поставил Armbian_5.35_Orangepizero_Ubuntu_xenial_default_3.4.113,все работает но через минут 40 зайти уже на Majordomotuz-vetal писал(а):сейчас качну что то и отпишусь!
не возможно а так же по ssh,помогает только перезагрузка Orange Pi Zero.
apt-cache search php7
php-all-dev - package depending on all supported PHP development packages
php7.0 - server-side, HTML-embedded scripting language (metapackage)
php7.0-cgi - server-side, HTML-embedded scripting language (CGI binary)
php7.0-cli - command-line interpreter for the PHP scripting language
php7.0-common - documentation, examples and common module for PHP
php7.0-curl - CURL module for PHP
php7.0-dev - Files for PHP7.0 module development
php7.0-gd - GD module for PHP
php7.0-gmp - GMP module for PHP
php7.0-json - JSON module for PHP
php7.0-ldap - LDAP module for PHP
php7.0-mysql - MySQL module for PHP
php7.0-odbc - ODBC module for PHP
php7.0-opcache - Zend OpCache module for PHP
php7.0-pgsql - PostgreSQL module for PHP
php7.0-pspell - pspell module for PHP
php7.0-readline - readline module for PHP
php7.0-recode - recode module for PHP
php7.0-snmp - SNMP module for PHP
php7.0-sqlite3 - SQLite3 module for PHP
php7.0-tidy - tidy module for PHP
php7.0-xml - DOM, SimpleXML, WDDX, XML, and XSL module for PHP
php7.0-xmlrpc - XMLRPC-EPI module for PHP
libphp7.0-embed - HTML-embedded scripting language (Embedded SAPI library)
php7.0-bcmath - Bcmath module for PHP
php7.0-bz2 - bzip2 module for PHP
php7.0-enchant - Enchant module for PHP
php7.0-fpm - server-side, HTML-embedded scripting language (FPM-CGI binary)
php7.0-imap - IMAP module for PHP
php7.0-interbase - Interbase module for PHP
php7.0-intl - Internationalisation module for PHP
php7.0-mbstring - MBSTRING module for PHP
php7.0-mcrypt - libmcrypt module for PHP
php7.0-phpdbg - server-side, HTML-embedded scripting language (PHPDBG binary)
php7.0-soap - SOAP module for PHP
php7.0-sybase - Sybase module for PHP
php7.0-xsl - XSL module for PHP (dummy)
php7.0-zip - Zip module for PHP
php7.0-dba - DBA module for PHP
phing - PHP5 project build system based on Apache Ant
php-auth - Creating an authentication system
php-doc - Documentation for PHP5
php-http-request2 - Provides an easy way to perform HTTP requests
php-letodms-lucene - Document management system - Fulltext search
php-memcache - memcache extension module for PHP5
php-memcached - memcached extension module for PHP5, uses libmemcached
php-net-dns2 - PHP5 Resolver library used to communicate with a DNS server
phpunit - Unit testing suite for PHP5
doxygen - Documentation system for C, C++, Java, Python and other languages
doxygen-dbg - Debug symbols for doxygen
doxygen-doc - Documentation for doxygen
exuberant-ctags - build tag file indexes of source code definitions
gir1.2-isocodes-1.2 - access of iso-codes data and translations - GObject introspection
ibus-table-yong - ibus-table input method: YongMa
libapache2-mod-php - server-side, HTML-embedded scripting language (Apache 2 module) (default)
libapache2-mod-php7.0 - server-side, HTML-embedded scripting language (Apache 2 module)
libct4 - libraries for connecting to MS SQL and Sybase SQL servers
libcups2-dev - Common UNIX Printing System(tm) - Development files CUPS library
libgtksourceview-3.0-common - common files for the GTK+ syntax highlighting widget
libisocodes-dev - access of iso-codes data and translations - development files
libisocodes1 - access of iso-codes data and translations
libmdb2 - Core library for accessing JET / MS Access (MDB) files
libnet-libidn-perl - Perl bindings for GNU Libidn
php - server-side, HTML-embedded scripting language (default)
php-cgi - server-side, HTML-embedded scripting language (CGI binary) (default)
php-cli - command-line interpreter for the PHP scripting language (default)
php-common - Common files for PHP packages
php-curl - CURL module for PHP [default]
php-dev - Files for PHP module development (default)
php-gd - GD module for PHP [default]
php-gmp - GMP module for PHP [default]
php-ldap - LDAP module for PHP [default]
php-mysql - MySQL module for PHP [default]
php-odbc - ODBC module for PHP [default]
php-pear - PEAR Base System
php-pgsql - PostgreSQL module for PHP [default]
php-pspell - pspell module for PHP [default]
php-recode - recode module for PHP [default]
php-snmp - SNMP module for PHP [default]
php-sqlite3 - SQLite3 module for PHP [default]
php-tidy - tidy module for PHP [default]
php-xmlrpc - XMLRPC-EPI module for PHP [default]
pkg-php-tools - various packaging tools and scripts for PHP packages
adminer - Web-based database administration tool
air-quality-sensor - user space driver for AppliedSensor's Indoor Air Monitor
ampache - web-based audio file management system
ampache-common - web-based audio file management system common files
ampache-themes - Themes for Ampache
aolserver4-doc - AOL web server version 4 - documentation
apertium - Shallow-transfer machine translation engine
bandwidthd - Tracks usage of TCP/IP and builds html files with graphs
bandwidthd-pgsql - Tracks usage of TCP/IP and builds html files with graphs
bluefish - advanced Gtk+ text editor for web and software development
cacti - web interface for graphing of monitoring systems
cacti-spine - Multi-Threading poller for cacti
cakephp - rapid application development framework for PHP
cakephp-scripts - rapid application development framework for PHP (scripts)
chameleon-cursor-theme - modern but not gaudy X11 mouse theme
codelite - Powerful and lightweight IDE
codelite-plugins - Powerful and lightweight IDE - plugins
coderay - Helper programs for CodeRay Ruby lib for syntax highlighting
coffeescript - interpreter and compiler for the CoffeeScript language
composer - dependency manager for PHP
davical - PHP CalDAV and CardDAV Server
davical-doc - PHP CalDAV and CardDAV Server - technical documentation
debpear - automatically builds and installs PEAR package as Debian packages
dh-linktree - Create symlink trees within a Debian package
dia2code - a dia-UML code generator
direnv - Utility to set directory specific environment variables
