server_ajax.ino: In function 'void parseRequest(WiFiClient)':
server_ajax.ino:87:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:87:80: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino
server_ajax.ino
server_ajax.ino:107:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:107:74: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:113:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:113:73: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:119:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:119:74: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:125:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:125:75: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:126:75: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:127:75: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:135:51: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:140:51: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:144:52: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:156:51: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:170:50: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:182:50: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:186:48: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void SetLEDs()':
server_ajax.ino:312:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:315:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:319:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:322:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:326:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:329:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:333:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:336:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void setSettings()':
server_ajax.ino:441:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:444:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void setControl()':
server_ajax.ino:513:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:517:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:522:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:526:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:531:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:535:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:540:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:544:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:549:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:553:44: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino: In function 'void checkPage()':
server_ajax.ino:680:49: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:681:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:682:46: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:683:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
server_ajax.ino:684:48: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Multiple libraries were found for "DallasTemperature.h"
Used: C:\Program Files\Arduino\portable\sketchbook\libraries\DallasTemperature
Not used: C:\Program Files\Arduino\portable\sketchbook\libraries\dallas-temperature-control
Multiple libraries were found for "OneWire.h"
Used: C:\Program Files\Arduino\portable\sketchbook\libraries\OneWire
Not used: C:\Program Files\Arduino\portable\packages\esp8266\hardware\esp8266\2.0.0\libraries\OneWire
Sketch uses 275 566 bytes (55%) of program storage space. Maximum is 499 696 bytes.
Global variables use 44 120 bytes (53%) of dynamic memory, leaving 37 800 bytes for local variables. Maximum is 81 920 bytes.
