Coolerr
Сообщение Coolerr » Пт янв 20, 2017 4:31 pm
Здрасти всем, перечитал 160 страниц, все нравится все хочется. Залил на ESP код. А вот залить файловую систему не получается.
Arduino: 1.6.5 (Windows 7), Плата"NodeMCU 0.9 (ESP-12 Module), 80 MHz, Serial, 115200, 4M (3M SPIFFS)"
Used: C:\Users\UB6HMC\Downloads\ams_esp8266_015\Sketches\esp8266\Arduino\libraries\DallasTemperature
Not used: C:\arduino-1.6.5-r5\libraries\DallasTemperature
Sketch uses 276 726 bytes (55%) of program storage space. Maximum is 499 696 bytes.
Global variables use 44 408 bytes (54%) of dynamic memory, leaving 37 512 bytes for local variables. Maximum is 81 920 bytes.
C:\Users\UB6HMC\AppData\Roaming\Arduino15\packages\esp8266\tools\esptool\0.4.6/esptool.exe -vv -cd nodemcu -cb 115200 -cp COM4 -ca 0x00000 -cf C:\Users\UB6HMC\AppData\Local\Temp\build6500807327993257416.tmp/arduino_mega_server_esp8266.cpp.bin
esptool v0.4.6 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM4
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
stat C:\Users\UB6HMC\AppData\Local\Temp\build6500807327993257416.tmp/arduino_mega_server_esp8266.cpp.bin success
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
espcomm_send_command: receiving 2 bytes of data
espcomm_open
Uploading 280880 bytes from C:\Users\UB6HMC\AppData\Local\Temp\build6500807327993257416.tmp/arduino_mega_server_esp8266.cpp.bin to flash at 0x00000000
erasing flash
size: 044930 address: 000000
first_sector_index: 0
total_sector_count: 69
head_sector_count: 16
adjusted_sector_count: 53
adjusted_size: 035000
setting serial port timeouts to 10000 ms
writing flash
starting app without reboot
closing bootloader
flush start
flush complete
.............................................................................[SPIFFS] data : C:\Users\UB6HMC\Downloads\ams_esp8266_015\Sketches\esp8266\Arduino\arduino_mega_server_esp8266\data
[SPIFFS] size : 3052
[SPIFFS] page : 256
[SPIFFS] block : 8192
/3d-esp1.htm
/3d-esp2.htm
/3d-esp3.htm
/404.htm
/a-show.png
/about.htm
/am-1.jpg
/am-2.jpg
/am-3.jpg
/amb-1.png
/amb-2.png
/amk-1.jpg
/amk-2.jpg
/amk-3.jpg
/amp-1.png
/amp-2.png
/amp-3.png
/amperka.png
/arduino.jpg
/click.png
/concept1.jpg
/concept2.jpg
/control.htm
/coop.htm
/cube.pde
/dev.htm
/dis.jpg
/edit.htm
/edit2.htm
/electro.htm
/esp-12.png
/esp-logo.png
/flotr2.js
/full-am1.htm
/full-am1.png
/full.htm
/full2.htm
/gg-1.jpg
/gg-2.jpg
/gg-3.jpg
/gg-4.jpg
/gg-5.jpg
/gg-6.jpg
/gg-7.jpg
/head.js
/help.htm
/home.jpg
/index-p1.htm
/index-p3.htm
/index-p4.htm
/index.htm
/jquery.js
/logo-p0.png
/logo-p1.png
/logo-p3.png
/logo-p3a.png
/logo-p4.jpg
/logo-p4a.png
/modern.jpg
/mt1132.jpg
/nblock.jpg
/network.htm
/nheader.jpg
/noo-03a.jpg
/noo-14a.jpg
/noo-20a.jpg
/noo.htm
/nooint1.png
/nooint2.png
/nooint3.png
/noolink.jpg
/nootech.jpg
/nootech2.jpg
/npult.jpg
/nsensor.jpg
/nsmart.jpg
/offer.htm
/ok-md-cn.png
/ports.htm
/pr1132.jpg
/process.js
/refer.htm
/sample1.htm
/sample2.htm
/scripts.js
/sensors.htm
/settings.htm
/solder.htm
/solder.jpg
/spiffs.htm
/style.css
/style_hk.css
/style_hm.css
/style_md.css
/style_p1.css
/style_p3.css
/style_p4.css
/subsys.htm
/supply.htm
/system.htm
/tech.htm
/themes.htm
/three.js
/under.htm
/update.htm
/_banner.htm
/_dash.htm
/_dash_hk.htm
/_dash_hm.htm
/_dash_md.htm
/_dash_p1.htm
/_dash_p3.htm
/_dash_p4.htm
/_footer.htm
/_foot_hk.htm
/_foot_hm.htm
/_foot_md.htm
/_foot_p1.htm
/_foot_p3.htm
/_foot_p4.htm
/_header.htm
/_head_hk.htm
/_head_hm.htm
/_head_md.htm
/_head_p1.htm
/_head_p3.htm
/_head_p4.htm
/_menu.htm
/_menu_hk.htm
/_menu_hm.htm
/_menu_md.htm
/_menu_p1.htm
/_menu_p3.htm
/_menu_p4.htm
/_one.htm
/_one_hk.htm
/_one_hm.htm
/_one_md.htm
/_one_p1.htm
/_one_p3.htm
/_one_p4.htm
[SPIFFS] upload : C:\Users\UB6HMC\AppData\Local\Temp\build6500807327993257416.tmp/arduino_mega_server_esp8266.spiffs.bin
[SPIFFS] reset : nodemcu
[SPIFFS] port : COM4
[SPIFFS] speed : 115200
[SPIFFS] address: 0x100000
Uploading 3125248 bytes from C:\Users\UB6HMC\AppData\Local\Temp\build6500807327993257416.tmp/arduino_mega_server_esp8266.spiffs.bin to flash at 0x00100000
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
SPIFFS Upload failed!
