shil
Сообщение shil »
Доброго времени, модуль просто перестал работать(
Алиса начала говорить что в текущим режиме это невозможно
21:20:35 0.92511800 PropertySetHandle send result: Not Found
21:20:35 0.90732500 PropertySetHandle send result: Not Found
21:20:35 0.78685400 PropertySetHandle send: {"ts":1666030835,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"2","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","value":true}}],"properties":[]}]}}
21:20:35 0.78642300 PropertySetHandle for object 'Relay01' and property 'status' and value=1
21:20:35 0.78383800 PropertySetHandle send: {"ts":1666030835,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"2","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","value":true}}],"properties":[]}]}}
21:20:35 0.78339900 PropertySetHandle for object 'Relay01' and property 'status' and value=1
21:20:23 0.48493700 PropertySetHandle for object 'Sensor_temphum01' and property 'value' and value=25.40
21:20:23 0.48536400 PropertySetHandle send: {"ts":1666030823,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"12","capabilities":[{"type":"devices.capabilities.range","state":{"instance":"temperature","value":25}}],"properties":[]}]}}
21:20:23 0.55828100 PropertySetHandle send: {"ts":1666030823,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"12","capabilities":[{"type":"devices.capabilities.range","state":{"instance":"humidity","value":44}}],"properties":[]}]}}
21:20:23 0.55784800 PropertySetHandle for object 'Sensor_temphum01' and property 'valueHumidity' and value=44.20
21:20:23 0.63302800 PropertySetHandle send result: Not Found
21:20:23 0.67436100 PropertySetHandle send result: Not Found
21:19:45 0.35227900 smarthome.php >>> {"request_id":"c37cebab-696f-462a-a530-b7012db4888f","payload":{"devices":[{"id":"1","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","action_result":{"status":"ERROR","error_code":"NOT_SUPPORTED_IN_CURRENT_MODE","error_message":"The device is not controlled in this mode. The module is in read-only mode."}}}]}]}}
21:19:45 0.35213000 The property of the object has not been set. The module is in read-only mode.
21:19:45 0.35198200 Capabilities type 'devices.capabilities.on_off', instance 'on', relative=0, value=true
21:19:45 0.35155700 Incoming action request for device ID1
21:19:45 0.34974300 POST /modules/yandexhome/smarthome.php/v1.0/user/devices/action 141.8.142.32 <<< {"payload":{"devices":[{"id":"1","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","value":true}}]}]}}
21:19:23 0.56399700 PropertySetHandle for object 'Sensor_temphum01' and property 'value' and value=25.40
21:19:23 0.56441900 PropertySetHandle send: {"ts":1666030763,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"12","capabilities":[{"type":"devices.capabilities.range","state":{"instance":"temperature","value":25}}],"properties":[]}]}}
21:19:23 0.63618000 PropertySetHandle for object 'Sensor_temphum01' and property 'valueHumidity' and value=44.30
21:19:23 0.69553400 PropertySetHandle send result: Not Found
21:19:23 0.75314900 PropertySetHandle send result: Not Found
21:19:23 0.63723900 PropertySetHandle send: {"ts":1666030763,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"12","capabilities":[{"type":"devices.capabilities.range","state":{"instance":"humidity","value":44}}],"properties":[]}]}}
21:18:58 0.87038500 PropertySetHandle send result: Not Found
21:18:58 0.80561000 PropertySetHandle send result: Not Found
21:18:58 0.77214100 PropertySetHandle send: {"ts":1666030738,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"2","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","value":true}}],"properties":[]}]}}
21:18:58 0.77172400 PropertySetHandle for object 'Relay01' and property 'status' and value=1
21:18:58 0.71351200 PropertySetHandle send: {"ts":1666030738,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"2","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","value":true}}],"properties":[]}]}}
21:18:58 0.71300400 PropertySetHandle for object 'Relay01' and property 'status' and value=1
21:18:52 0.04742400 PropertySetHandle send result: Not Found
21:18:52 0.29095100 PropertySetHandle send result: Not Found
21:18:52 0.18668900 PropertySetHandle send result: Not Found
21:18:52 0.18235200 PropertySetHandle send: {"ts":1666030732,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"5","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","value":false}}],"properties":[]}]}}
21:18:52 0.18197400 PropertySetHandle for object 'Relay03' and property 'status' and value=0
21:18:52 0.06543600 PropertySetHandle send: {"ts":1666030732,"payload":{"user_id":"f904d454b24471a626744b6d7439b6a0","devices":[{"id":"5","capabilities":[{"type":"devices.capabilities.on_off","state":{"instance":"on","value":false}}],"properties":[]}]}}
21:18:52 0.06483400 PropertySetHandle for object 'Relay03' and property 'status' and value=0
21:18:52 0.03477500 PropertySetHandle send result: Not Found
webms
Сообщение webms »
тоже самое
shil
Сообщение shil »
shil писал(а): Пн окт 17, 2022 9:24 pm Доброго времени, модуль просто перестал работать(
вот что мне ответила поддержка яндекса
Спасибо за длительное ожидание, Максим!
Мы проверили информацию и постарались разобраться в ситуации.
По всей видимости, она возникает из-за изменения в работе навыка Умный Дом MajorDoMo, и только его разработчик сможет её исправить.
Увы, разработчик навыка не оставил контактов для связи. Пожалуйста, поставьте навыку низкую оценку на странице навыка и опишите произошедшую ситуацию в комментарии. Также при обращении укажите следующий Request ID: 1d30ba0c-0b13-465f-ad35-90406764a9e8, эта информация поможет разработчику навыка разобраться.
Надеемся, вопрос решится как можно быстрее!
Если у вас появятся новые вопросы, пишите. Постараемся помочь!
Yevgen16
Сообщение Yevgen16 »
shil писал(а): Ср окт 19, 2022 10:52 am вот что мне ответила поддержка яндекса
На всякий случай спрошу, а у вас навык приватный или публичный, который работает через коннект Сергея? У меня приватный (свой) работает нормально.
Сообщение xor »
Yevgen16 писал(а): Ср окт 19, 2022 1:28 pm
Поддержка ссылается на публичный навык Умный Дом MajorDoMo, который никаким боком к модулю Yandex Home (тема тут)
С навыком Сергея работает его же модуль мдм YaDevices и с ним тоже всё в порядке
Yevgen16
xor писал(а): Ср окт 19, 2022 5:15 pm
Я поэтому и спросил про какой навык идёт разговор. Тоже думаю, что поддержка не про то отвечает.
shil
Сообщение shil »
Приватный
shil
Сообщение shil »
Yevgen16 писал(а): Ср окт 19, 2022 8:11 pm
Я понял, спасибо
shil
Сообщение shil »
Получил такой ответ от поддержки Яндекса
Проверьте, пожалуйста, работу вашего навыка. Навык отвечает на запросы следующим образом
"request_id": "841bd8a0-da99-4644-9063-4cdf2bcea416",
"payload": {
"devices": [
"id": "2",
"capabilities": [
"type": "devices.capabilities.on_off",
"state": {
"instance": "on",
"action_result": {
"status": "ERROR",
"error_code": "NOT_SUPPORTED_IN_CURRENT_MODE",
"error_message": "The device is not controlled in this mode. The module is in read-only mode."
Подскажите пожалуйста, что за режим для чтения?
Сообщение xor »
shil писал(а): Чт окт 20, 2022 6:52 pm Получил такой ответ от поддержки Яндекса
"payload": {
"devices": [
"id": "2",
"capabilities": [
"state": {
"instance": "on",
"action_result": {
"status": "ERROR",
Автономный режим в настройках вашего модуля, судя по коду
