Выключатели LIVOLO
DJ_Technic
Re: Выключатели LIVOLO
Сообщение DJ_Technic »
Вот, что удалось считать с пульта VL-RMT-03
{"name":"vl-rmt-03_1.1_92","data":"b2802a0013060606070507050705070b0c05070b0c0b0705070507050705070507050705070507050705070507050000000000000000000000000000"}
{"name":"vl-rmt-03_1.2_93","data":"b280280014060605060607050705070b0c06070a0c0b070507050705070507050c0b07050705070506060605"}
{"name":"vl-rmt-03_1.3_94","data":"b280260014050606060606060606060b0c06060b0c0b070606060606060606050c0b0c0b0705060507050000"}
{"name":"vl-rmt-03_1.4_95","data":"b280280014050705070507050705070a0c05070a0c0a07050705070507050705070507050c0a070507050705"}
{"name":"vl-rmt-03_1.5_96","data":"b280260014050705070507050705070a0d05070a0c0b070507050705070507050c0a07050c0b070507050000"}
{"name":"vl-rmt-03_Плюс_97","data":"b280260014050706070507050705060b0c06070b0c0b070507050705070507050c06070b0c0b070507050000"}
{"name":"vl-rmt-03_Минус_98","data":"b280260013060606070606050706060a0d06060b0c0b070507050705070507050c0b0c06060b060606050000"}
{"name":"vl-rmt-03_l.1_99","data":"b200260014060605070507060606070b0c06060b0c0b070507050705070507050c06070a0c06070b06050000"}
{"name":"vl-rmt-03_ll.1_100","data":"b200260014050705070507050605070a0c05060b0c0b070507050705070507050c0b0c050705070a07050000"}
{"name":"vl-rmt-03_2.1_102","data":"b280280014050705070507050705070a0c05070a0d0a080507050705070507050c05070a0705070507050605"}
{"name":"vl-rmt-03_2.2_103","data":"b280280014060606060607060705070b0c05070a0c0b0705070507050705070507050d0a0705070507050606"}
{"name":"vl-rmt-03_2.3_104","data":"b180280014060606060606060606060b0c06060b0c0b070507060706060607050705070606060c0b07060605"}
{"name":"vl-rmt-03_2.4_105","data":"b280280013060705060507050606070b0c05070a0c0b0705070507050705070507050c05070b070507050705"}
{"name":"vl-rmt-03_2.5_106","data":"b280280013060606060606060606060b0c06060b0c0b070606060606070507050c060606060b070507060605"}
{"name":"vl-rmt-03_Плюс_107","data":"b280240013060606060507060606060b0c06060b0c0b070507060605070606050c0b0c0b0c0a060600000000"}
{"name":"vl-rmt-03_Минус_108","data":"b280280013060606070507050705070a0d05070b0c0a0705070507050705070507050c060606060b06050705"}
{"name":"vl-rmt-03_l.2_109","data":"b200280013060606060606060606060b0c06060b0c0b060606060706060606060606070507050c06070a0606"}
{"name":"vl-rmt-03_ll.2_110","data":"b200280014050705070507060606070a0c05060b0c0b07050705070507050706070507050c050706070a0605"}
{"name":"vl-rmt-03_Питание_101","data":"b23d2600060705070b0c06070b0c0b070507050705070507050c0b07050c06060b0606140606060705070000"}
1.1-1.5 - выключатели в первой комнате
2.1-2.5 - выключатели во второй комнате
l.1-ll.1 - сценарии в первой комнате
l.2-ll.2 - сценарии во второй комнате
Питание - выключить всё
Вот только срабатывает на эти команды мой старый димер через раз, а с пульта всегда корректно и по командам считанным Catalyst в 90% всегда срабатывает.
Было бы здорово реализовать подачу длинных команд.
П.С. заказал новые выключатели, димеры и выключатель для рольставней LIVOLO - будет с чем экспериментировать.
Попробуйте переставить саму голову RM. Может неблагоприятное расположение магнитных полей.
DJ_Technic
Пробовал поставить даже вплотную к выключателю, результат тот же. Думаю дело в другом, хотя полей я думаю хватает, т.к. дома мышь от ноута очень сильно тупит и пользоваться ей почти не реально, а на работе норм.
Kas-11
Сообщение Kas-11 »
ПОЯВИЛСЯ - LIVOLO шлюз ZIGBEE, C700ZW-12
https://ru.aliexpress.com/item/LIVOLO-W ... 3c00X8sMfm
Сообщение directman66 »
Kas-11 писал(а): Вт дек 04, 2018 10:22 am ПОЯВИЛСЯ - LIVOLO шлюз ZIGBEE, C700ZW-12
Уже подключил. Без их шлюза пока просто безделушка. https://mysku.ru/blog/aliexpress/68804.html
Интеграция через стик пока тоже не возможна https://github.com/Koenkk/zigbee2mqtt/issues/592, но попытки активно ведутся.
andrey040670
Сообщение andrey040670 »
Но нет, (надеюсь пока) димера и rf пульта, без которого я не вижу смысла в жизни :) Пока пускай R серия + BroadLink стоит, будем ждать.
Лойсо Пондохва
Сообщение Лойсо Пондохва »
Имеется Broadlink RM Pro 2+ и куча выключателей Livolo. В модуле Broadlink настроил по 2 команды на выключатель. Одна включает другая выключает. Это всё работает при нажатии на тест. Не могу понять как настроить что бы на панели были кнопочки включатели что бы при включении включался свет при выключении выключался.
Сообщение xor »
Лойсо Пондохва писал(а): Вс июн 09, 2019 6:00 pm кнопочки включатели
так кнопочки или выключатели? на панели - это меню или сцена или дашборд или ещё что-то?
Лойсо Пондохва
Выключатели в меню.
Сообщение xor »
Лойсо Пондохва писал(а): Вс июн 09, 2019 9:01 pm Выключатели в меню.
У меня сделано так (но у меня без ПУ)
метод switch стандартный
$status = $this->getProperty("status");
if ($status) {
 $this->callMethod('turnOff');
 $this->callMethod('turnOn');