doxygen-gui - GUI configuration tool for doxygen
doxygen-latex - Documentation system for C, C++, Java, Python and other languages
drush - command line shell and Unix scripting interface for Drupal
dynalogin-client-php - two-factor HOTP/TOTP authentication - PHP client
empty-expect - Run processes and applications under pseudo-terminal
erlang-cowboy - Cowboy is a small, fast and modular HTTP server written in Erlang
erlang-cowboy-doc - Documentation files for erlang-cowboy
erlang-cowboy-examples - Examples for erlang-cowboy
freeplane - Java program for working with Mind Maps
fusiondirectory-smarty3-acl-render - Provide FusionDirectory ACL based rendering for Smarty3
gambas3-gb-clipper - Gambas Clipper component
ganglia-webfrontend - cluster monitoring toolkit - web front-end
geany - fast and lightweight IDE
geany-common - fast and lightweight IDE -- common files
gosa-plugin-phpgw - phpgw plugin for GOsa²
gosa-plugin-phpgw-schema - LDAP schema for GOsa² phpgw plugin
gosa-plugin-phpscheduleit - phpscheduleit plugin for GOsa²
gosa-plugin-phpscheduleit-schema - LDAP schema for GOsa² phpscheduleit plugin
gphpedit - development environment for PHP/HTML/CSS
grub-imageboot - boot iso, harddisk and floppy images with grub2 and syslinux memdisk
gtk-clearlooks-gperfection2-theme - gtk theme for the clearlooks engine
haserl - CGI scripting program for embedded environments
htcheck-php - Simple php interface to database generated by ht://Check
ir.lv2 - LV2 IR reverb
irssi-scripts - collection of scripts for irssi
jclicmoodle - JClic module for Moodle
jed - editor for programmers (textmode version)
jffnms - PHP Network Management System
jkmeter - horizontal or vertical bargraph audio level meter for Jack Audio Connection Kit
jsonlint - validating parser of JSON data structures
kdevelop-php - PHP plugin for KDevelop
kdevelop-php-dbg - debugging symbols for the KDevelop PHP plugin
kdevelop-php-docs - PHP documentation plugin for KDevelop
kdevelop-php-docs-l10n - localization files for KDevelop PHP documentation plugin
kdevelop-php-l10n - localization files for KDevelop PHP plugin
klone - embedded web application development framework
letodms - document management system based on PHP and MySQL
letodms-webdav - document management system based on PHP and MySQL - WebDAV server
libapache2-mod-auth-memcookie - Apache2 authentication and authorization module.
libapache2-mod-auth-tkt - lightweight single-sign-on authentication module for Apache
libapache2-mod-authn-yubikey - Yubikey authentication provider for Apache
libapache2-mod-watchcat - Process monitoring Apache module
libapache2-mod-xsendfile - Serve large static files efficiently from web applications
libarc-php - Flexible RDF system for semantic web and PHP practitioners
libawl-php - Andrew's Web Libraries - PHP Utility Libraries
libcgi-session-serialize-yaml-perl - YAML and YAML::Syck support for CGI::Session's serializers
libcgi-struct-xs-perl - Perl module to build structures from CGI data, XS version
libcode-tidyall-perl - your all-in-one code tidier and validator
libfpdf-tpl-php - PHP library to use PDF templates with FPDF
libfpdi-php - PHP library for importing existing PDF documents into FPDF
libghc-highlighting-kate-dev - syntax highlighting library based on Kate syntax descriptions
libghc-highlighting-kate-doc - library documentation for highlighting-kate; documentation
libghc-highlighting-kate-prof - highlighting-kate library with profiling enabled; profiling libraries
libgraphite-php - PHP Linked Data Library
libgtksourceview2.0-common - common files for the GTK+ syntax highlighting widget
libhtml-defang-perl - cleans HTML and CSS of scripting, executable contents and XSS attacks
libhtml-wikiconverter-phpwiki-perl - HTML to wiki markup converter - PhpWiki dialect
libjs-edit-area - a free javascript editor for source code
libjs-jquery-jush - jQuery Syntax Highlighter
libmarkdown-php - PHP library for rendering Markdown data
libming-dev - Library to generate SWF (Flash) Files (development files)
libming-util - Library to generate SWF (Flash) Files - Utilities
libming1 - Library to generate SWF (Flash) Files
libnusoap-php - SOAP toolkit for PHP
libphp-adodb - ADOdb is a PHP database abstraction layer library
libphp-embed - HTML-embedded scripting language (Embedded SAPI library) (default)
libphp-jabber - Object-oriented PHP interface for the Jabber/XMPP protocol
libphp-magpierss - provides an XML-based RSS parser in PHP
libphp-pclzip - transitional dummy package
libphp-phpmailer - full featured email transfer class for PHP
libphp-predis - Flexible and feature-complete PHP client library for the Redis key-value store
libphp-serialization-perl - Perl module to manipulate serialized PHP data structures
libphp-simplepie - RSS and Atom feed parsing in PHP
libphp-snoopy - Snoopy is a PHP class that simulates a web browser
libphp-swiftmailer - transitional dummy package
libphutil - Shared library for Arcanist and Phabricator
librinci-perl - module that provides a language-neutral metadata for your code
libsmokeakonadi3 - Akonadi SMOKE library
libsmokeattica3 - Attica SMOKE library
libsmokebase3v5 - SMOKE base library
libsmokekde-dev - KDE SMOKE libraries -- development files
libsmokekde4-dbg - KDE SMOKE libraries -- debug symbols
libsmokekdecore4-3 - KDE Core SMOKE libraries
libsmokekdeui4-3 - KDE Ui SMOKE libraries
libsmokekfile3 - KFile SMOKE library
libsmokekhtml3 - KHTML SMOKE library
libsmokekio3 - KIO SMOKE library
libsmokeknewstuff2-3 - KNewStuff2 SMOKE library
libsmokeknewstuff3-3 - KNewStuff3 SMOKE library
libsmokekparts3 - KParts SMOKE libraries
libsmokektexteditor3 - KTextEditor SMOKE libraries
libsmokekutils3 - KUtils SMOKE libraries
libsmokeokular3 - Okular SMOKE bindings
libsmokephonon3 - Qt Phonon SMOKE library
libsmokeplasma3 - Plasma SMOKE library
libsmokeqimageblitz3 - QImageBlitz SMOKE libraries
libsmokeqsci3 - QScintilla2 SMOKE library
libsmokeqt3support4-3 - Qt3 Support SMOKE library
libsmokeqt4-dbg - Qt SMOKE libraries debug symbols
libsmokeqt4-dev - Development files for Qt SMOKE libraries
libsmokeqtcore4-3 - Qt Core SMOKE library