такая фигня, если ставлю 1М 512К заливаться начинает но залипает через некоторое время. Заливаю скетч как NodeMCU 0.9 ибо у меня она и с встроенным конвертером на CH340.
Лог загрузки ESP
AMS for ESP8266 started...
Modul Hardware...
SDK version: 1.3.0
Boot version: 31
Boot mode: 1
Reset info: Fatal exception:0 flag:6 (EXT_SYS_RST) epc1:0x00000000 epc2:0x00000000 epc3:0x00000000 excvaddr:0x00000000 depc:0x00000000
CPU freq: 80 MHz
Free memory: 35016 (75%)
Flash speed: 40 MHz
Flash mode: 0
Flash size: 4194304
SPIFFS size: 3147488
Program size: 1046816
Sketch size: 280864
Free for sketch: 765952
started
Modul Wi-Fi...
Connecting to Spider
WiFi connected
IP address: 192.168.43.10
started
Modul SPIFFS...
Total files: 0
Total size: 0
started
Modul Random... started
Modul EEPROM...
started
Modul NTP...
Local port: 2390
started
Modul RTC...
Set time provider
sending NTP packet...
packet received, length=48
Unix time = 1484929681
started
2017-01-20 16:28:01 Modul HTTP...
2017-01-20 16:28:01 HTTP port: 80
2017-01-20 16:28:01 started
2017-01-20 16:28:01 Modul Server... started
GLOBAL Init DONE (6s)
AMS WORK
2017-01-20 16:28:01 : 31488 (68%) 31488
2017-01-20 16:28:54 : 31488 (68%) 0
Как победить?
Сообщение serghei » Пт янв 20, 2017 5:05 pm
Спрячьте код код спойлер. Скорее всего у Вас NodeMcu V3 с драйвером CH340. Фото платы можно в студию? Сначала заливаем файлы. Выбирайте NodeMCU 1.0 . Версия дров 2.0.0 Разбивку 1М под скетч, 3М под файлы. И после этого скетч. Судя по логу скетч работает. И версия IDE 1.6.5 r5 ,желательно r2 с сайта.
Coolerr
Сообщение Coolerr » Пт янв 20, 2017 5:24 pm
Да плата такая Изображение
Пробовал по разному и сначала файлы потом систему и наоборот, и заливал родную прошивку. IDE 1.6.5 r2 скачано отсюда, версия Expressiff 2.0.0 иначе прошивка не компилилась.
Сообщение serghei » Пт янв 20, 2017 5:31 pm
.......Чешу репу...... У меня проблемы были после всяких манипуляций с платами . Попробуйте в другой порт воткнуть. И несколько раз перегрузить NodeMcu .Буквально сейчас полдня убил , прежде чем залил в старую плату.
Mochalov_da
Сообщение Mochalov_da » Пт янв 20, 2017 5:33 pm
Coolerr писал(а): такая фигня, если ставлю 1М 512К
Лог загрузки ESP
Modul Hardware...
SDK version: 1.3.0
Boot version: 31
Boot mode: 1
CPU freq: 80 MHz
Flash speed: 40 MHz
Flash mode: 0
Flash size: 4194304
Sketch size: 280864
started
Modul Wi-Fi...
Как победить?
У вас 4M памяти судя по логу загрузки AMS. Зачем вы размечаете как 1М 512К?!
Отправлено с моего HUAWEI TIT-AL00 через Tapatalk
Cubieboard A10(Cubian/MajorDoMo)+nRF24L01+ds18b20, ESP8266(AMS)+RGB+ds18b20, Attiny13a+nRF24L01
Coolerr
Сообщение Coolerr » Пт янв 20, 2017 5:35 pm
Перетыкивание не помогает.
[SPIFFS] port : COM1
Uploading 3125248 bytes from C:\Users\UB6HMC\AppData\Local\Temp\build8991544029131517115.tmp/sketch_jan20a.spiffs.bin to flash at 0x00100000
Mochalov_da
Да я уже по всякому пробую. В таком положении хоть что-то происходит, результат конечно нулевой.
Mochalov_da
Сообщение Mochalov_da » Пт янв 20, 2017 5:39 pm
Coolerr писал(а):
Mochalov_da
Можно включить модуль ftp и закинуть все файлы через него.
Сообщение serghei » Пт янв 20, 2017 5:45 pm
Со всеми "нормальными" готовыми платами проблем не было. А загрузчик файлов из дистрибутива?
Сообщение serghei » Пт янв 20, 2017 5:49 pm
Mochalov_da писал(а): Можно включить модуль ftp и закинуть все файлы через него.
А можно поподробнее? А то в 16М скетч залить еще как то могу, а файлы ну никак((((
Coolerr
Сообщение Coolerr » Пт янв 20, 2017 6:30 pm
Загрузчик из него. А есть другой?
