Sun Mar 04 23:56:27.971991 2018] [mpm_winnt:notice] [pid 4644:tid 236] AH00418: Parent: Created child process 4100
[Sun Mar 04 23:56:29.366071 2018] [ssl:warn] [pid 4100:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:56:29.367071 2018] [ssl:warn] [pid 4100:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:56:29.744093 2018] [ssl:warn] [pid 4100:tid 252] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sun Mar 04 23:56:29.745093 2018] [ssl:warn] [pid 4100:tid 252] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Sun Mar 04 23:56:29.745093 2018] [ssl:warn] [pid 4100:tid 252] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Sun Mar 04 23:56:30.160117 2018] [mpm_winnt:notice] [pid 4100:tid 252] AH00354: Child: Starting 64 worker threads.
[Sun Mar 04 23:56:30.831155 2018] [core:alert] [pid 4100:tid 964] [client 192.168.0.62:61160] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:56:30.831155 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.62:61161] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:56:31.367186 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.62:61186] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:56:42.378815 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.200:3049] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:56:58.586742 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.62:61196] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:56:58.636745 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.62:61197] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:57:42.382247 2018] [core:alert] [pid 4100:tid 924] [client 192.168.0.200:2826] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:58:42.448683 2018] [core:alert] [pid 4100:tid 904] [client 192.168.0.200:2859] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:59:09.895253 2018] [core:alert] [pid 4100:tid 964] [client 192.168.0.62:61248] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:59:47.382397 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.200:2892] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:59:53.264733 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.62:61268] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:59:53.264733 2018] [core:alert] [pid 4100:tid 964] [client 192.168.0.62:61270] C:/_majordomo/.htaccess: <IfModule not allowed here
[Sun Mar 04 23:59:53.314736 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.62:61269] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Sun Mar 04 23:59:58.618040 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.62:61279] C:/_majordomo/.htaccess: <IfModule not allowed here
[Mon Mar 05 00:00:04.946402 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.62:61281] C:/_majordomo/.htaccess: <IfModule not allowed here
[Mon Mar 05 00:00:04.946402 2018] [core:alert] [pid 4100:tid 964] [client 192.168.0.62:61282] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Mon Mar 05 00:00:05.009405 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.62:61283] C:/_majordomo/.htaccess: <IfModule not allowed here, referer: http://192.168.0.220/
[Mon Mar 05 00:00:09.104639 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.62:61290] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here
[Mon Mar 05 00:00:09.154642 2018] [core:alert] [pid 4100:tid 896] [client 192.168.0.62:61289] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here, referer: http://192.168.0.220/
[Mon Mar 05 00:00:13.365883 2018] [core:alert] [pid 4100:tid 896] [client ::1:49307] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here
[Mon Mar 05 00:00:13.906914 2018] [core:alert] [pid 4100:tid 896] [client ::1:49308] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:33.000006 2018] [core:alert] [pid 4100:tid 960] [client ::1:49317] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here
[Mon Mar 05 00:00:33.043009 2018] [core:alert] [pid 4100:tid 960] [client ::1:49318] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:33.611041 2018] [core:alert] [pid 4100:tid 960] [client ::1:49319] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here
[Mon Mar 05 00:00:33.649043 2018] [core:alert] [pid 4100:tid 960] [client ::1:49320] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:33.779051 2018] [core:alert] [pid 4100:tid 960] [client ::1:49325] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here
[Mon Mar 05 00:00:33.801052 2018] [core:alert] [pid 4100:tid 960] [client ::1:49326] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:35.023122 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.62:61294] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here
[Mon Mar 05 00:00:35.095126 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.62:61301] C:/_majordomo/.htaccess: AddDefaultCharset not allowed here, referer: http://192.168.0.220/
[Mon Mar 05 00:00:39.964405 2018] [core:alert] [pid 4100:tid 960] [client ::1:49327] C:/_majordomo/.htaccess: DirectoryIndex not allowed here
[Mon Mar 05 00:00:40.001407 2018] [core:alert] [pid 4100:tid 960] [client ::1:49328] C:/_majordomo/.htaccess: DirectoryIndex not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:40.454433 2018] [core:alert] [pid 4100:tid 960] [client ::1:49330] C:/_majordomo/.htaccess: DirectoryIndex not allowed here
[Mon Mar 05 00:00:40.472434 2018] [core:alert] [pid 4100:tid 960] [client ::1:49331] C:/_majordomo/.htaccess: DirectoryIndex not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:40.625442 2018] [core:alert] [pid 4100:tid 960] [client ::1:49332] C:/_majordomo/.htaccess: DirectoryIndex not allowed here
[Mon Mar 05 00:00:40.658444 2018] [core:alert] [pid 4100:tid 960] [client ::1:49334] C:/_majordomo/.htaccess: DirectoryIndex not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:40.760450 2018] [core:alert] [pid 4100:tid 960] [client ::1:49335] C:/_majordomo/.htaccess: DirectoryIndex not allowed here
[Mon Mar 05 00:00:40.789452 2018] [core:alert] [pid 4100:tid 960] [client ::1:49336] C:/_majordomo/.htaccess: DirectoryIndex not allowed here, referer: http://localhost/phpmyadmin4/index.php
[Mon Mar 05 00:00:42.591555 2018] [core:alert] [pid 4100:tid 960] [client 192.168.0.200:2925] C:/_majordomo/.htaccess: DirectoryIndex not allowed here
[Mon Mar 05 00:01:42.655990 2018] [core:alert] [pid 4100:tid 964] [client 192.168.0.200:2958] C:/_majordomo/.htaccess: <IfModule not allowed here
[Mon Mar 05 00:02:42.722426 2018] [core:alert] [pid 4100:tid 964] [client 192.168.0.200:2991] C:/_majordomo/.htaccess: <IfModule not allowed here
Ну, патч, он на то и патч, чтобы его поверх прокатывать ![Wink ;)](./images/smilies/icon_e_wink.gif)
Возьмите свежий инсталятор и поставьте из него, или скопируйте из свежей инсталяции папки в рабочую
Парни никто не мерял загрузку проца после патча?
1.Процессор на треть больше грузит а то и более, временами до 100%
2.Память, тут наоборот процентов на 30 меньше.
Процессор смотрю грузит апач в основном.
Система на Win7
Система на Win7
