Re: [Модуль] Погода от Openweather
Да, это к серверу достучаться не может. Бывает иногда. Особенно если мусор от модуля в onnewhour остался и он по 5-10 запросов одновременно делает.
не мусора нет, еще совсем редко, несколько раз в то что пишется в историю температура, давление, влажность нули прилетали
[Sat Mar 10 08:10:23.983816 2018] [:error] [pid 21956] [client 192.168.137.1:1104] PHP Warning: fopen(/var/www/html/debmes/2018-03-10_undefined.log): failed to open stream: No such file or directory in /var/www/html/lib/general.class.php on line 175, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
[Sat Mar 10 08:10:23.983999 2018] [:error] [pid 21956] [client 192.168.137.1:1104] PHP Warning: filesize(): stat failed for /var/www/html/debmes/2018-03-10_undefined.log in /var/www/html/lib/general.class.php on line 177, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
[Sat Mar 10 08:10:29.076482 2018] [:error] [pid 22110] [client 192.168.137.1:1105] PHP Warning: fopen(/var/www/html/debmes/2018-03-10_undefined.log): failed to open stream: No such file or directory in /var/www/html/lib/general.class.php on line 175, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
[Sat Mar 10 08:10:29.076660 2018] [:error] [pid 22110] [client 192.168.137.1:1105] PHP Warning: filesize(): stat failed for /var/www/html/debmes/2018-03-10_undefined.log in /var/www/html/lib/general.class.php on line 177, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
[Sat Mar 10 08:10:34.135077 2018] [:error] [pid 24370] [client 192.168.137.1:1106] PHP Warning: fopen(/var/www/html/debmes/2018-03-10_undefined.log): failed to open stream: No such file or directory in /var/www/html/lib/general.class.php on line 175, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
[Sat Mar 10 08:10:34.135256 2018] [:error] [pid 24370] [client 192.168.137.1:1106] PHP Warning: filesize(): stat failed for /var/www/html/debmes/2018-03-10_undefined.log in /var/www/html/lib/general.class.php on line 177, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
[Sat Mar 10 08:10:39.208808 2018] [:error] [pid 22001] [client 192.168.137.1:1110] PHP Warning: fopen(/var/www/html/debmes/2018-03-10_undefined.log): failed to open stream: No such file or directory in /var/www/html/lib/general.class.php on line 175, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
[Sat Mar 10 08:10:39.208985 2018] [:error] [pid 22001] [client 192.168.137.1:1110] PHP Warning: filesize(): stat failed for /var/www/html/debmes/2018-03-10_undefined.log in /var/www/html/lib/general.class.php on line 177, referer: http://192.168.137.13/admin.php?pd=&md= ... penweather
это в логах апача, в логе мдм участилось
PHP Warning: Invalid argument supplied for foreach() in /var/www/html/modules/app_openweather/get_weather.inc.php on line 51
в историю пишется влажность, давление, температура
стало раз в сутки нули прилетать
и народ давайте проголосуем https://connect.smartliving.ru/tasks/20.html
уже не раз
06:53 Алиса: Завтра ожидается -21 градус цельсия, ясно. Слабый ветер, 3 метра в секунду, Западно-юго-западный.
06:53 Алиса: Сегодня утром ожидается -22 градуса цельсия, небольшой снегопад.
06:53 Алиса: Ветра нет.
06:52 Алиса: Относительная влажность 0 процентов. Атмосферное давление пониженное, 0 миллиметров ртутного столба.
06:52 Алиса: Сейчас на улице , температура 0 градусов цельсия, ощущается как 13 градусов цельсия, теплее, чем вчера на 22 градуса.
Никит, что можно сделать, в 6 утра нули прилетели, в 7 все нормально
я так думаю отписаться от хаурли и самому дергать, проверку какую-нибудь???
тут и овм может мудрить и наша метео станция с которой овм получает данные (в Зональном за вагонкой на юг), хз
Хм...вроде в модуле есть проверка пустого массива
if($curWeather!=false && !empty($curWeather))
...можешь попробовать вывести $curWeather в какой нить файл, и посмотреть на ответ. Если выясним причину - будет проще и "принять меры".
а как, что дописать?
я так понимаю это $data = getURL($query); в файл, а как
п.с. ребята в телеге помогли, сенкс, собираю статистику с того что в джсон прилетает
        file_put_contents('/var/www/html/texts/Weather.txt', date('Y-m-d H:i:s') . PHP_EOL, FILE_APPEND);
        file_put_contents('/var/www/html/texts/Weather.txt', $data . PHP_EOL, FILE_APPEND);
        $curWeather = json_decode($data);
Последний раз редактировалось Logrus Пн мар 12, 2018 2:38 pm, всего редактировалось 2 раза.
slgeo
Сообщение slgeo »
Блин, иногда такая неадекватная температура приходит с сервиса, как будто совсем другой город анализирует.
CONNECT
нулей пока не было, но Никита посмотри на закат/рассвет
2018-03-12 16:17:33
{"coord":{"lon":59.97,"lat":57.92},"weather":[{"id":800,"main":"Clear","description":"ясно","icon":"01d"}],"base":"stations","main":{"temp":-6.28,"pressure":1011.42,"humidity":64,"temp_min":-6.28,"temp_max":-6.28,"sea_level":1042.72,"grnd_level":1011.42},"wind":{"speed":2.76,"deg":260.5},"clouds":{"all":0},"dt":1520853304,"sys":{"message":0.0459,"country":"RU","sunrise":1520821440,"sunset":1520863004},"id":520494,"name":"Nizhniy Tagil","cod":200}
2018-03-12 16:18:37
{"coord":{"lon":59.97,"lat":57.92},"weather":[{"id":800,"main":"Clear","description":"ясно","icon":"01d"}],"base":"stations","main":{"temp":-6.28,"pressure":1011.42,"humidity":64,"temp_min":-6.28,"temp_max":-6.28,"sea_level":1042.72,"grnd_level":1011.42},"wind":{"speed":2.76,"deg":260.5},"clouds":{"all":0},"dt":1520853001,"sys":{"message":0.0056,"country":"RU","sunrise":1520821441,"sunset":1520863003},"id":520494,"name":"Nizhniy Tagil","cod":200}
2018-03-12 17:00:04
{"coord":{"lon":59.97,"lat":57.92},"weather":[{"id":800,"main":"Clear","description":"ясно","icon":"01d"}],"base":"stations","main":{"temp":-6.28,"pressure":1011.42,"humidity":64,"temp_min":-6.28,"temp_max":-6.28,"sea_level":1042.72,"grnd_level":1011.42},"wind":{"speed":2.76,"deg":260.5},"clouds":{"all":0},"dt":1520855742,"sys":{"message":0.0041,"country":"RU","sunrise":1520821435,"sunset":1520863008},"id":520494,"name":"Nizhniy Tagil","cod":200}
2018-03-12 18:00:03
{"coord":{"lon":59.97,"lat":57.92},"weather":[{"id":800,"main":"Clear","description":"ясно","icon":"01d"}],"base":"stations","main":{"temp":-6.28,"pressure":1011.42,"humidity":64,"temp_min":-6.28,"temp_max":-6.28,"sea_level":1042.72,"grnd_level":1011.42},"wind":{"speed":2.76,"deg":260.5},"clouds":{"all":0},"dt":1520859387,"sys":{"message":0.0036,"country":"RU","sunrise":1520821428,"sunset":1520863014},"id":520494,"name":"Nizhniy Tagil","cod":200}
А что не так?
я так понимаю это в линукс тайм на восход/закат, но они с каждым разом отличаются на несколько секунд 0_0