libsmokeqtdbus4-3 - Qt D-Bus SMOKE library
libsmokeqtdeclarative4-3 - Qt Declarative SMOKE library
libsmokeqtgui4-3 - Qt Gui SMOKE library
libsmokeqthelp4-3 - Qt Help SMOKE library
libsmokeqtnetwork4-3 - Qt Network SMOKE library
libsmokeqtopengl4-3 - Qt OpenGL SMOKE library
libsmokeqtscript4-3 - Qt Script SMOKE library
libsmokeqtsql4-3 - Qt Sql SMOKE library
libsmokeqtsvg4-3 - Qt Svg SMOKE library
libsmokeqttest4-3 - Qt Test SMOKE library
libsmokeqtuitools4-3 - Qt Ui Tools SMOKE library
libsmokeqtxml4-3 - Qt Xml SMOKE library
libsmokeqtxmlpatterns4-3 - Qt XmlPatterns SMOKE library
libsmokesolid3 - Solid SMOKE libraries
libsparkline-php - sparkline graphing library for php
libstring-koremutake-perl - Convert to/from Koremutake Memorable Random Strings
libswe-doc - documentation for the libswe package
libswf-perl - Ming (SWF) module for Perl
libtext-mediawikiformat-perl - module that converts Mediawiki markup into other text formats
libtntnet-dev - Tntnet library development headers
libtntnet12v5 - Tntnet libraries
libwcat1 - Process monitoring library
libwcat1-dev - Process monitoring library
libwebinject-perl - Perl Module for testing web services
libwulf-dev - development environment for wulfware
libwulf2 - shared libraries for running wulfware programs
libwww-facebook-api-perl - Facebook API implementation
libykclient-dev - Yubikey client library development files
libykclient3 - Yubikey client library runtime
libzend-framework-php - a simple, straightforward, open-source software framework for PHP 5
libzend-framework-zendx-php - a simple, straightforward, open-source software framework for PHP 5
llgal - Command-line online gallery generator
ltsp-cluster-control - Web based thin-client configuration management
ming-fonts-dejavu - Ming format DejaVue Fonts
ming-fonts-opensymbol - Ming format Opensymbol Fonts
mlmmj-php-web - web interface for mlmmj, written in php
mlmmj-php-web-admin - administrative web interface for mlmmj, written in php
modsecurity-crs - modsecurity's Core Rule Set
mrename - A tool for easy and automatic renaming of many files
musica - web application for browsing and listening to your music
nagios-plugins-contrib - Plugins for nagios compatible monitoring systems
navit - Car navigation system with routing engine
netbeans - Extensible Java IDE
nzb - Usenet binary grabber
nzbget - command-line based binary newsgrabber for nzb files
papercut - simple and extensible NNTP server
parrot - virtual machine for dynamic languages
pdepend - design quality metrics for PHP packages
pear-channels - PEAR channels for various projects
pgtap - Unit testing framework for PostgreSQL
pgtap-doc - Unit testing framework for PostgreSQL
phamm - PHP front-end to manage virtual services on LDAP - main package
phamm-ldap - PHP front-end to manage virtual services on LDAP - back-end files
phamm-ldap-amavis - PHP front-end to manage virtual services on LDAP - back-end files
phamm-ldap-vacation - PHP front-end to manage virtual services on LDAP - back-end files
php-amqp - AMQP extension for PHP
php-amqplib - pure PHP implementation of the AMQP protocol
php-analog - PHP micro logging package
php-apcu - APC User Cache for PHP
php-apigen - PHP source code API generator
php-apigen-theme-bootstrap - Twitter Bootstrap theme for ApiGen
php-apigen-theme-default - Default theme for ApiGen
php-assetic - Asset Management for PHP
php-ast - AST extension for PHP 7
php-auth-http - HTTP authentication
php-auth-sasl - Abstraction of various SASL mechanism responses
php-aws-sdk - software development kit to build solutions for Amazon
php-bcmath - Bcmath module for PHP [default]
php-bz2 - bzip2 module for PHP [default]
php-cache - framework for caching of arbitrary data
php-cache-lite - Fast and Safe little cache system
php-cas - Central Authentication Service client library in php
php-cli-prompt - tiny helper prompting for user input
php-codecoverage - collection, processing, and rendering for code coverage
php-codesniffer - PHP, CSS and JavaScript coding standard analyzer and checker
php-compat - Provides components to achieve PHP version independence
php-composer-semver - Semver library that offers utilities, version constraint parsing and
php-composer-spdx-licenses - SPDX licenses list and validation library
php-console-commandline - A full featured command line options and arguments parser
php-console-table - Library that makes it easy to build console style tables
php-crypt-blowfish - Allows for quick two-way blowfish encryption without requiring the MCrypt PHP extension
php-crypt-cbc - PEAR class to emulate Perl's Crypt::CBC module
php-crypt-chap - Generating CHAP packets
php-crypt-gpg - PHP PEAR module for encrypting and decrypting with GnuPG
php-cssmin - CSS minification class
php-date - Generic date/time handling class for PEAR
php-db - PHP PEAR Database Abstraction Layer
php-deepcopy - create deep copies (clones) of objects
php-directory-scanner - recursive directory scanner and filter
php-doctrine-annotations - Docblock Annotations Parser - Doctrine component
php-doctrine-bundle - bundle library - Doctrine component
php-doctrine-cache - cache library - Doctrine component
php-doctrine-cache-bundle - cache bundle library - Doctrine component
php-doctrine-collections - Collections Abstraction library - Doctrine component
php-doctrine-common - common extensions for Doctrine
php-doctrine-data-fixtures - Data Fixtures for all Doctrine Object Managers
php-doctrine-dbal - database abstraction layer for Doctrine
php-doctrine-inflector - string manipulations library - Doctrine component
php-doctrine-instantiator - lightweight utility to instantiate objects in PHP
php-doctrine-lexer - base lexer library - Doctrine component
php-doctrine-orm - tool for object-relational mapping
php-dompdf - HTML to PDF converter
php-dropbox - Dropbox API library
php-elisp - Emacs support for php files
php-email-validator - A library for validating emails
php-enchant - Enchant module for PHP [default]
php-fdomdocument - extension to PHP's standard DOM
php-file-iterator - FilterIterator implementation for PHP
