Уже не первый раз замечаю, что через определенное время мажор становиться недоступным. Если перезагрузить nginx, то все ок.
При попытке достучаться до Мажора, получаем 504 Gateway Time-out.
/var/log/nginx/error.log:
2019/07/05 18:47:20 [error] 16667#16667: *131530 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
2019/07/05 18:50:07 [error] 16669#16669: *131533 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
2019/07/05 19:30:31 [error] 16670#16670: *131555 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
2019/07/05 20:11:17 [error] 16669#16669: *131600 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
root@orangepiprime:~# telnet localhost 80
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
Connection closed by foreign host.
user www-data;
worker_processes 4;
worker_rlimit_nofile 8192;
error_log /var/log/nginx/error.log error;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
client_body_temp_path /var/spool/nginx_client_body_temp;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
server_tokens off;
server_names_hash_bucket_size 128;
server {
server_name localhost md.lan;
root /var/www;
listen 80;
index index.html index.htm index.php default.html;
access_log off;
client_max_body_size 150M;
# настройки тюнинга https://xakep.ru/2010/12/15/54168/
# Максимальный размер буфера для хранения тела запроса клиента
client_body_buffer_size 1K;
# Максимальный размер буфера для хранения заголовков запроса клиента
client_header_buffer_size 1k;
# Максимальный размер тела запроса клиента, прописанный в поле Content-Length заголовка. Если сервер должен поддерживать загрузку файлов, это значение необходимо увеличить
#client_max_body_size 1k;
# Количество и размер буферов для чтения большого заголовка запроса клиента
large_client_header_buffers 2 1k;
# Таймаут при чтении тела запроса клиента
client_body_timeout 10;
# Таймаут при чтении заголовка запроса клиента
client_header_timeout 10;
# Таймаут, по истечению которого keep-alive соединение с клиентом не будет закрыто со стороны сервера
keepalive_timeout 5 5;
# Таймаут при передаче ответа клиенту
send_timeout 10;
# обрабатывать только запросы GET HEAD POST
if ($request_method !~ ^(GET|HEAD|POST)$ ) {
return 444;
location / {
rewrite pda$ /popup/pda.html redirect;
rewrite ^api/ /api.php;
if (!-e $request_filename){
rewrite ^(.*)$ /nf.php;
# настройки тюнинга
# обращение только по DNS имени
#if ($host !~ ^(md.lan|www.md.lan)$ ) {
#return 444;
location /config.php {
deny all;
location ~* "/\.(htaccess|htpasswd)$" {
deny all;
return 404;
location ~ \.php$ {
fastcgi_index index.php;
fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PATH_TRANSLATED $document_root$fastcgi_path_info;
include /etc/nginx/fastcgi_params;
fastcgi_param PHP_VALUE "short_open_tag=on";
fastcgi_param PHP_VALUE "error_reporting=E_ALL & ~E_NOTICE";
fastcgi_param PHP_VALUE "max_execution_time=90";
fastcgi_param PHP_VALUE "max_input_time=180";
fastcgi_param PHP_VALUE "post_max_size=200M";
fastcgi_param PHP_VALUE "upload_max_filesize=50M";
fastcgi_param PHP_VALUE "max_file_uploads=150";
fastcgi_read_timeout 400;
location /api {
rewrite ^(.*)$ /api.php;
