Re: Образ для OrangePi PC,OrangePi Plus,OrangePi 2,OrangePi
Добавлено: Вс июн 04, 2017 8:17 am
На Orange Pi Zero образ DietPi MD 148 не запускается сразу загораются светодиоды на сетевом адаптере и все. Script.bin менял
Обсуждение проекта
https://mjdm.ru/forum/
#!/bin/bash
backtitle="Armbian EMMC backup script, http://www.armbian.com | Author: nopnop2002"
title="Backup from EMMC to Image File"
logfile="/tmp/dd.log"
imgfile="/var/images/emmc.img.7z"
sleeptime=10
debugout="/tmp/debug.log"
function DebugEcho() {
if [ $1 = '-n' ]; then
echo -n $2 >> ${debugout}
else
echo $1 >> ${debugout}
fi
# Get copied size
function GetCopied() {
pid=`ps -ef | grep "dd if=" | grep -v grep | awk '{print $2}'`
# echo -n "pid="
# echo $pid
kill -USR1 $pid
# tail -1 /tmp/dd.log
# echo -n "/tmp/dd.log="
if [ -s ${logfile} ]; then
# tail -1 /tmp/dd.log | awk '{print $1}'
# copied=`tail -1 /tmp/dd.log | awk '{print $1}'`
copied=`tail -1 ${logfile} | awk '{print $1}'`
copied=`expr ${copied} \* 100`
else
copied=0
fi
# DebugEcho -n "copied="
# DebugEcho $copied
# Get progress
function GetProgress() {
DebugEcho $copied
DebugEcho -n "emmcbyte="
DebugEcho $emmcbyte
progress=`expr ${copied} / ${emmcbyte}`
if [ ${progress} -gt 100 ]; then
progress=100
fi
# Check root user
if [ "$UID" -ne 0 ]; then
dialog --title "$title" --backtitle "$backtitle" \
--infobox "\nMust be root" 5 60
exit 1
fi
# Check p7zip install
p7zip=`dpkg -l | grep p7zip | wc -l`
if [ $p7zip == 0 ]; then
--infobox "\np7zip not installed" 5 60
exit 1
fi
# Check EMMC partition
emmc=`cat /proc/partitions | grep -c mmcblk1`
#echo -n "emmc="
#echo $emmc
if [ $emmc == 0 ]; then
--infobox "\n/dev/mmcblk1 not found" 5 60
exit 1
fi
# Check image file exist
if [ -f ${imgfile} ]; then
--yes-label "Ok" --no-label "No" --yesno \
"\n${imgfile} is already exist. purge ok?" 7 60
if [ $? -eq 1 ]; then exit 1; fi
rm ${imgfile}
fi
# Get EMMC size
#cat /proc/partitions | grep mmcblk1 | head -1 | awk '{print $3}'
emmcbyte=`cat /proc/partitions | grep mmcblk1 | head -1 | awk '{print $3}'`
#echo $emmcbyte
emmcbyte=`expr ${emmcbyte} \* 1024`
#echo $emmcbyte
emmcmegabyte=`expr ${emmcbyte} / 1000000`
#echo $emmcmegabyte
# Create working directory
if [ ! -d /var/images ]; then
mkdir /var/images
fi
# Delete log file
if [ -f ${logfile} ]; then
rm ${logfile}
fi
# Start dd with background
(dd if=/dev/mmcblk1 bs=10M | 7zr a -bd -t7z -m0=lzma -mx=9 -mfb=64 -md=32m -ms=on -si ${imgfile}) &> /tmp/dd.log &
# Display progress screen
begin_date=`date +%s`
active=1
while [ $active == 1 ]
do
# ps -ef | grep "dd if=" | grep -v grep | wc -l
active=`ps -ef | grep "dd if=" | grep -v grep | wc -l`
DebugEcho -n "active="
DebugEcho $active
if [ $active == 1 ]; then
GetCopied
GetProgress
DebugEcho -n "progress="
DebugEcho $progress
echo $progress | dialog --title "$title" --backtitle "$backtitle" \
--gauge "\n\nCreating EMMC backup image (${emmcmegabyte} Mb). Please wait!" 10 80
fi
sleep ${sleeptime}
done
# Finish
end_date=`date +%s`
total=`expr $end_date - $begin_date`
min=`expr $total / 60`
sec=`expr $total % 60`
--msgbox "\nAll done.Elapsed time (${min}Min.${sec}Sec.)" 7 60
(cd /tmp/1; tar --backup -c *) |tar -C /tmp/2 -xvdirectman66 писал(а):Коллеги, я перенес систему с карты памяти во внутреннюю память emmc с помощью nand-sata-install, настроил и т.д. Как обратно перенести настроенную систему на карту памяти?
При чем тут раздел u-boot? На сколько я понимаю загрузчик пытается сначала с SD грузиться а потом с emmc.directman66 писал(а):на emmc я так понял нет раздела u-boot. С карты не загрузиться же.