php-finder-facade - convenience wrapper for Symfony's Finder component
php-finder-facade-doc - convenience wrapper for Symfony's Finder component - documentation
php-font-lib - read, parse, export and make subsets of different fonts
php-fpdf - PHP class to generate PDF files
php-fpm - server-side, HTML-embedded scripting language (FPM-CGI binary) (default)
php-fshl - Fast Syntax HighLighter
php-fxsl - XSL wrapper and extension to XSLTProcessor
php-geoip - GeoIP module for PHP
php-geshi - Generic Syntax Highlighter
php-getid3 - scripts to extract information from multimedia files
php-gettext - read gettext MO files directly, without requiring anything other than PHP
php-gnupg - wrapper around the gpgme library
php-google-api-php-client - Google APIs client library for PHP
php-google-auth - Google Auth Library for PHP
php-guzzle-stream - implementation of the proposed PSR-7 stream interface
php-guzzlehttp - object-oriented PHP HTTP client
php-guzzlehttp-promises - Guzzle promises library
php-guzzlehttp-psr7 - PSR-7 message implementation
php-guzzlehttp-ringphp - Ring adapter and handler system for Guzzle
php-guzzlehttp-ringphp-doc - Ring adapter and handler system for Guzzle - documentation
php-hamcrest - This is the PHP port of Hamcrest Matchers
php-horde - Horde Application Framework
php-horde-activesync - Horde ActiveSync Server Library
php-horde-alarm - Horde Alarm Libraries
php-horde-ansel - Photo management application
php-horde-argv - Horde command-line argument parsing package
php-horde-auth - Horde Authentication API
php-horde-autoloader - Horde Autoloader
php-horde-browser - Horde Browser API
php-horde-cache - Horde Caching API
php-horde-cli - Horde Command Line Interface API
php-horde-compress - Horde Compression API
php-horde-compress-fast - Fast Compression Library
php-horde-constraint - Horde Constraint library
php-horde-content - Tagging application
php-horde-controller - Horde Controller libraries
php-horde-core - Horde Core Framework libraries
php-horde-crypt - Horde Cryptography API
php-horde-crypt-blowfish - Blowfish Encryption Library
php-horde-css-parser - Horde CSS Parser
php-horde-cssminify - CSS Minification
php-horde-data - Horde Data API
php-horde-date - Horde Date package
php-horde-date-parser - Horde Date Parser
php-horde-dav - Horde library for WebDAV, CalDAV, CardDAV
php-horde-db - Horde Database Libraries
php-horde-editor - Horde Editor API
php-horde-elasticsearch - Horde ElasticSearch client
php-horde-exception - Horde Exception Handler
php-horde-feed - Horde Feed libraries
php-horde-form - Horde Form API
php-horde-gollem - Web-based file manager
php-horde-group - Horde User Groups System
php-horde-groupware - Horde Groupware
php-horde-hashtable - Horde Hash Table Interface
php-horde-history - API for tracking the history of an object
php-horde-http - Horde HTTP libraries
php-horde-icalendar - iCalendar API
php-horde-idna - IDNA backend normalization package
php-horde-image - Horde Image API
php-horde-imap-client - Horde IMAP Client
php-horde-imp - A web based webmail system
php-horde-imsp - IMSP API
php-horde-ingo - An email filter rules manager
php-horde-injector - Horde dependency injection container
php-horde-itip - iTip invitation response handling
php-horde-javascriptminify - Javascript Minification
php-horde-kolab-format - A package for reading/writing Kolab data formats
php-horde-kolab-server - A package for manipulating the Kolab user database
php-horde-kolab-session - A package managing an active Kolab session
php-horde-kolab-storage - A package for handling Kolab data stored on an IMAP server
php-horde-kronolith - A web based calendar
php-horde-ldap - Horde LDAP libraries
php-horde-listheaders - Horde List Headers Parsing Library
php-horde-lock - Horde Resource Locking System
php-horde-log - Horde Logging library
php-horde-logintasks - Horde Login Tasks System
php-horde-lz4 - Horde LZ4 Compression Extension
php-horde-mail - Horde Mail Library
php-horde-mail-autoconfig - Horde Mail Autoconfiguration
php-horde-mapi - MAPI utility library
php-horde-memcache - Horde Memcache API
php-horde-mime - Horde MIME Library
php-horde-mime-viewer - Horde MIME Viewer Library
php-horde-mnemo - A web based notes manager
php-horde-nag - A web based task list manager
php-horde-nls - Native Language Support (NLS)
php-horde-notification - Horde Notification System
php-horde-oauth - Horde OAuth client/server
php-horde-openxchange - Open-Xchange Connector
php-horde-pack - Horde Pack Utility
php-horde-passwd - Horde password changing application
php-horde-pdf - Horde PDF library
php-horde-perms - Horde Permissions System
php-horde-prefs - Horde Preferences API
php-horde-queue - Horde Queue
php-horde-rdo - Rampage Data Objects
php-horde-role - PEAR installer role used to install Horde components
php-horde-routes - Horde Routes URL mapping system
php-horde-rpc - Horde RPC API
php-horde-scheduler - Horde Scheduler System
php-horde-scribe - Scribe
php-horde-secret - Secret Encryption API
php-horde-serialize - Data Encapulation API
php-horde-service-facebook - Horde Facebook client
php-horde-service-gravatar - API accessor for gravatar.com
php-horde-service-twitter - Horde Twitter client
php-horde-service-urlshortener - Horde_Service_UrlShortener Class
php-horde-service-weather - Horde Weather Provider
php-horde-sesha - A simple Inventory App for Horde
php-horde-sessionhandler - Horde Session Handler API
php-horde-share - Horde Shared Permissions System
php-horde-smtp - Horde SMTP Client
php-horde-socket-client - Horde Socket Client
php-horde-spellchecker - Spellcheck API
php-horde-stream - Horde stream handler
php-horde-stream-filter - Horde Stream filters
php-horde-stream-wrapper - Horde Stream wrappers
php-horde-support - Horde support package
php-horde-syncml - Horde_SyncMl provides an API for processing SyncML requests
php-horde-template - Horde Template System
php-horde-test - Horde testing base classes
php-horde-text-diff - Engine for performing and rendering text diffs
php-horde-text-filter - Horde Text Filter API
php-horde-text-flowed - Horde API for flowed text as per RFC 3676
