Ron
Сообщение Ron »
Amarok писал(а):Это какой?
Amarok, микрофон этот
Сейчас даже цена на него упала.
Ребят...случилась бяда какая-то...
МД после включения начинает спамить сообщениями
[   70.345274] ---[ end trace 068e8de32bb05546 ]---
[   70.346022] ------------[ cut here ]------------
[   70.346040] WARNING: CPU: 0 PID: 435 at fs/f2fs/node.c:1159 __get_node_page.part.1+0x1e8/0x384
[   70.346044] Modules linked in: evdev bnep hci_uart btbcm bluetooth uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core snd_usb_audio videodev snd_hwdep media snd_usbmidi_lib snd_rawmidi snd_seq_device brcmfmac brcmutil cfg80211 rfkill snd_bcm2835 snd_pcm snd_timer snd bcm2835_gpiomem uio_pdrv_genirq fixed uio i2c_dev ip_tables x_tables ipv6
[   70.346167] CPU: 0 PID: 435 Comm: rs:main Q:Reg Tainted: G        W       4.9.59-v7+ #1047
[   70.346171] Hardware name: BCM2835
[   70.346189] [<8010fb3c>] (unwind_backtrace) from [<8010c058>] (show_stack+0x20/0x24)
[   70.346205] [<8010c058>] (show_stack) from [<80456764>] (dump_stack+0xd4/0x118)
[   70.346222] [<80456764>] (dump_stack) from [<8011d348>] (__warn+0xf8/0x110)
[   70.346234] [<8011d348>] (__warn) from [<8011d430>] (warn_slowpath_null+0x30/0x38)
[   70.346248] [<8011d430>] (warn_slowpath_null) from [<803ec264>] (__get_node_page.part.1+0x1e8/0x384)
[   70.346264] [<803ec264>] (__get_node_page.part.1) from [<803ec420>] (get_node_page.part.2+0x20/0x24)
[   70.346280] [<803ec420>] (get_node_page.part.2) from [<803ed5c4>] (get_node_page+0x28/0x2c)
[   70.346295] [<803ed5c4>] (get_node_page) from [<803e2c30>] (f2fs_gc+0x654/0xcb8)
[   70.346310] [<803e2c30>] (f2fs_gc) from [<803f2a1c>] (f2fs_balance_fs.part.0+0x13c/0x14c)
[   70.346326] [<803f2a1c>] (f2fs_balance_fs.part.0) from [<803f2a4c>] (f2fs_balance_fs+0x20/0x24)
[   70.346342] [<803f2a4c>] (f2fs_balance_fs) from [<803e606c>] (f2fs_write_begin+0x688/0xaec)
[   70.346357] [<803e606c>] (f2fs_write_begin) from [<8020caf0>] (generic_perform_write+0xd0/0x1c8)
[   70.346373] [<8020caf0>] (generic_perform_write) from [<8020dba4>] (__generic_file_write_iter+0x19c/0x1f8)
[   70.346389] [<8020dba4>] (__generic_file_write_iter) from [<803ca63c>] (f2fs_file_write_iter+0xf0/0x108)
[   70.346405] [<803ca63c>] (f2fs_file_write_iter) from [<8026fc98>] (__vfs_write+0xd0/0x128)
[   70.346419] [<8026fc98>] (__vfs_write) from [<80270b08>] (vfs_write+0xb4/0x1bc)
[   70.346438] [<80270b08>] (vfs_write) from [<80271c48>] (SyS_write+0x54/0xb0)
[   70.346454] [<80271c48>] (SyS_write) from [<801080c0>] (ret_fast_syscall+0x0/0x1c)
[   70.346460] ---[ end trace 068e8de32bb05547 ]---
[   70.347172] ------------[ cut here ]------------
[   70.347187] WARNING: CPU: 0 PID: 435 at fs/f2fs/node.c:1159 __get_node_page.part.1+0x1e8/0x384
[   70.347191] Modules linked in: evdev bnep hci_uart btbcm bluetooth uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core snd_usb_audio videodev snd_hwdep media snd_usbmidi_lib snd_rawmidi snd_seq_device brcmfmac brcmutil cfg80211 rfkill snd_bcm2835 snd_pcm snd_timer snd bcm2835_gpiomem uio_pdrv_genirq fixed uio i2c_dev ip_tables x_tables ipv6
[   70.347303] CPU: 0 PID: 435 Comm: rs:main Q:Reg Tainted: G        W       4.9.59-v7+ #1047
[   70.347307] Hardware name: BCM2835
[   70.347325] [<8010fb3c>] (unwind_backtrace) from [<8010c058>] (show_stack+0x20/0x24)
[   70.347339] [<8010c058>] (show_stack) from [<80456764>] (dump_stack+0xd4/0x118)
[   70.347353] [<80456764>] (dump_stack) from [<8011d348>] (__warn+0xf8/0x110)
