http://blynk-cloud.com/<ваш_токен>/project Если там есть "конфидициальная информация" (имя проекта, токен, ещё че нить - можете удалить, мне главное раздел виджетов не трогать))
http://blynk-cloud.com/<ваш_токен>/project Код: Выделить всё
{"id":1255555114,"parentId":-1,"isPreview":false,"name":"ESP8266zal","createdAt":1499942234155,"updatedAt":1500019787375,"widgets":[{"type":"BUTTON","id":158766,"x":0,"y":0,"color":600084223,"width":2,"height":2,"tabId":0,"label":"Свет","isEnabled":true,"isDefaultColor":true,"deviceId":0,"pinType":"DIGITAL","pin":15,"pwmMode":true,"rangeMappingOn":false,"min":0,"max":1,"value":"0","pushMode":true},{"type":"LCD","id":134796,"x":0,"y":2,"color":600084223,"width":8,"height":2,"tabId":0,"isEnabled":true,"isDefaultColor":true,"deviceId":0,"pins":[{"pin":2,"pwmMode":false,"rangeMappingOn":false,"pinType":"VIRTUAL","value":"46.200","min":0,"max":100},{"pin":3,"pwmMode":false,"rangeMappingOn":false,"pinType":"VIRTUAL","value":"26.500","min":-40,"max":80}],"advancedMode":false,"textFormatLine1":"Влажность /pin0./%","textFormatLine2":"Температура /pin1/°","textLight":false,"frequency":60000},{"type":"LCD","id":91212,"x":0,"y":4,"color":600084223,"width":8,"height":2,"tabId":0,"isEnabled":true,"isDefaultColor":true,"deviceId":0,"pins":[{"pin":4,"pwmMode":false,"rangeMappingOn":false,"pinType":"VIRTUAL","value":"66.400","min":0,"max":100},{"pin":5,"pwmMode":false,"rangeMappingOn":false,"pinType":"VIRTUAL","value":"19.700","min":-40,"max":80}],"advancedMode":false,"textFormatLine1":"Влажность /pin0./%","textFormatLine2":"Температура /pin1/°","textLight":false,"frequency":60000}],"devices":[{"id":0,"name":"ESP8266zal","boardType":"NodeMCU","token":"МОЙ ТОКЕН","connectionType":"WI_FI","status":"ONLINE","disconnectTime":1500012376938,"lastLoggedIP":"91.196.193.12"}],"theme":"Blynk","keepScreenOn":false,"isAppConnectedOn":false,"isShared":false,"isActive":true,"hardwareInfo":{"version":"0.4.8","boardType":"NodeMCU","buildDate":"Jul 13 2017 22:28:56","heartbeatInterval":10}} =) wifi-iot Изначально как-то мне не понравилась...как минимум интерфейсом и платными ограничениями...igorewa писал(а):Вчера специально поехал купил esp для экспериментов и впервые столкнулся со скетчами. Но уверено могу сказать прощай wifi-iot ! да здравствует Blynk ! ))
А вот тут нужно поподробнее ) в идеале инструкцию а еще лучше видео ролик )) А то не очень удобно постоянно делать вот такnick7zmail писал(а): я в МД передаю какие-то данные по http-ссылке (виджет webhook) - понадобилось поменять ссылку (поменять связанный объект к примеру), дак зашел в приложение, и прямо в приложении исправил ссылку...никаких отключений/подключений, перепрошивок, всё чисто из приложения)) это ж реально шикарно =D.
