121 раз
2010 раз
Сообщение
nick7zmail » Вт июн 09, 2020 7:46 am
andrey040670 писал(а):Модуль вроде бы работает, но при авто обновлении апач матюкается в еррор.логе, вот часть этого безобразия:
[Mon Jun 08 07:00:00.738072 2020] [php7:error] [pid 28721] [client 127.0.0.1:57468] PHP Fatal error: Uncaught Error: Call to undefined method app_openweather::get_weather() in /var/www/modules/objects/objects.class.php(624) : eval()'d code:3\nStack trace:\n#0 /var/www/modules/objects/objects.class.php(624): eval()\n#1 /var/www/lib/objects.class.php(964): objects->callMethod('Run', 0)\n#2 /var/www/objects/index.php(147) : eval()'d code(1): callMethod('Run')\n#3 /var/www/objects/index.php(147): eval()\n#4 {main}\n thrown in /var/www/modules/objects/objects.class.php(624) : eval()'d code on line 3
[Mon Jun 08 08:00:00.197098 2020] [php7:error] [pid 1343] [client 127.0.0.1:36904] PHP Fatal error: Uncaught Error: Call to undefined method app_openweather::get_weather() in /var/www/modules/objects/objects.class.php(624) : eval()'d code:3\nStack trace:\n#0 /var/www/modules/objects/objects.class.php(624): eval()\n#1 /var/www/lib/objects.class.php(964): objects->callMethod('Run', 0)\n#2 /var/www/objects/index.php(147) : eval()'d code(1): callMethod('Run')\n#3 /var/www/objects/index.php(147): eval()\n#4 {main}\n thrown in /var/www/modules/objects/objects.class.php(624) : eval()'d code on line 3
[Mon Jun 08 09:00:00.203389 2020] [php7:error] [pid 32496] [client 127.0.0.1:44578] PHP Fatal error: Uncaught Error: Call to undefined method app_openweather::get_weather() in /var/www/modules/objects/objects.class.php(624) : eval()'d code:3\nStack trace:\n#0 /var/www/modules/objects/objects.class.php(624): eval()\n#1 /var/www/lib/objects.class.php(964): objects->callMethod('Run', 0)\n#2 /var/www/objects/index.php(147) : eval()'d code(1): callMethod('Run')\n#3 /var/www/objects/index.php(147): eval()\n#4 {main}\n thrown in /var/www/modules/objects/objects.class.php(624) : eval()'d code on line 3
Разбор полётов сам не делал, пока в разъездах, нет времени.
P/s
PHP Version 7.2.24
У вас от старого модуля код на обновление погоды где то прописан...там надо последнюю строку поменять на ту, что выше привели (первые 2 строки совпадают).
andrey040670
167 раз
86 раз
Сообщение
andrey040670 » Вт июн 09, 2020 10:06 am
Вроде всё подчистил, а где надо поменял, но проверю ещё раз.
Спасибо.
P/s
Ага, нашёл. Занимался экспериментами (давно это было) и благополучно про это забыл
, а код остался. Надо выбрать время и почистить систему от всякого теперь не нужного и забытого хлама, наверное можно ещё чего нибудь найти.
Ещё раз спасибо.
tosat
1 раз
0
Сообщение
tosat » Чт июн 11, 2020 12:40 pm
Скажите, почему у меня на 3-й малине в настройках местоположения можно выбрать только страну, город выбрать негде, соответственно погода не отображается.На старой версии всё работает.
Последний раз редактировалось
tosat Чт июн 11, 2020 1:12 pm, всего редактировалось 1 раз.
121 раз
2010 раз
Сообщение
nick7zmail » Чт июн 11, 2020 12:41 pm
tosat писал(а):Скажите, почему у меня на 3-й малине в настройках местоположения можно выбрать только страну, год выбрать негде, соответственно погода не отображается.На старой версии всё работает.
Какой браузер? Попробуйте хром или оперу
tosat
1 раз
0
Сообщение
tosat » Чт июн 11, 2020 1:11 pm
Пробовал и хром и оперу, всё равно выбора города нет, скинул бы скрин, но почему-то не получается.
andrey040670
167 раз
86 раз
Сообщение
andrey040670 » Чт июн 11, 2020 1:17 pm
С файлом /modules/app_openweather/city.list.json всё в порядке?
121 раз
2010 раз
Сообщение
nick7zmail » Чт июн 11, 2020 1:41 pm
tosat писал(а):Пробовал и хром и оперу, всё равно выбора города нет, скинул бы скрин, но почему-то не получается.
Интересно...первый такой случай с этим модулем...давайте подключусь гляну
tosat
1 раз
0
Сообщение
tosat » Чт июн 11, 2020 1:55 pm
Да, только что вытер полностью модуль(чтобы не было хвостов), установил по новой с маркета, этот файл занимает 31.7 мBаt, всё равно картина такая же, хотя на старой версии выбор города есть.
А что нужно для вашего подключения ?
121 раз
2010 раз
Сообщение
nick7zmail » Чт июн 11, 2020 6:43 pm
tosat писал(а):Да, только что вытер полностью модуль(чтобы не было хвостов), установил по новой с маркета, этот файл занимает 31.7 мBаt, всё равно картина такая же, хотя на старой версии выбор города есть.
Тимвивер/энидеск и время согласовать...в телегу можно написать @nick7zmaik
tosat
1 раз
0
Сообщение
tosat » Чт июн 11, 2020 11:55 pm
Вообщем разобрался, дело в том что я юзаю в основном планшет Ipad, так вот на нём список городов не подгружаетя, с компа всё нормально, но мне всё равно старая версия программы больше нравится, накатил её поверх новой и, работает и даже обновления не просит, ещё у меня проблеммы с новой версией графиков, сами то они рисуются, но если посмотреть в простых устройствах например температуру то там видно только значок увеличение на весь экран и он не работает, самого графика нету.
