Установка Мажордомо на XAMPP
Re: Установка Мажордомо на XAMPP
Сообщение tarasfrompir »
Slavik398 писал(а): Чт апр 09, 2020 1:25 pm
if (is_array($_GET['m_c_s']) && count($_GET['m_c_s']) ) {
Тогда еще такой вариант
Slavik398
Сообщение Slavik398 »
tarasfrompir писал(а): Чт апр 09, 2020 1:42 pm
Заменил
Перезагрузил
Ничего не поменялось.
[Thu Apr 09 14:03:01.956627 2020] [php7:warn] [pid 5168:tid 1960] [client 127.0.0.1:54085] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
[Thu Apr 09 14:03:02.019132 2020] [php7:warn] [pid 5168:tid 1960] [client 127.0.0.1:54085] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
[Thu Apr 09 14:03:02.072519 2020] [php7:warn] [pid 5168:tid 1924] [client 127.0.0.1:54090] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
[Thu Apr 09 14:03:02.135016 2020] [php7:warn] [pid 5168:tid 1924] [client 127.0.0.1:54090] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
[Thu Apr 09 14:03:03.119130 2020] [php7:warn] [pid 5168:tid 1960] [client 192.168.8.108:45184] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
[Thu Apr 09 14:03:03.237524 2020] [php7:warn] [pid 5168:tid 1960] [client 192.168.8.108:45184] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
[Thu Apr 09 14:03:10.625385 2020] [php7:warn] [pid 5168:tid 1960] [client 192.168.8.104:19728] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
[Thu Apr 09 14:03:20.529929 2020] [php7:warn] [pid 5168:tid 1924] [client 192.168.8.104:3894] PHP Warning:  in_array() expects parameter 2 to be array, null given in D:\\xampp\\htdocs\\modules\\objects\\objects.class.php on line 506
нашел чего не так - щас соображу
замени всю функцию
   function callMethodSafe($name, $params = 0) {
        startMeasure('callMethodSafe');
        $current_call = $this->object_title . '.' . $name;
        $call_stack = array();
        if (is_array($params)) {
			if (isset($params['m_c_s']) && is_array($params['m_c_s']) && !empty($params['m_c_s'])) {
				$call_stack = $params['m_c_s'];
						DebMes($params['m_c_s']);
			$raiseEvent = $params['raiseEvent'];
			unset($params['raiseEvent']);
			unset($params['m_c_s']);
            $current_call .= '.' . md5(json_encode($params));
        if (IsSet($_SERVER['REQUEST_URI']) && ($_SERVER['REQUEST_URI'] != '')) {
            if (isset($_GET['m_c_s']) && is_array($_GET['m_c_s']) && !empty($_GET['m_c_s'])) {
                $call_stack = $_GET['m_c_s'];
			$raiseEvent = $_GET['raiseEvent'];
            if (in_array($current_call, $call_stack)) {
                $call_stack[] = $current_call;
                DebMes("Warning: cross-linked call of " . $current_call . "\nlog:\n" . implode(" -> \n", $call_stack));
                return 0;
        if (!is_array($params)) {
            $params = array();
        $params['raiseEvent'] = $raiseEvent;
        $params['m_c_s'] = $call_stack;
        if (IsSet($_SERVER['REQUEST_URI']) && ($_SERVER['REQUEST_URI'] != '') && !$raiseEvent && count($call_stack)>1) {
            $result = $this->callMethod($name, $params);
            $result = callAPI('/api/method/' . urlencode($this->object_title . '.' . $name), 'GET', $params);
        endMeasure('callMethodSafe');
        return $result;
Slavik398
tarasfrompir писал(а): Чт апр 09, 2020 2:24 pm замени всю функцию
                return 0;
            $params = array();
        return $result;
Сейчас норм, в логе пусто,DebMes тоже ничего не выводит.
Конечный варианта
                return 0;
            $params = array();
        return $result;
pash4uga писал(а): Ср янв 15, 2020 5:29 pm У меня в логе mysql валится куча ошибок [ERROR] mysqld.exe: The table 'cached_ws' is full
Ни у кого такого не было, как бороться?
Кстати вроде поправилось в мдм. Альфа...
pash4uga
Сообщение pash4uga »
tarasfrompir писал(а): Вт апр 21, 2020 10:51 am Кстати вроде поправилось в мдм. Альфа...
Обновился, будем проверять)
Bagir
Сообщение Bagir »
tarasfrompir писал(а): Чт май 02, 2019 12:59 pmНам необходимо скачать АЛЬФА версию Мажордомо с гитхаба (поскольку в ней внесены изменения в базу данных)
На 2 мая 2019 года.
Как бы узнать какие именно? Я сделал переезд в новую сборку, но со своей базой данных. Ошибок по SQL пока не наблюдаю. Но как то не спокойно. Придется сравнивать структуру пустой базы данных из архива новой сборки и старой своей.
Bagir писал(а): Ср апр 22, 2020 9:13 am
На 2 мая 2019 года.
Это нужно для чистой установки, - не хватало каких то свойств в б.д. Так что если не пишет что чего то нету - то все нормально.