php-horde-thrift - Thrift
php-horde-timeobjects - Horde timeobjects application
php-horde-timezone - Timezone library
php-horde-token - Horde Token API
php-horde-translation - Horde translation library
php-horde-trean - Web-based bookmarks application
php-horde-tree - Horde Tree API
php-horde-turba - A web based address book
php-horde-url - Horde Url class
php-horde-util - Horde Utility Libraries
php-horde-vfs - Virtual File System API
php-horde-view - Horde View API
php-horde-webmail - Horde Groupware Webmail Edition
php-horde-whups - Ticket-tracking application
php-horde-wicked - Wiki application
php-horde-xml-element - Horde Xml Element object
php-horde-xml-wbxml - Horde_Xml_Wbxml provides an API for encoding and decoding WBXML documents used in SyncML and other wireless applications
php-html-safe - strip down all potentially dangerous content within HTML
php-htmlawed - htmLawed PHP code to purify & filter HTML
php-htmlpurifier - Standards-compliant HTML filter
php-http - PHP PEAR module for HTTP related stuff
php-http-request - PEAR class to provide an easy way to perform HTTP requests
php-http-webdav-server - WebDAV Server Baseclass
php-icinga - PHP library to communicate with and use Icinga
php-igbinary - igbinary PHP serializer
php-image-text - Image_Text - Advanced text maipulations in images
php-imagick - Provides a wrapper to the ImageMagick library
php-imap - IMAP module for PHP [default]
php-interbase - Interbase module for PHP [default]
php-intl - Internationalisation module for PHP [default]
php-invoker - Utility class for invoking callables with a timeout
php-irods-prods - PHP client API for iRODS
php-jmespath - Declaratively specify how to extract elements from a JSON document
php-json - JSON module for PHP [default]
php-json-patch - Produce and apply json-patch objects
php-json-schema - implementation of JSON schema
php-jwt - encode and decode JSON Web Tokens (JWT)
php-kdyby-events - Events for Nette Framework
php-kit-pathjoin - Cross-platform library for normalizing and joining file system paths
php-league-flysystem - filesystem abstraction offering one API to many filesystems
php-letodms-core - Document management system - Core files
php-libvirt-php - libvirt bindings for PHP
php-log - Logging Framework
php-mail - Class that provides multiple interfaces for sending emails
php-mail-mbox - Read and modify Unix MBOXes
php-mail-mime - PHP PEAR module for creating MIME messages
php-mail-mimedecode - Provides a class to decode mime messages
php-markdown - PHP library for rendering Markdown data
php-mbstring - MBSTRING module for PHP [default]
php-mcrypt - libmcrypt module for PHP [default]
php-mdb2 - merge of the PEAR DB and Metabase php database abstraction layers
php-mdb2-driver-mysql - PHP PEAR module to provide a MySQL driver for MDB2
php-mdb2-driver-pgsql - PHP PEAR module to provide a PostgreSQL driver for MDB2
php-mf2 - Microformats2 is the simplest way to markup structured information in HTML
php-mime-type - Utility class for dealing with MIME types
php-mockery - mock object framework for PHPUnit and other testing framework
php-mockery-doc - mock object framework for PHPUnit - documentation
php-mongodb - MongoDB driver for PHP
php-monolog - send logs to various destination and web services
php-msgpack - PHP extension for interfacing with MessagePack
php-net-dime - class that implements DIME encoding
php-net-ftp - provides an OO interface to the PHP FTP functions
php-net-imap - Provides an implementation of the IMAP protocol
php-net-ipv4 - IPv4 network calculations and validation
php-net-ipv6 - Check and validate IPv6 addresses
php-net-ldap - OO interface for searching and manipulating LDAP-entries
php-net-ldap2 - Object oriented interface for searching and manipulating LDAP-entries
php-net-ldap3 - Object oriented interface for searching and manipulating LDAP entries
php-net-nntp - PHP Pear module for NNTP
php-net-publicsuffix - PHP module for detecting registered domains and public suffixes
php-net-sieve - Handles talking to a sieve server
php-net-smartirc - provides an OO interface to the PHP IRC functions
php-net-smtp - PHP PEAR module implementing SMTP protocol
php-net-socket - PHP PEAR Network Socket Interface module
php-net-url - easy parsing of Urls
php-net-url2 - Class for parsing and handling URL
php-net-whois - PHP PEAR module for querying whois services
php-nette - Nette Framework
php-nrk-predis - Flexible and feature-complete PHP client library for the Redis key-value store
php-numbers-words - PEAR module providing methods for spelling numerals in words
php-oauth - OAuth 1.0 consumer and provider extension
php-openid - PHP OpenID library
php-pager - Pages an array of data, creating links to previous and next pages
php-parser - convert PHP code into abstract syntax tree
php-patchwork-utf8 - UTF-8 strings handling for PHP
php-pclzip - ZIP archive manager class for PHP
php-pdfparser - PHP library to parse PDF files and extract elements like text
php-pecl-http - pecl_http module for PHP 5 Extended HTTP Support
php-pecl-http-dev - pecl_http module for PHP 5 Extended HTTP Support development headers
php-phpdbg - server-side, HTML-embedded scripting language (PHPDBG binary) (default)
php-phpdocumentor-reflection - Reflection library to do Static Analysis for PHP Projects
php-phpdocumentor-reflection-common - Common reflection classes - phpDocumentor component
php-phpdocumentor-reflection-docblock - DocBlock parser - phpDocumentor component
php-phpdocumentor-type-resolver - TypeResolver and FqsenResolver - phpDocumentor component
php-phpseclib - implementations of an arbitrary-precision integer arithmetic library
php-phpspec-prophecy - object mocking framework - phpspec component
php-picofeed - Modern library to handle RSS/Atom feeds
php-pimple - simple dependency injection container
php-propro - propro module for PHP
php-propro-dev - propro module for PHP development headers
php-proxy-manager - library providing utilities to operate with Object Proxies
php-psr-cache - Common interface for caching libraries
