Ошибка системы, помогите плиз! ! !
zoto
Re: Ошибка системы, помогите плиз! ! !
Сообщение zoto » Вт янв 30, 2018 8:14 pm
Вот этот лог при загрузке, может поможете)))
C:\_majordomo>set MIBDIRS=C:\_majordomo\server\php\Extras\mibs
C:\_majordomo>rem Timesync on startup
C:\_majordomo>rem start .\apps\neutron\neutron.exe
C:\_majordomo>rem Web-server start
C:\_majordomo>start server2go.exe
C:\_majordomo>rem USB devices monitor start
C:\_majordomo>rem start .\apps\usbdeview\USBDeview.exe
C:\_majordomo>rem Battery run monitor start
C:\_majordomo>rem start .\apps\batteryrun\batteryrun.exe "C:\_majordomo\htdocs\obj.bat ThisComputer.powerConnected" "C:\_majordomo\htdocs\obj.bat ThisComputer.powerDisconnected"
C:\_majordomo>rem Main system cycle start
C:\_majordomo>rem Database auto repair
C:\_majordomo>.\server\mysql\bin\mysqlcheck.exe -u root --auto-repair --check --optimize --all-databases
.\server\mysql\bin\mysqlcheck.exe: Got error: 2003: Can't connect to MySQL server on 'localhost' (10061) when trying to connect
C:\_majordomo>cd .\htdocs
C:\_majordomo\htdocs>..\server\php\php.exe cycle.php
Connecting to database...
CONNECTED TO DB
Running startup maintenance
Checking modules.
Clearing the cache.
Starting ./scripts/cycle_connect.php ...
23:10:46 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_connect.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_connect.php.txt
OK
Starting ./scripts/cycle_dev_broadlink.php ...
23:10:47 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_broadlink.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_dev_broadlink.php.txt
OK
Starting ./scripts/cycle_execs.php ...
23:10:48 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_execs.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_execs.php.txt
OK
Starting ./scripts/cycle_main.php ...
23:10:49 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_main.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_main.php.txt
OK
Starting ./scripts/cycle_nut.php ...
23:10:49 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_nut.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_nut.php.txt
OK
Starting ./scripts/cycle_onvif.php ...
23:10:51 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_onvif.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_onvif.php.txt
OK
Starting ./scripts/cycle_ping.php ...
23:10:51 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_ping.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_ping.php.txt
OK
Starting ./scripts/cycle_rss.php ...
23:10:52 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_rss.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_rss.php.txt
OK
Starting ./scripts/cycle_scheduler.php ...
23:10:53 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_scheduler.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_scheduler.php.txt
OK
Starting ./scripts/cycle_skype.php ...
23:10:54 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_skype.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_skype.php.txt
OK
Starting ./scripts/cycle_states.php ...
23:10:55 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_states.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_states.php.txt
OK
Starting ./scripts/cycle_websockets.php ...
23:10:56 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_websockets.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_websockets.php.txt
OK
Starting ./scripts/cycle_webvars.php ...
23:10:57 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_webvars.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_webvars.php.txt
OK
Starting ./scripts/cycle_wscache.php ...
23:10:59 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_wscache.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_wscache.php.txt
OK
Starting ./scripts/cycle_X101_skype.php ...
OK
Starting ./scripts/cycle_xiaomihome.php ...
23:11:06 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_xiaomihome.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_xiaomihome.php.txt
OK
Starting ./scripts/cycle_xiaomimiio.php ...
23:11:08 Starting thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_xiaomimiio.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_xiaomimiio.php.txt
OK
ALL CYCLES STARTED
23:11:08 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_connect.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_connect.php.txt
23:11:08 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_skype.php --params "a:0:{}">>C:\_majordomo\htdocs/debmes/log_2018-01-30-cycle_skype.php.txt
PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 49 bytes) in C:\_majordomo\htdocs\lib\mysqli.class.php on line 200
PHP Warning: socket_recvfrom(): unable to recvfrom [10060]: ╧юя√Єър єёЄрэютшЄ№ ёюхфшэхэшх с√ыр схчєёях°эющ, Є.ъ. юЄ фЁєуюую ъюья№■ЄхЁр чр ЄЁхсєхьюх тЁхь  эх яюыєўхэ эєцэ√щ юЄъышъ, шыш с√ыю ЁрчюЁтрэю єцх єёЄрэютыхээюх ёюхфшэхэшх шч-чр эхтхЁэюую юЄъышър єцх яюфъы■ўхээюую ъюья№■ЄхЁр.
