[Модуль] Sonoff (dev_sonoff)
Есть признаки "оживления"? Или я всё сломал? =D
klv666
Сообщение klv666 »
nick7zmail писал(а): Пн май 27, 2019 5:03 pm Есть признаки "оживления"? Или я всё сломал? =D
Включал, выключал, включал... и т.д. один и тот же канал, свет не реагировал
дебагSPOILER_SHOW
21:09:33 0.78035600 [wss] +++ pong
21:09:33 0.60734600 [wss] --- ping
21:09:11 0.59408700 [wss] +++ {"action":"update","deviceid":"100050477d","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","userAgent":"device","ts":0,"params":{"init":1,"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}],"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"fwVersion":"2.7.1","rssi":-58,"staMac":"DC:4F:22:DE:AD:1D","pulse":"off","pulseWidth":500},"from":"device"}
21:09:10 0.59003000 [wss] +++ {"action":"sysmsg","deviceid":"100050477d","apikey":"c97cd2e2-6053-45dc-bbd5-ab5a7bd74b09","ts":0,"params":{"online":true}}
21:09:01 0.11248800 [wss] +++ {"action":"sysmsg","deviceid":"100050477d","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","ts":0,"params":{"online":false}}
21:08:56 0.75623800 [wss] +++ {"action":"update","deviceid":"100050477d","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","userAgent":"device","ts":0,"params":{"rssi":-58},"from":"device"}
21:08:31 0.03076700 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"oqXnzEGq","apkVesrion":"1.8","os":"ios","at":"a8f8829bf25f52b708cc0320cee8e2e38653cb25","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","ts":1558966111,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1558966111000}
21:08:30 0.31272600 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":null,"params":{"switches":[{"outlet":2,"switch":"on"}]},"sequence":1558966110000}
21:08:06 0.89338600 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":"100046940b","params":{"switches":[{"outlet":2,"switch":"off"}]},"sequence":1558966086000}
21:08:06 0.70537600 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"pAwgvI7l","apkVesrion":"1.8","os":"ios","at":"a8f8829bf25f52b708cc0320cee8e2e38653cb25","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","ts":1558966086,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1558966086000}
21:08:05 0.97133400 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":null,"params":{"switches":[{"outlet":2,"switch":"off"}]},"sequence":1558966085000}
21:07:56 0.75380600 [wss] +++ {"action":"update","deviceid":"100050477d","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","userAgent":"device","ts":0,"params":{"rssi":-55},"from":"device"}
21:07:38 0.48076100 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":"100046940b","params":{"switches":[{"outlet":0,"switch":"on"}]},"sequence":1558966058000}
21:07:38 0.30375100 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":null,"params":{"switches":[{"outlet":0,"switch":"on"}]},"sequence":1558966058000}
21:07:38 0.11474000 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"q73zgrJO","apkVesrion":"1.8","os":"ios","at":"a8f8829bf25f52b708cc0320cee8e2e38653cb25","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","ts":1558966058,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1558966058000}
21:07:37 0.37069800 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":null,"params":{"switches":[{"outlet":0,"switch":"on"}]},"sequence":1558966057000}
21:07:31 0.07433800 [wss] +++ pong
21:07:30 0.87732600 [wss] --- ping
Признаки есть, на другом 4про, 2 канала работают)))
Вот с работающего канала - включил, выключил
дебагSPOILER_SHOW
21:14:53 0.31663200 [wss] +++ {"action":"update","deviceid":"100046a384","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","userAgent":"app","sequence":"1558966491000","ts":0,"params":{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]},"tempRec":"100046a384"}
21:14:52 0.13556500 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"g0vJ1csy","apkVesrion":"1.8","os":"ios","at":"a8f8829bf25f52b708cc0320cee8e2e38653cb25","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","ts":1558966492,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1558966492000}
21:14:51 0.38552200 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":"100046a384","params":{"switches":[{"outlet":1,"switch":"off"}]},"sequence":1558966491000}
21:14:41 0.07093200 [wss] +++ {"action":"update","deviceid":"100046a384","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","userAgent":"app","sequence":"1558966478000","ts":0,"params":{"switches":[{"switch":"off","outlet":0},{"switch":"on","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]},"tempRec":"100046a384"}
21:14:40 0.31188900 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"rcq7a1IR","apkVesrion":"1.8","os":"ios","at":"a8f8829bf25f52b708cc0320cee8e2e38653cb25","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","ts":1558966480,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1558966480000}
21:14:38 0.56378900 [wss] --- {"action":"update","userAgent":"app","apikey":"110e511c-ab79-4430-9485-26b6cfeb5e27","deviceid":"100046a384","params":{"switches":[{"outlet":1,"switch":"on"}]},"sequence":1558966478000}
Кое что работает. Из трех 4про: 1 работает, 1 не работает и у одного не работает 1 канал. Еще 2х каналный выключатель заработал
Еще "эхо" иногда появляется
samolet
Сообщение samolet »
статусы приходят , команды в игноре, с телефона все ок, с мажоры хрен
yii
Сообщение yii »
РАБОТАЕТ!!!
Но я удалил старый модуль (проверил что папка удалилась), удалил таблицы модуля.
Сразу тоже не заработало
Сейчас еще 3х кальный настрою, посмотрю, на 2х работают оба, 4х у меня нет
UPD: на 3х тоже работают все каналы
Последний раз редактировалось yii Пн май 27, 2019 6:02 pm, всего редактировалось 1 раз.
yii
Сообщение yii »
samolet писал(а): Пн май 27, 2019 5:32 pm статусы приходят , команды в игноре, с телефона все ок, с мажоры хрен
а цикл запущен?
klv666
Сообщение klv666 »
yii писал(а): Пн май 27, 2019 5:52 pm РАБОТАЕТ!!!
Удалили и заново поставили? Подскажите что еще надо удалить кроме модуля в разделе маркет..?
Если статусы приходят - то запущен. То что не уходят - это уже в другом месте смотреть надо. Перезагрузите на всякий случай малину с мажориком.
klv666 писал(а): Пн май 27, 2019 6:01 pm Удалили и заново поставили? Подскажите что еще надо удалить кроме модуля в разделе маркет..?
Таблицы, если не удалились, в phpmyadmin.
yii
Сообщение yii »
Этого как бы достаточно, но я проверил что модуль действительно удалился (что его нет в папке modules) и таблицы dev_sonoff_* модуль насколько помню удаляет сам, но я их удалил руками еще до удаления модуля (это в phpmyadmin делается) :)
А че за 3х канальный?)) Touch что ли?
samolet
Сообщение samolet »
Неееее, ну его нафик, если я удалю модуль то капец работенки прибавится, я лучше старые файля сейчас все заменю и обновлю. Обновил ни чего не изменилось
Последний раз редактировалось samolet Пн май 27, 2019 6:25 pm, всего редактировалось 1 раз.