php-psr-http-message - Common interface for HTTP messages
php-psr-log - common interface for logging libraries
php-punic - PHP-Unicode CLDR toolkit
php-radius - Radius client library
php-random-compat - PHP 5.x polyfill for random_bytes() and random_int() from PHP 7
php-raphf - raphf module for PHP
php-raphf-dev - raphf module for PHP development headers
php-react-promise - lightweight implementation of CommonJS Promises/A for PHP
php-readline - readline module for PHP [default]
php-redis - PHP extension for interfacing with Redis
php-rrd - PHP bindings to rrd tool system
php-sabre-dav - WebDAV Framework for PHP
php-sabre-dav-2.1 - WebDAV Framework for PHP
php-sabre-event - lightweight library for event-based development
php-sabre-http - library to ease the work with HTTP protocol
php-sabre-http-3 - library to ease the work with HTTP protocol
php-sabre-uri - several functions for working with URIs
php-sabre-vobject - library to parse and manipulate iCalendar and vCard objects
php-sabre-vobject-3 - library to parse and manipulate iCalendar and vCard objects
php-sabre-xml - specialized XML reader and writer
php-seclib - implementations of an arbitrary-precision integer arithmetic library
php-securitylib - base set of security libraries
php-sepa-direct-debit - Create Sepa Direct Debit XML Files in PHP
php-services-json - PHP implementaion of json_encode/decode
php-services-weather - This class acts as an interface to various online weather-services
php-smb - php wrapper for smbclient and libsmbclient-php
php-smbclient - PHP wrapper for libsmbclient
php-soap - SOAP module for PHP [default]
php-solr - PHP extension for communicating with Apache Solr server
php-sql-formatter - a PHP SQL highlighting library
php-ssh2 - Bindings for the libssh2 library
php-stomp - Streaming Text Oriented Messaging Protocol (STOMP) client module for PHP
php-streams - A set of generic stream wrappers
php-superclosure - Serialize Closure objects, including their context and binding
php-swiftmailer - Swiftmailer, free feature-rich PHP mailer
php-sybase - Sybase module for PHP [default]
php-symfony-asset - manage asset URLs
php-symfony-browser-kit - simulate the behavior of a web browser
php-symfony-class-loader - load PHP classes automatically
php-symfony-config - load configurations from different data sources
php-symfony-console - run tasks from the command line
php-symfony-css-selector - convert CSS selectors to XPath expressions
php-symfony-debug - tools to make debugging of PHP code easier
php-symfony-debug-bundle - debugging tools for the Symfony framework
php-symfony-dependency-injection - standardize and centralize construction of objects
php-symfony-doctrine-bridge - integration for Doctrine with Symfony Components
php-symfony-dom-crawler - ease DOM navigation for HTML and XML documents
php-symfony-event-dispatcher - dispatch events and listen to them
php-symfony-expression-language - compile and evaluate expressions
php-symfony-filesystem - basic filesystem utilities
php-symfony-finder - find files and directories
php-symfony-form - create HTML forms and process request data
php-symfony-framework-bundle - basic, robust and flexible MVC framework
php-symfony-http-foundation - object-oriented layer for the HTTP specification
php-symfony-http-kernel - building blocks for flexible and fast HTTP-based frameworks
php-symfony-intl - limited replacement layer for the PHP extension intl
php-symfony-locale - deprecated replacement layer for the PHP extension intl
php-symfony-monolog-bridge - integration for Monolog with Symfony Components
php-symfony-options-resolver - configure objects with option arrays
php-symfony-phpunit-bridge - integration for PHPUnit with Symfony Components
php-symfony-process - execute commands in sub-processes
php-symfony-property-access - read from and write to an object or array
php-symfony-proxy-manager-bridge - integration for ProxyManager with Symfony Components
php-symfony-routing - associate a request with code that generates a response
php-symfony-security - infrastructure for sophisticated authorization systems
php-symfony-security-bundle - configurable security system for the Symfony framework
php-symfony-serializer - convert PHP objects into specific formats and vice versa
php-symfony-stopwatch - profile PHP code
php-symfony-swiftmailer-bridge - integration for Swift Mailer with Symfony Components
php-symfony-templating - tools needed to build a template system
php-symfony-translation - tools to internationalize an application
php-symfony-twig-bridge - integration for Twig with Symfony Components
php-symfony-twig-bundle - configurable integration of Twig with the Symfony framework
php-symfony-validator - tools to validate classes
php-symfony-var-dumper - Symfony mechanism for exploring and dumping PHP variables
php-symfony-web-profiler-bundle - collect requests information for analysis and debugging
php-symfony-yaml - convert YAML to PHP arrays and the other way around
php-tcpdf - PHP class for generating PDF files on-the-fly
php-text-captcha - Generation of CAPTCHAs
php-text-figlet - PEAR module for rendering text using FIGlet fonts
php-text-languagedetect - Language detection class
php-text-password - Creating passwords with PHP
php-text-template - Simple template engine
php-text-wiki - transform Wiki and BBCode markup into XHTML, LaTeX or plain text markup
php-timer - Utility class for timing
php-token-stream - Wrapper around PHP's tokenizer extension
php-tokenreflection - PHP reflection replacement
php-twig - Flexible, fast, and secure template engine for php
php-twig-doc - Twig template engine documentation
php-uuid - PHP UUID extension
php-validate - validation class
php-webmozart-assert - Assertions to validate method input/output with nice error messages
php-wikidiff2 - external diff engine for mediawiki
php-xajax - A library to develop Ajax applications
php-xdebug - Xdebug Module for PHP
php-xml - DOM, SimpleXML, WDDX, XML, and XSL module for PHP [default]
php-xml-htmlsax3 - SAX parser for HTML and other badly formed XML documents
php-xml-parser - XML parsing class based on PHP's bundled expat