in C:\_majordomo\htdocs\modules\dev_broadlink\broadlink.class.php on line 553
Сообщение xor » Вт янв 30, 2018 9:01 pm
Перевод
socket_recvfrom(): unable to recvfrom [10060]: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Что-то с модулем broadlink
553 строка $ret = socket_recvfrom($cs, $response, 2048, 0, $from, $port);
Экспортируйте команды бродлинка, деинсталлируйте этот модуль, перезагрузитесь. (Это если в панель управления можно войти)
Сообщение xor » Вт янв 30, 2018 9:14 pm
ошибка в mysqli:
* Execute SQL SELECT query and return all records
* This method returns records as array of assosiated arrays (by field names)
* @param string $query SQL SELECT query
* @return array execution result
* @access public
public function Select($query)
if (!$this->connected) return false;
$res = array();
if ($result = $this->Exec($query))
while ($rec = mysqli_fetch_array($result, MYSQL_ASSOC)) // 200 error!
$res[] = $rec;
else
$this->Error($query,0);
return $res;
попытка выполнить запрос из бродлинка.
стоит посмотреть таблицы бродлинка в базе dev_broadlink_commands, dev_httpbrige_devices.
У автора модуля можете проконсультироваться ( nick7zmail)
zoto (Чт фев 01, 2018 2:53 pm)
zoto
Сообщение zoto » Чт фев 01, 2018 2:53 pm
здравствуйте, товарищи
зайти в панель управления НЕ возможно, соответственно деинсталировать модуль броадлинка не могу,
"Экспортируйте команды бродлинка" - если можно объясните подробнеее, как это сделать
"стоит посмотреть таблицы бродлинка в базе dev_broadlink_commands, dev_httpbrige_devices."
подскажите, что в них искать, если можно?
Заранее спасибо.
NiKiToS
Сообщение NiKiToS » Пт фев 02, 2018 12:27 pm
В последнем обнавлении МЖД есть ошибка системы,я тоже долго ковырялся с этим,переустанавливал не раз МЖД и даже windows что бы понять где ошибка,но так и не понял,обратился к Сергею,должны вместе посмотреть в чем дело...
За это сообщение автора NiKiToS поблагодарил:
TrDA (Сб фев 03, 2018 10:41 am)
webms
Сообщение webms » Вс июн 09, 2019 5:56 pm
после обновления МД тоже появилась ошибка
Warning: socket_recvfrom(): unable to recvfrom [10054]: ��������� ���� ������������� �������� ������������ �����������. in C:\_majordomo\htdocs\modules\dev_broadlink\broadlink.class.php on line 566 Fatal error: Uncaught Error: Call to undefined method SP1::Send_data() in C:\_majordomo\htdocs\lib\brlink_command.php:10 Stack trace: #0 C:\_majordomo\htdocs\lib\brlink_command.php(18): brLinkRawCommand(NULL, NULL) #1 C:\_majordomo\htdocs\modules\scripts\scripts.class.php(151) : eval()'d code(59): brLinkCommand(NULL) #2 C:\_majordomo\htdocs\modules\scripts\scripts.class.php(151): eval() #3 C:\_majordomo\htdocs\lib\common.class.php(682): scripts->runScript('AutoTempCondeti...', Array) #4 C:\_majordomo\htdocs\objects\index.php(177): runScript('AutoTempCondeti...', Array) #5 {main} thrown in C:\_majordomo\htdocs\lib\brlink_command.php on line 10
куда копать?
Сообщение Logrus » Вс июн 09, 2019 7:53 pm
куда копать?
а данный модуль удален?
Почти всё время уходит на исправление ошибок, оставшееся - на их повторение. (с) ))) Спасибо - ТАМ =>
connect Raspberry Pi3, с образа от Сергея 3.31, PHP 7
webms
Сообщение webms » Пн июн 10, 2019 8:29 am
неа, странно, из скрипта выводил ошибку, а если запустить напрямую brLinkCommand() то все ок
в итоге я запустил вручную все команды и теперь даже из скрипта все работает
чудеса
Nobody
Сообщение Nobody » Сб июл 13, 2019 7:32 pm
Вот такая ошибка появилась, у некоторых модулей статус стал "цикл остановлен", появилось недавно, система и УД свежие, ставилось все недели 2-3 назад, убунту, если что... Что делать?))
Сообщение tarasfrompir » Сб июл 13, 2019 8:14 pm
https://connect.smartliving.ru/profile/ ... row-1.html
