Борьба с ошибками в логах error.log debmes
PAV
Re: Борьба с ошибками в логах error.log debmes
Сообщение PAV » Вс дек 20, 2015 1:50 pm
У меня тоже такое проскакивает иногда, с другим сценарием, но бывает
PAV
Сообщение PAV » Вс окт 09, 2016 10:52 am
Новая беда. Кто знает, что за хрень?
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
sudo: no tty present and no askpass program specified
[Sun Oct 09 10:50:01.277327 2016] [:error] [pid 17532] [client 10.0.0.217:53163] PHP Warning:  imagepng() expects parameter 1 to be resource, null given in /srv/www/pChart/index.php on line 583, referer: http://10.0.0.105/menu.html
[Sun Oct 09 10:50:01.277696 2016] [:error] [pid 17532] [client 10.0.0.217:53163] PHP Stack trace:, referer: http://10.0.0.105/menu.html
[Sun Oct 09 10:50:01.277807 2016] [:error] [pid 17532] [client 10.0.0.217:53163] PHP   1. {main}() /srv/www/pChart/index.php:0, referer: http://10.0.0.105/menu.html
[Sun Oct 09 10:50:01.277872 2016] [:error] [pid 17532] [client 10.0.0.217:53163] PHP   2. imagepng() /srv/www/pChart/index.php:583, referer: http://10.0.0.105/menu.html
[Sun Oct 09 10:50:02.061348 2016] [:error] [pid 13441] [client 10.0.0.217:53160] PHP Warning:  imagepng() expects parameter 1 to be resource, null given in /srv/www/pChart/index.php on line 583, referer: http://10.0.0.105/menu.html
[Sun Oct 09 10:50:02.061600 2016] [:error] [pid 13441] [client 10.0.0.217:53160] PHP Stack trace:, referer: http://10.0.0.105/menu.html
[Sun Oct 09 10:50:02.061694 2016] [:error] [pid 13441] [client 10.0.0.217:53160] PHP   1. {main}() /srv/www/pChart/index.php:0, referer: http://10.0.0.105/menu.html
[Sun Oct 09 10:50:02.061766 2016] [:error] [pid 13441] [client 10.0.0.217:53160] PHP   2. imagepng() /srv/www/pChart/index.php:583, referer: http://10.0.0.105/menu.html
ZyaK
Сообщение ZyaK » Пт июн 01, 2018 2:08 pm
Подскажите пожалуйста что то больно много всего тут, как искать что нему не нравится?
15:02:49 0.27938000 Error registered (type: sql):
2006: MySQL server has gone away
SELECT objects.*
                     FROM objects
                    WHERE TITLE LIKE 'ThisComputer'
Backtrace:
#0 /var/www/html/lib/mysqli.class.php(394): registerError('sql', '2006: MySQL ser...')
#1 /var/www/html/lib/mysqli.class.php(177): mysql->Error('SELECT objects....')
#2 /var/www/html/lib/mysqli.class.php(225): mysql->Exec('SELECT objects....')
#3 /var/www/html/lib/mysqli.class.php(530): mysql->SelectOne('SELECT objects....')
#4 /var/www/html/lib/objects.class.php(387): SQLSelectOne('SELECT objects....')
#5 /var/www/html/lib/objects.class.php(902): getObject('ThisComputer')
#6 /var/www/html/scripts/cycle_wscache.php(64): setGlobal('cycle_wscacheRu...', 1527850969, 1)
#7 {main}
15:02:49 0.28076000 Error registered (type: sql):
SELECT objects.*
                     FROM objects
Backtrace:
#1 /var/www/html/lib/mysqli.class.php(233): mysql->Error('SELECT objects....')
#2 /var/www/html/lib/mysqli.class.php(530): mysql->SelectOne('SELECT objects....')
#3 /var/www/html/lib/objects.class.php(387): SQLSelectOne('SELECT objects....')
#4 /var/www/html/lib/objects.class.php(902): getObject('ThisComputer')
#5 /var/www/html/scripts/cycle_wscache.php(64): setGlobal('cycle_wscacheRu...', 1527850969, 1)
#6 {main}
15:02:49 0.28250400 Error registered (type: sql):
DELETE FROM jobs WHERE TITLE LIKE 'restartWebSocket'
Backtrace:
#1 /var/www/html/lib/mysqli.class.php(177): mysql->Error('DELETE FROM job...')
#2 /var/www/html/lib/mysqli.class.php(479): mysql->Exec('DELETE FROM job...')
#3 /var/www/html/lib/common.class.php(409): SQLExec('DELETE FROM job...')
#4 /var/www/html/lib/common.class.php(444): clearScheduledJob('restartWebSocke...')
#5 /var/www/html/lib/common.class.php(432): clearTimeOut('restartWebSocke...')
#6 /var/www/html/scripts/cycle_wscache.php(65): setTimeOut('restartWebSocke...', 'sg("cycle_webso...', 300)
#7 {main}
15:02:49 0.28381000 Error registered (type: sql):
INSERT INTO `jobs`(`TITLE`, `COMMANDS`, `RUNTIME`, `EXPIRE`) VALUES('restartWebSocket', 'sg(\"cycle_websocketsRun\",\"\");sg(\"cycle_websocketsControl\",\"restart\");', '2018-06-01 15:07:49', '2018-06-01 15:37:49')
Backtrace:
#1 /var/www/html/lib/mysqli.class.php(177): mysql->Error('INSERT INTO `jo...')
#2 /var/www/html/lib/mysqli.class.php(328): mysql->Exec('INSERT INTO `jo...')