[   70.347365] [<8011d348>] (__warn) from [<8011d430>] (warn_slowpath_null+0x30/0x38)
[   70.347379] [<8011d430>] (warn_slowpath_null) from [<803ec264>] (__get_node_page.part.1+0x1e8/0x384)
[   70.347395] [<803ec264>] (__get_node_page.part.1) from [<803ec420>] (get_node_page.part.2+0x20/0x24)
[   70.347410] [<803ec420>] (get_node_page.part.2) from [<803ed5c4>] (get_node_page+0x28/0x2c)
[   70.347424] [<803ed5c4>] (get_node_page) from [<803e2c30>] (f2fs_gc+0x654/0xcb8)
[   70.347439] [<803e2c30>] (f2fs_gc) from [<803f2a1c>] (f2fs_balance_fs.part.0+0x13c/0x14c)
[   70.347456] [<803f2a1c>] (f2fs_balance_fs.part.0) from [<803f2a4c>] (f2fs_balance_fs+0x20/0x24)
[   70.347471] [<803f2a4c>] (f2fs_balance_fs) from [<803e606c>] (f2fs_write_begin+0x688/0xaec)
[   70.347491] [<803e606c>] (f2fs_write_begin) from [<8020caf0>] (generic_perform_write+0xd0/0x1c8)
[   70.347507] [<8020caf0>] (generic_perform_write) from [<8020dba4>] (__generic_file_write_iter+0x19c/0x1f8)
[   70.347523] [<8020dba4>] (__generic_file_write_iter) from [<803ca63c>] (f2fs_file_write_iter+0xf0/0x108)
[   70.347537] [<803ca63c>] (f2fs_file_write_iter) from [<8026fc98>] (__vfs_write+0xd0/0x128)
[   70.347551] [<8026fc98>] (__vfs_write) from [<80270b08>] (vfs_write+0xb4/0x1bc)
[   70.347565] [<80270b08>] (vfs_write) from [<80271c48>] (SyS_write+0x54/0xb0)
[   70.347579] [<80271c48>] (SyS_write) from [<801080c0>] (ret_fast_syscall+0x0/0x1c)
[   70.347585] ---[ end trace 068e8de32bb05548 ]---
При чем на столько засирает - что вебморда даже не грузится...как стартанёт - норм загрузится...как этот спам начинается - всё виснет.
Не пойму что это значит, но по ходу как-то замешана f2fs...что делать? Не уж то образ придётся снова накатывать? Я уже слишком стар для этого)) и у меня этот образ на столько хорошо отлажен =( жалко...
Ни у кого такого не было? Помогите плс.
eygen
Сообщение eygen »
nick7zmail писал(а):Ребят...случилась бяда какая-то...
Флешка поди сбоить начала?
Врят ли...если флехи умирают то полностью, как правило. У меня ни одной битой таблички, ни одного (змеченного) убитого файлика.
Ещё варианты? Ниохота всё заново накатывать на новый образ =(
помимо бэкапов,образ флешки с настройками ос создавать периодически
а что тут еще можно?
Не, ну мож кто именно с этой проблемой встречался и исправлял.. Ибо место на флеха есть, флеха не битая...образ если делать - скорее всего с этими же ошибками забэкапится.
Ron
Сообщение Ron »
Пару раз налетал на такую фигню. Но если быть честным, то логи не разбирал ,т.е. причину. Понял, что по циклам чго то там падало, да и БД жрала ресурс, по быстродействию скуель чего-то там не справлялся. Понасоздал кучу побитых таблиц для восстановления.
Ну короче раза 4-5 грубым ребутом (по питанию в off) и репаром в БД таблиц лечил.
По циклам ничего не падает, база тоже целая...подозрение на битую фс...именно на фс а не на битую флеху...вчера поставил убунту нормальную на комп (давно хотел, руки не доходили)...вечером попробую заархивировать систему, форматнуть флеху и снова залить туда.
Ron
Сообщение Ron »
Ну можно и так конечно, но можно и сделать USB флешку загрузочной, оттуда запуститься и прогнать fsck SD-шки.
Тогда узнаешь реально о файловой системе.
В последний раз, когда так делал - потерял данные...
Но там реально хард битый был....но данные на нём видны были и читались...после попытки fsck, и попыток восстановления ей секторов - хард вообще перестал монтироваться любыми способами...обидно короче было...повторов не хотелось бы =(
