Модуль работы с Z-Wave устройствами
Bagir
Re: Модуль работы с Z-Wave устройствами
Сообщение Bagir »
Да, конечно! Вот по этой ссылке как раз
http://localhost:8083/ZWaveAPI/Run/devi ... tate.value
ответ будет число 255. Это значение value.
Или если надо сразу все 6 групп, то так:
http://localhost:8083/ZWaveAPI/Run/devi ... larmSensor
ответSPOILER_SHOW
{"supported":true,"name":"AlarmSensor","data":{"name":"devices.19.instances.0.commandClasses.156.data","type":"NoneType","value":null,"updateTime":1410993460,"invalidateTime":1410993459,"version":{"name":"version","type":"int","value":1,"updateTime":1410993461,"invalidateTime":1410993460},"security":{"name":"security","type":"bool","value":false,"updateTime":1410993460,"invalidateTime":1410993459},"interviewDone":{"name":"interviewDone","type":"bool","value":true,"updateTime":1410993463,"invalidateTime":1410993459},"interviewCounter":{"name":"interviewCounter","type":"int","value":9,"updateTime":1410993462,"invalidateTime":1410993459},"alarmMap":{"name":"alarmMap","type":"int","value":33,"updateTime":1410993463,"invalidateTime":1410993459},"alarms":{"name":"alarms","type":"NoneType","value":null,"updateTime":1410993460,"invalidateTime":1410993459},"0":{"name":"0","type":"NoneType","value":null,"updateTime":1410993464,"invalidateTime":1411860768,"srcId":{"name":"srcId","type":"int","value":19,"updateTime":1411861633,"invalidateTime":1410993463},"sensorState":{"name":"sensorState","type":"int","value":255,"updateTime":1411861633,"invalidateTime":1410993463},"sensorTime":{"name":"sensorTime","type":"int","value":0,"updateTime":1411861633,"invalidateTime":1410993463}},"5":{"name":"5","type":"NoneType","value":null,"updateTime":1410993464,"invalidateTime":1411860768,"srcId":{"name":"srcId","type":"int","value":19,"updateTime":1411860808,"invalidateTime":1410993463},"sensorState":{"name":"sensorState","type":"int","value":0,"updateTime":1411860808,"invalidateTime":1410993463},"sensorTime":{"name":"sensorTime","type":"int","value":0,"updateTime":1411860808,"invalidateTime":1410993463}}},"id":156}
Это пример датчика протечки. У него из 6 групп есть только 0-General и 5-Flood.
К примеру у датчика дыма есть три группы. Их можно видеть в топике обзора на него.
Bagir
Сообщение Bagir »
Сергей, это конечно наверное нагло с моей стороны просить, но может сразу и 43 класс добавите. Он очень маленький и нужен для брелков и выключателей. И похоже как пока что нужен только мне одному. Но в будущем конечно должен пригодиться и остальным. Ответ браузера и описание я обновил в обзорном топике на брелок http://smartliving.ru/forum/viewtopic.p ... 921#p13921
В будущем я уверен, что сумею помогать в разработке системы не только идеями, но и работой. А пока что мне сложновато въехать в написанный код. В структуре файлов z-Wave я разобрался, но многое еще не ясно.
Добавил поддержку класса Alarm и класса контроллера сцены (пультов). В последнем читаю свойство CurrentScene -- возможно не то, что нужно, так что надо тестировать.
Для добавления новых свойств надо нажать на сканирование сети -- уже настроенные связи останутся и добавяться новые свойства.
Bagir
Сообщение Bagir »
Аларм отлично настроился. Сразу получаю в объект свойство тревоги. Вечерком обновлю обзоры датчика дыма и протечки, и можно будет считать их законченными.
А пульт и выключатель не обновляет свое свойство, пока не зайдешь в настройки Z устройств в МД, и не откроешь его (где линкуем свойства). Вероятно в этот момент происходит повторный опрос.
Пульт ведет себя несколько по другому. Ранее я на это просто не обратил внимание. Если посмотреть на тот же датчик протечки, то при опускании его в воду, мы сразу увидим
где 19 это id датчика протечки. Такое можно наблюдать со всеми устройствами в момент передачи ими данных. А теперь посмотрим, что будет, если нажать на кнопку пульта:
2 это id стика (usb свистка - главного контроллера сети)
а id пульта 28. Но его тут нет. Соответственно и свойство само не обновляется. Пока что это все наблюдения. Будем копать.
Можно попробовать в файле ./modules/zwave/zwave.class.php
после строчки
echo "Unknown device (".$m[0].")\n";
добавить
echo serialize($v);
перезапустить циклы и посмотреть что будет выдаваться -- возможно там "выщемим" код пульта
Bagir
Сообщение Bagir »
Сейчас сделаю!
Bagir
Сообщение Bagir »
Ну задачка. Вот, посмотрите сами, может на что глаз упадет:
id выключателя 29
id пульта 28
Но этих цифр тут нет.
Сначала нажал на кнопку выключателя. Затем сразу на кнопку пульта. Отличия есть, но выключатель настроен "из коробки", а пульт я настроил на запуск сцен. Сейчас для чистоты эксперимента, я настрою выключатель точно так же как и пульт и все повторю.
Bagir
Сообщение Bagir »
Настроил выключатель так же на запуск сцен, и теперь по записям даже нельзя понять, какой выключатель был нажат
instances.<цифра> зависит от кнопки. 1-4. А 0 всегда сопутствует. Видимо чтобы увидеть повторное нажатие той же кнопки.
Дело ясное, что дело темное. Если есть идеи, пишите! Пока буду копать вслепую.
Возможно нажатие кнопки на пульте меняет текущую сцену, которая хранится в общем контроллере сети. В таком случае, нужно будет делать привязку к этому свойству для устройства типа контроллер, а не для пульта.
Bagir
Сообщение Bagir »
Я тоже так подумал. В пользу этого предположения еще факт отсутствия этого класса в интервью пульта и выключателя. Возможно действительно надо смотреть в сторону свойств контроллера.
И еще грабли: Допустим мы нажали на кнопку 1.
http://localhost:8083/ZWaveAPI/Run/devi ... cene.value приняло значение 11. Мы увидим, что значение поменялось на 11, и поймем что нажата кнопка кнопка 1.
А вот если второй раз нажать на кнопку 1, то поллингом этого адреса мы уже ничего не увидим, т.к. значение как было 11, так таким и осталось. Следовательно, нам нужен сигнал о том, что было совершено действие с кнопками, а какое именно мы уже и поймем по этому значению value.
Но получается так, что и выключатель и пульт шлют одинаковые данные, и понять кто это прислал с помощью анализа echo serialize($v); невозможно. Придется как то подбивать клинья к контроллеру. Что то как то за мудрили zеторубы в этом вопросе... Но есть лазейка. Можно смотреть свойство updateTime, и сравнивать его с предыдущим. Так мы можем понять, что была нажата та же кнопка, если value не изменилось.
Вообще я слышал, что они собираются в корне переделать ПО, работающее по http://localhost:8083. И что даже там будут возможности указать GET запросы, чтобы не нужно было делать поллинг. Ну как бы это конечно правильно. Непонятно только куда смотрели до сих пор. Я вообще думал, что Z тема давно выглажена, чиста и прозрачна. А тут оказывается еще не вспаханное поле для творчества. Ну может быть даже так интересней..