php-xml-rpc2 - PHP XML-RPC client/server library
php-xml-serializer - swiss-army knife for reading and writing XML files
php-xml-svg - XML_SVG API
php-yac - YAC (Yet Another Cache) for PHP
php-zend-code - Zend Framework - Code component
php-zend-db - Zend Framework - Db component
php-zend-eventmanager - Zend Framework - EventManager component
php-zend-hydrator - Zend Framework - Hydrator component
php-zend-search - Zend Framework - ZendSearch component
php-zend-stdlib - Zend Framework - Stdlib component
php-zend-xml - Zend Framework - Xml component
php-zeta-base - Zeta Components - Base package
php-zeta-console-tools - Zeta Components - ConsoleTools package
php-zeta-unit-test - Zeta Components - UnitTest package
php-zip - Zip module for PHP [default]
php-zipstreamer - Stream zip files without i/o overhead
php-zmq - ZeroMQ messaging bindings for PHP
phpab - lightweight PHP namespace aware autoload generator
phpbb3 - full-featured, skinnable non-threaded web forum
phpbb3-l10n - additional language files for phpBB
phpcpd - copy and paste detector (CPD) for PHP code
phpdox - documentation generation framework and tool
phpgacl - PHP Generic Access Control Lists
phpldapadmin - web based interface for administering LDAP servers
phploc - tool for quickly measuring the size of a PHP project
phpmd - PHP Mess Detector
phpmyadmin - MySQL web administration tool
phppgadmin - web-based administration tool for PostgreSQL
phpqrcode - PHP library for generating two-dimensional barcodes
phpreports - XML-based report generator for PHP
phpsysinfo - PHP based host information
phpunit-code-unit-reverse-lookup - look up what a line of code belongs to - PHPUnit component
phpunit-comparator - functionality to compare PHP values for equality - PHPUnit component
phpunit-dbunit - DbUnit port for PHP/PHPUnit to support database interaction testing
phpunit-diff - diff implementation - stand-alone component from PHPUnit
phpunit-environment - functionality to handle HHVM/PHP environments - PHPUnit component
phpunit-exporter - export variables for visualization - PHPUnit component
phpunit-git - Simple wrapper for Git
phpunit-global-state - snapshotting of global state - PHPUnit component
phpunit-mock-object - Mock Object library for PHPUnit
phpunit-object-enumerator - enumerate all referenced objects - PHPUnit component
phpunit-recursion-context - recursively process PHP variables - PHPUnit component
phpunit-resource-operations - provide a list of PHP built-in functions that operate on resources
phpunit-version - Library that helps with managing the version number of Git-hosted PHP projects
phpwebcounter - simple and light web hit counter
phpwebcounter-extra - extra graphical numbers to PHP Web Counter
pinba-engine-mysql - realtime statistics server for PHP using MySQL (metapackage)
pinba-engine-mysql-5.7 - realtime statistics server for PHP using MySQL as a read-only interface
poppassd - password change server for Eudora and NUPOP
postfix-cluebringer-webui - anti-spam plugin for Postfix
postfixadmin - Virtual mail hosting interface for Postfix
postgresql-9.5-pgtap - Unit testing framework extension for PostgreSQL 9.5
prayer - standalone IMAP-based webmail server
prayer-accountd - account management daemon for Prayer
prayer-templates-dev - tools for compiling Prayer templates
prayer-templates-src - templates for customizing Prayer Webmail
preprocess - portable multi-language file preprocessor
psi-plus - Qt-based XMPP/Jabber client (basic version)
psi-plus-common - common files for Psi+
psi-plus-dbg - Qt-based XMPP/Jabber client (basic version) [debug symbols]
psi-plus-l10n - localization files for Psi+
psi-plus-plugins - plugins for Psi+
psi-plus-plugins-dbg - plugins for Psi+ [debug symbols]
psi-plus-skins - skins for Psi+
psi-plus-sounds - sound files for Psi+
psi-plus-webkit - Qt-based XMPP/Jabber client (WebKit version)
psi-plus-webkit-dbg - Qt-based XMPP/Jabber client (WebKit version) [debug symbols]
python-adodb - A database abstraction library for python
python-cheetah - text-based template engine and Python code generator
python-django-extdirect - Ext.Direct serverside implementation for Django
python-guzzle-sphinx-theme - Sphinx theme used by Guzzle
python-htmltmpl - Templating engine for separation of code and HTML
python-kid - simple Pythonic template language for XML based vocabularies
python-ming - Ming (SWF) module for Python
python-phply - PHP parser written in Python using PLY
python-phpserialize - Python port of PHP serialize and unserialize functions (Python 2)
python-pysimplesoap - simple and lightweight SOAP Library (Python 2)
python-sphinxcontrib.phpdomain - Sphinx "phpdomain" extension
python-templayer - layered template library for Python
python-vatnumber - Python module to validate VAT numbers (implemented in Python 2)
python3-phply - PHP parser written in Python 3 using PLY
python3-phpserialize - Python port of PHP serialize and unserialize functions (Python 3)
python3-pysimplesoap - simple and lightweight SOAP Library (Python 3)
python3-vatnumber - Python module to validate VAT numbers (implemented in Python 3)
r-cran-brew - GNU R templating framework for report generation
r-cran-nloptr - GNU R package for interface to NLopt
r-cran-stringi - GNU R character string processing facilities
raintpl - easy and fast template engine for PHP
refdb-clients - Reference database and bibliography tool - clients
refdb-doc - Reference database and bibliography tool - doc
refdb-server - Reference database and bibliography tool - sql server
refdb-www - Reference database and bibliography tool - www server
rhythmbox-ampache - play audio streams from an Ampache server
rofs - Read-Only Filesystem for FUSE
rtgui - Web based front-end for rTorrent
ruby-bluefeather - Extend Markdown Converter written in Ruby
ruby-coderay - Ruby library for syntax highlighting
ruby-erubis - fast and extensible eRuby implementation which supports multi-language
ruby-haml-contrib - Elegant, structured XHTML/XML templating engine - addons
sbnc-php-dev - IRC proxy for multiple users (PHP classes)
