#include "RF24.h"
// nRF24L01 modul configuration
//RF24 radio(0, 2); // CE, CSN pins для ESP8266 с SD картой
RF24 radio(34, 35); // CE, CSN pins для ESP32
byte addresses[][6] = {"1Node", "2Node"}; Код: Выделить всё
#include <SPI.h>
#include "RF24.h" Код: Выделить всё
#include "esp32-hal-spi.h" - AMS for ESP32 SD started...
Module Random... started
Module EEPROM (NVS)...
Address: 186
Module Hardware...
Arduino IDE: 1.6.5
SDK version: v2.0-rc1-803-g1e0710f1
Chip revision: 0
Chip ID: 0CE903A4AE30
CPU freq: 240 MHz
Free memory: 204532 (71%)
Flash mode: 2
Flash speed: 80 MHz
Flash size: 4194304
Self temp: 37.2 C
Module Wi-Fi...
Connecting to mega ..
WiFi: connected
IP address: 192.168.2.70
Module SD...
Init: OK
Type: SDHC
Check: ..................
Files: 187
Total: 19454068 B
Empty: 3
Index: found
Module NTP...
Server: 129.6.15.30
Port: 123
Module Time...
Provider: network
NTP request: OK
2017-07-22 22:26:19 Module Server... started
2017-07-22 22:26:19 Module Upload... started
2017-07-22 22:26:19 Module Send... started
2017-07-22 22:26:19 Parasite power ON
2017-07-22 22:26:19 Found 1 devices
2017-07-22 22:26:19 #0: 40 26 27 42 7 0 0 tempSTR
2017-07-22 22:26:19 #1: 40 26 27 42 7 0 0 tempHOM
2017-07-22 22:26:19 #2: 40 26 27 42 7 0 0 tempWRM
2017-07-22 22:26:19 Module Temp... started
2017-07-22 22:26:19 Module Contacts... started
2017-07-22 22:26:19 Module PIR... started
2017-07-22 22:26:19 Module LED... started
2017-07-22 22:26:19 Module Keys... started
2017-07-22 22:26:19 Module Robotdyn... started
2017-07-22 22:26:19 Module DHT... started
2017-07-22 22:26:19 Base Receiving
2017-07-22 22:26:19 Module nRF24... started
GLOBAL Init DONE (17s)
AMS WORK
2017-07-22 22:26:19 : 132864 (46%) 132864
2017-07-22 22:26:21 tempSTR: 29.12
2017-07-22 22:26:21 tempHOM: 29.12
2017-07-22 22:26:21 tempWRM: 29.12
Request: -> 2 1 0 255 1 0 0 0 0
SEND FAILED
?esp=1
TRY: 1
SEND FAILED
?esp=1
Request: -> 2 100 0 255 1 0 0 0 0
SEND FAILED
TRY: 2
SEND FAILED
TRY: 1
SEND FAILED
2017-07-22 22:26:30 tempSTR: 29.12
2017-07-22 22:26:30 tempHOM: 29.12
2017-07-22 22:26:30 tempWRM: 29.12
?esp=1
TRY: 3
SEND FAILED
SEND 1 ERROR
TRY: 2
SEND FAILED
Request: -> 2 4 0 255 1 0 0 0 0
SEND FAILED
?esp=1
TRY: 3
SEND FAILED
SEND 100 ERROR
TRY: 1
SEND FAILED
TRY: 2
SEND FAILED
Request: -> 2 7 0 255 1 0 0 0 0
SEND FAILED
?esp=1
TRY: 3
SEND FAILED
2017-07-22 22:26:50 tempSTR: 29.19
2017-07-22 22:26:50 tempHOM: 29.19
2017-07-22 22:26:50 tempWRM: 29.19
?esp=1
TRY: 3
Request: -> 2 9 0 255 1 0 0 0 0
SEND FAILED
SEND 9 ERROR
Humidity: 41.00 % Temperature: 29.00 *C
Self temp: 41.1 C
Request: -> 2 100 0 255 1 1 0 0 0