#3 /var/www/html/lib/mysqli.class.php(550): mysql->Insert('jobs', Array)
#4 /var/www/html/lib/common.class.php(397): SQLInsert('jobs', Array)
#5 /var/www/html/lib/common.class.php(433): addScheduledJob('restartWebSocke...', 'sg("cycle_webso...', 1527851269)
#7 {main}
15:02:49 0.28500300 Error registered (type: sql):
Backtrace:
#1 /var/www/html/lib/mysqli.class.php(330): mysql->Error('INSERT INTO `jo...')
#2 /var/www/html/lib/mysqli.class.php(550): mysql->Insert('jobs', Array)
#3 /var/www/html/lib/common.class.php(397): SQLInsert('jobs', Array)
#4 /var/www/html/lib/common.class.php(433): addScheduledJob('restartWebSocke...', 'sg("cycle_webso...', 1527851269)
#5 /var/www/html/scripts/cycle_wscache.php(65): setTimeOut('restartWebSocke...', 'sg("cycle_webso...', 300)
#6 {main}
15:02:49 0.46310600 Error registered (type: sql):
SELECT objects.*
                     FROM objects
Backtrace:
#6 /var/www/html/scripts/cycle_db_save.php(48): setGlobal('cycle_db_saveRu...', 1527850969, 1)
#7 {main}
15:02:49 0.46403700 Error registered (type: sql):
SELECT objects.*
                     FROM objects
Backtrace:
#5 /var/www/html/scripts/cycle_db_save.php(48): setGlobal('cycle_db_saveRu...', 1527850969, 1)
#6 {main}
11:02:49 0.48226300 Error registered (type: sqlconn):
2002: No such file or directory
Backtrace:
#0 /var/www/html/lib/mysqli.class.php(135): registerError('sqlconn', '2002: No such f...')
#1 /var/www/html/lib/mysqli.class.php(106): mysql->Connect()
#2 /var/www/html/index.php(25): mysql->__construct('localhost', '', 'root', 'rootpsw', 'db_terminal')
#3 /var/www/html/nf.php(148): include_once('/var/www/html/i...')
#4 {main}
15:02:49 0.55386000 Error registered (type: sql):
SELECT objects.*
                     FROM objects
Backtrace:
#6 /var/www/html/scripts/cycle_alarmclock.php(35): setGlobal('cycle_alarmcloc...', 1527850969, 1)
#7 {main}
15:02:49 0.55488200 Error registered (type: sql):
SELECT objects.*
                     FROM objects
Backtrace:
#5 /var/www/html/scripts/cycle_alarmclock.php(35): setGlobal('cycle_alarmcloc...', 1527850969, 1)
#6 {main}
Сообщение skysilver » Пт июн 01, 2018 3:51 pm
Гуглить - MySQL server has gone away
PAV
Сообщение PAV » Пт окт 25, 2019 1:01 pm
Если при подключении SSH в файле /var/log/auth.log появляется ошибка:
fatal: no matching cipher found: client aes256-cbc,rijndael256-cbc,rijndael-cbc@lysator.liu.se,aes192-cbc,rijndael192-cbc,aes128-cbc,rijndael128-cbc,blowfish-cbc,3des-cbc,des-cbc,des-cbc@ssh.com server aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com [preauth]
Нужно добавить в файл:
/etc/ssh/sshd_config
Ciphers aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,blowfish-cbc,aes128-cbc,3des-cbc,cast128-cbc,arcfour,aes192-cbc,aes256-cbc
mavrnet
Сообщение mavrnet » Вт дек 10, 2019 11:54 am
Всем добрый день!
помогите пожалуйста. ежесекундно по несколько ошибок добавляется в error.og и он растет не по детски(
Mon Dec 09 11:37:45.410663 2019] [php7:warn] [pid 3657] [client 127.0.0.1:59688] PHP Warning: Illegal string offset 'ORIGINAL_OBJECT_TITLE' in /var/www/modules/objects/objects.class.php on line 559
[Mon Dec 09 11:37:45.410729 2019] [php7:error] [pid 3657] [client 127.0.0.1:59688] PHP Fatal error: Uncaught Error: Cannot unset string offsets in /var/www/modules/objects/objects.class.php:563\nStack trace:\n
#0 /var/www/lib/objects.class.php(954): objects->callMethod('switch', 'RFF')\n
#1 /var/www/modules/zigbee2mqtt/zigbee2mqtt.class.php(1107): callMethod('switch', 'OFF')\n
#2 /var/www/modules/zigbee2mqtt/zigbee2mqtt.class.php(900): zigbee2mqtt->update_default('zigbee2mqtt/0x0...', 'OFF')\n
#3 /var/www/modules/zigbee2mqtt/zigbee2mqtt.class.php(763): zigbee2mqtt->processMessage2('zigbee2mqtt/0x0...', 'OFF')\n
#4 /var/www/modules/zigbee2mqtt/zigbee2mqtt.class.php(736): zigbee2mqtt->processMessage('zigbee2mqtt/0x0...', '{"power":0.06,"...')\n
#5 /var/www/api.php(225): zigbee2mqtt->api(Array)\n
#6 {main}\n
thrown in /var/www/modules/objects/objects.class.php on line 563
и возможно ли, что из-за этого постоянно появляется вот такая системная ошибка?:
cycle_execs
Backtrace:
#0 /var/www/cycle.php(362): registerError('cycle_hang', 'cycle_execs')
#1 {main}
Что это значит? куда дальше копать?