sbox-dtc - CGI chroot wrapper script for safer hosting environment
scummvm - engine for several graphical adventure games
scummvm-data - engine for several graphical adventure games (data files)
simpleid - simple OpenID provider implemented in PHP
simpleid-ldap - simple OpenID provider implemented in PHP - LDAP plugin
simpleid-store-dynalogin - two-factor HOTP/TOTP authentication - OpenID provider
simplesamlphp - Authentication and federation application supporting several protocols
slbackup-php - Web-based administration tool for slbackup
sloccount - programs for counting physical source lines of code (SLOC)
smarty-gettext - Gettext plugin enabling internationalization in Smarty
smarty-validate - Server-side form validation plugin for Smarty
smarty3 - Template engine for PHP
smoke-dev-tools - SMOKE development tools
smokegen-dbg - SMOKE development tools -- debug symbols
splash - Visualisation tool for Smoothed Particle Hydrodynamics simulation
sqlformat - SQL formatting utility
squirrelmail - Webmail for nuts
squirrelmail-compatibility - SquirrelMail plugin: Let other plugins work with older/newer SM versions
squirrelmail-lockout - SquirrelMail plugin: Disallow access to users/domains
squirrelmail-logger - SquirrelMail plugin: Add logging functionality to your webmail interface
squirrelmail-quicksave - SquirrelMail plugin: Auto-save messages while composing
squirrelmail-secure-login - SquirrelMail plugin: Force users to use SSL encrypted connections
squirrelmail-sent-confirmation - SquirrelMail plugin: display a confimation message after sending mails
squirrelmail-spam-buttons - SquirrelMail plugin: Place "Spam" buttons on the mailbox message list page
squirrelmail-viewashtml - SquirrelMail plugin: View mails as HTML
srg - Fast, Flexible and Detailed log analysis for the Squid Proxy
swig - Generate scripting interfaces to C/C++ code
swig2.0 - Generate scripting interfaces to C/C++ code
swig3.0 - Generate scripting interfaces to C/C++ code
synergy - Share mouse, keyboard and clipboard over the network
therion-doc - Documentation for Therion Cave surveying software
tntnet - modular, multithreaded web application server for C++
tntnet-demos - demo web applications for Tntnet
tntnet-doc - documentation for Tntnet
tweeper - web scraper to convert supported websites (e.g. Twitter.com) to RSS
txt2regex - A Regular Expression "wizard", all written with bash2 builtins
ukolovnik - Simple todo manager using PHP and MySQL
universalindentgui - GUI frontend for several code beautifiers
uphpmvault - upload recovery images to HP MediaVault2 via Ethernet
uwsgi-app-integration-plugins - plugins for integration of uWSGI and application
uwsgi-plugin-php - PHP plugin for uWSGI
vdr-plugin-infosatepg - include TechniSat EPG data via satelite in vdr
velocity - Java-based template engine for web application
vim-syntastic - Syntax checking hacks for vim
vim-youcompleteme - fast, as-you-type, fuzzy-search code completion engine for Vim
wapiti - web application vulnerability scanner
watchcatd - Process monitoring daemon
wulf2html - filter for generating HTML logs from wulflogger data
wulflogger - extract cluster node data from remote xmlsysd daemons
wulfstat - curses based wulfware for monitoring cluster nodes
wwwconfig-common - Debian web auto configuration
xine-ui - the xine video player, user interface
xjed - editor for programmers (x11 version)
xmlsysd - wulfware daemon to extract data from cluster nodes
yasat - simple stupid audit tool
yate-scripts - PHP scripts for YATE
yhsm-validation-server - Validation server using YubiHSM
yrmcds - memcached compatible KVS with master/slave replication
yubikey-ksm - Key Storage Module for YubiKey One-Time Password (OTP) tokens
yubikey-server-c - Yubikey validation server
yubikey-val - One-Time Password (OTP) validation server for YubiKey tokens
zabbix-frontend-php - network monitoring solution - PHP front-end
zend-framework - a simple, straightforward, open-source software framework for PHP 5
zend-framework-bin - a simple, straightforward, open-source software framework for PHP 5
mgltools-cadd - Computer Aided Drug Discovery (CADD) Pipeline
php-horde-javascriptminify-jsmin - Horde Javascript Minifier - Jsmin PHP Driver
php-horde-text-filter-jsmin - Horde Text Filter - Jsmin PHP Driver
php-mythtv - PHP Bindings for MythTV
apophenia-bin - Apophenia Statistical C Library -- binary package
apophenia-doc - Apophenia Statistical C Library -- reference manual
auth2db - Powerful and eye-candy IDS logger, log viewer and alert generator
dbconfig-mysql - dbconfig-common MySQL/MariaDB support
libapophenia2 - Apophenia Statistical C Library -- library package
libapophenia2-dev - Apophenia Statistical C Library -- development package
libmariadb-client-lgpl-dev - MariaDB Client Library for C, development files
libmariadb-client-lgpl-dev-compat - MariaDB Client Library for C, compatibility symlinks
libmariadb2 - MariaDB Client Library for C
libmariadbd-dev - MariaDB embedded database, development files
libmariadbd18 - MariaDB embedded database
libreoffice-mysql-connector - MariaDB/MySQL Connector extension for LibreOffice
libwtdbomysql-dev - MySQL/MariaDB backend for Wt::Dbo [development]
libwtdbomysql38 - MySQL/MariaDB backend for Wt::Dbo [runtime]
mariadb-client - MariaDB database client (metapackage depending on the latest version)
mariadb-client-10.0 - MariaDB database client binaries
mariadb-client-core-10.0 - MariaDB database core client binaries
mariadb-common - MariaDB common metapackage
mariadb-plugin-connect - Connect storage engine for MariaDB
mariadb-plugin-mroonga - Mroonga storage engine for MariaDB
mariadb-plugin-oqgraph - OQGraph storage engine for MariaDB
mariadb-plugin-spider - Spider storage engine for MariaDB
mariadb-server - MariaDB database server (metapackage depending on the latest version)
mariadb-server-10.0 - MariaDB database server binaries
mariadb-server-core-10.0 - MariaDB database core server files
mariadb-test - MariaDB database regression test suite
mariadb-test-data - MariaDB database regression test suite - data files
mycli - CLI for MySQL/MariaDB
