Проблема с запуском сервера
batihor
Re: Проблема с запуском сервера
Сообщение batihor »
все бы ни чего, но вот...
Изменена опция сборки, пересобираем все
server_ajax.ino: In function 'void parseRequest(WiFiClient)':
server_ajax.ino:87:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:87:80: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:100:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:100:74: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:107:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:107:74: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:113:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:113:73: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:119:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:119:74: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:125:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:125:75: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:126:75: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:127:75: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:135:51: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:140:51: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:144:52: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:156:51: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:170:50: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:182:50: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:186:48: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void SetLEDs()':
server_ajax.ino:312:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:315:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:319:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:322:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:326:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:329:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:333:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:336:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void setSettings()':
server_ajax.ino:441:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:444:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void setControl()':
server_ajax.ino:513:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:517:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:522:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:526:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:531:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:535:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:540:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:544:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:549:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:553:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void checkPage()':
server_ajax.ino:680:49: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:681:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:682:46: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:683:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:684:48: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Multiple libraries were found for "DallasTemperature.h"
Used: C:\Program Files\Arduino\portable\sketchbook\libraries\DallasTemperature
Not used: C:\Program Files\Arduino\portable\sketchbook\libraries\dallas-temperature-control
Multiple libraries were found for "OneWire.h"
Used: C:\Program Files\Arduino\portable\sketchbook\libraries\OneWire
Not used: C:\Program Files\Arduino\portable\packages\esp8266\hardware\esp8266\2.0.0\libraries\OneWire
Sketch uses 275 566 bytes (55%) of program storage space. Maximum is 499 696 bytes.
Global variables use 44 120 bytes (53%) of dynamic memory, leaving 37 800 bytes for local variables. Maximum is 81 920 bytes.
Сообщение serghei »
Отлично! На Варнинги не обращай внимание. Про это писали на форуме - прочитай тему АМС на ЕСП еще раз. Если скомпилировалось - то зальется. Сначала файлы, затем скетч. Как это сделать на модуле с двумя пинами я пока не знаю.
batihor
Сообщение batihor »
заливается. но работы нет. пока не ясно ни чего.
Сообщение serghei »
Покажи лог SerialMonitora. Веб страницы открываются? Названия сети и пароль прописал? Главное чтобы подсеть совпала. И адрес гетвея укажи свой. А то время не увидишь )))
batihor
Сообщение batihor »
спасибо огромное. работает!
со временем действительно пока туго )))
Сообщение serghei »
Пишу по памяти. На компе запусти CMD.exe и набери ipconfig . Вылезет инфа твоего WiFi. Там будет и адрес гетвея. У меня вторая подсеть и адрес 192.168.2.100 . Вот его и вбей в код АМС. Я сообразил через 3 месяца :lol:
batihor
Сообщение batihor »
я его провтыкал исправить )))
все заработало. благодарю за помощь!
Сообщение serghei »
Просто я себя помню как первый раз запускал. Два месяца понадобилось. Удачи !
Corshun74
Сообщение Corshun74 »
Напишу здесь, проблема та же - с запуском сервера. Arduino Mega 2560 rev3 / Ethernet Shield W5100 от RobotDyn / RTC 3231 /Transcend 2gb . Все проверено на стандартных примерах - Web-server работает нормально, карта опознается.
Все файлы взяты отсюда https://hi-lab.ru/ , среда Arduino 1.6.5 , Arduino Mega Server version 0.16, библиотеки подкинул, файлы на карту скинул. компилируется и заливается без предупреждений.
В итоге - пингуется без проблем. браузер пишет :
Страница недоступна
Сайт 192.168.10.37 не отправил данных.
Подключал и напрямую к ноутбуку, и к роутеру. -без разницы
Иногда получается попасть на стартовую страницу, дальше - никак.
при питании от USB лог такой
AMS Mega (0.16) started...
Modul Hardware...
Controller: Arduino Mega
Total memory: 8192
Free memory: 3880 (47%)
Network adapter: Ethernet Shield
started
Modul EEPROM...
Address: 45
started
Modul Ethernet...
MAC: 0 2A F5 12 67 FA
IP: 192.168.10.37
started
Modul SD...
SD init... OK
index.htm... found
Check..............
Files: 143
started
Modul SD Info...
SD type: SD2
Filesystem: FAT16
Cluster: -32768
SD size: 1965 MB
started
Modul NTP...
Local port: 123
started
Modul RTC...
Waiting for NTP sync...
Transmit NTP request (129.6.15.30:123)
Receive NTP response
2017-05-31 00:01:11 started
2017-05-31 00:01:11 Modul Server... started
2017-05-31 00:01:11 Modul Upload... started
2017-05-31 00:01:11 Modul Temperature...
2017-05-31 00:01:11 Parasite power OFF
2017-05-31 00:01:11 Found 0 devices
2017-05-31 00:01:11 #0: 0 0 0 0 0 0 0 tempSTR
2017-05-31 00:01:11 #1: 0 0 0 0 0 0 0 tempHOM
2017-05-31 00:01:11 #2: 0 0 0 0 0 0 0 tempWRM
2017-05-31 00:01:11 Modul nooLite... started
2017-05-31 00:01:11 GLOBAL Init DONE (3s)
2017-05-31 00:01:11 AMS WORK 3855 (47%)
2017-05-31 00:02:10 3827 (47%)
2017-05-31 00:03:10 3827 (47%)
2017-05-31 00:04:10 3827 (47%)
2017-05-31 00:05:10 3827 (47%)
2017-05-31 00:06:10 tempSTR: ID problem or not present
2017-05-31 00:06:10 tempHOM: ID problem or not present
2017-05-31 00:06:10 tempWRM: ID problem or not present
2017-05-31 00:06:10 3827 (47%)
Если подключаешь внешний источник питания 8в, карта странно себя ведет
Modul SD...
SD init... OK
index.htm... found
Check..............
Files: 143
started
Modul SD Info...
SD type: SD2
Not find partition
Not find partition
Куда дальше копать, не пойму. Может подскажете? Заранее спасибо.
Сообщение serghei »
Судя по первому логу как бы все нормально. Во втором не видит карту,вернее файловую систему. Свои приключения на этот счет и помочь смогу только после 22.00 по Москве. Перво - наперво возьмите новую карту. Желательно без посредника в виде карт - ридера форматните в FAT-32. Лучше на ноутбуке. Файлы залейте без каталогов - просто файлы. И у Вас точно 10 подсеть локальная?
Под микроскопом проверьте пины возле SD разъема и SPI Я не удачно подпаял радио модуль и Мега тупо зависала через час работы. (Сам шилд как на картинке ? )
Использую б/п от рутеров TP-link на 9 вольт.
Попробуйте сторонним низкоуровневым форматером форматнуть карту.Она точно не бывала в телефонах, планшетах ? И не знала NTFS ?
Ping говорит о том,что на шилд подано питание и он в локалке.
Мегу подключите только в рутер, допустим с той же 10 подсетью. Комп должен быть в той же подсети.
В течении дня я читаю форум, ответить не всегда могу . На работе ж.....(...есть...))).
И в скетче кроме часов и сети ничего не правили ?
