Re: Samsung Smart TV
Добавлено: Сб апр 02, 2016 9:41 pm
Добрый день.
до 55000 порта не достучаться.
вот ответ:
вот ответ:
//error_reporting(E_ALL);
$tvip = IP ТВ
$myip = IP сервера
$mymac = MAC сервера
$appstring = "iphone..iapp.samsung"; //оставляем
$tvappstring = "iphone.UE46F6800.iapp.samsung"; //я вставил свою модель
$remotename = "Perl Samsung Remote"; //ќставл¤ем
echo "Content-type: text/html\n\n";
$sock = socket_create(AF_INET, SOCK_STREAM, getprotobyname('tcp'));
$result = socket_connect($sock, $tvip, '55000');
if( $result === false)
die ("Could not create socket: \n");
//Normal remote keys
//KEY_0
//KEY_1
//KEY_2
//KEY_3
//KEY_4
//KEY_5
//KEY_6
//KEY_7
//KEY_8
//KEY_9
//KEY_UP
//KEY_DOWN
//KEY_LEFT
//KEY_RIGHT
//KEY_MENU
//KEY_PRECH
//KEY_GUIDE
//KEY_INFO
//KEY_RETURN
//KEY_CH_LIST
//KEY_EXIT
//KEY_ENTER
//KEY_SOURCE
//KEY_AD
//KEY_PLAY
//KEY_PAUSE
//KEY_MUTE
//KEY_PICTURE_SIZE
//KEY_VOLUP
//KEY_VOLDOWN
//KEY_TOOLS
//KEY_POWEROFF
//KEY_CHUP
//KEY_CHDOWN
//KEY_CONTENTS
//KEY_W_LINK //Media P
//KEY_RSS //Internet
//KEY_MTS //Dual
//KEY_CAPTION //Subt
//KEY_REWIND
//KEY_FF
//KEY_REC
//KEY_STOP
//Bonus buttons not on the normal remote:
//KEY_TV
//Don't work/wrong codes:
//KEY_CONTENT
//KEY_INTERNET
//KEY_PC
//KEY_HDMI1
//KEY_OFF
//KEY_POWER
//KEY_STANDBY
//KEY_DUAL
//KEY_SUBT
//KEY_CHANUP
//KEY_CHAN_UP
//KEY_PROGUP
//KEY_PROG_UP
$ipencoded = base64_encode($myip);
$macencoded = base64_encode($mymac);
$messagepart1 = chr(0x64) . chr(0x00) . chr(strlen($ipencoded)) . chr(0x00) . $ipencoded . chr(strlen($macencoded)) . chr(0x00) . $macencoded .
chr(strlen(base64_encode($remotename))) . chr(0x00) . base64_encode($remotename);
$part1 = chr(0x00) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart1)) . chr(0x00) . $messagepart1;
socket_write($sock, $part1, strlen($part1));
echo $part1;
echo "\n";
$messagepart2 = chr(0xc8) . chr(0x00);
$part2 = chr(0x00) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart2)) . chr(0x00) . $messagepart2;
socket_write($sock, $part2, strlen($part2));
echo $part2;
echo "\n";
//Preceding sections all first time only
if (isset($_REQUEST["key"])) {
//Send remote key
$key = "KEY_" . $_REQUEST["key"];
$messagepart3 = chr(0x00) . chr(0x00) . chr(0x00) . chr(strlen(base64_encode($key))) . chr(0x00) . base64_encode($key);
$part3 = chr(0x00) . chr(strlen($tvappstring)) . chr(0x00) . $tvappstring . chr(strlen($messagepart3)) . chr(0x00) . $messagepart3;
socket_write($sock,$part3,strlen($part3));
echo $part3;
echo "\n";
} else if (isset($_REQUEST["text"])) {
//Send text, e.g. in YouTube app's search, N.B. NOT BBC iPlayer app.
$text = $_REQUEST["text"];
$messagepart3 = chr(0x01) . chr(0x00) . chr(strlen(base64_encode($text, ""))) . chr(0x00) . base64_encode($text, "");
$part3 = chr(0x01) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart3)) . chr(0x00) . $messagepart3;
echo $part3;
echo "\n";
socket_close($sock);
echo "\n\n";
?>Мне свой UE40H6203AK так и не удалось завести. Железо у них похожее. Управляю по ик через broadlink RM. Я че ток не делал, и порты менял, и файлы разные пробовал из данной темы. Прикол в том, что к нему не каждое приложение из плэй-маркета конектится. Мне удалось подключить только одно, но я не помню какое, и не помню как...повторно найти не получилось. Может у нас протокол другой, или способ авторизации в этой серии, или что, я хз.Michael писал(а):Уважаемые господа форумчане, подскажите тема по самсунгу умерла?
А так хочется подключить свой телек
Из материалов выше ничего не заработало модель телека UE40H5500
nick7zmail писал(а):Michael писал(а): Если получится подключить - обязательно поделитесь как. Для начала попробуйте поиграться с портами. Вместо 55000, предложенного в 1м посте - 7676, 52235 и ещё какой то я находил на забугорных форумах.
Основная задача - сделать так, чтобы телик выдал запрос - типа кто-то пытается подключится. У меня, как я и говорил, не получилось.
У меня винда сругнулась на то что там тип вирус...еще не разу такого от винды не видел))Maxipro писал(а):Может эта ссылка оживит тему?
http://luck.moy.su/forum/8-41-1
Там прога, которая по зваверениям автора, беспроблемно позволяет управлять несколькими разными сериями тв самсунг по сети с компа. Может это натолкнет наших гениев на какие-нибудь мысли для дальнейшего движения в этом направлении?
