[Модуль] MySensors (mysensor)
dakipro
Re: Модуль MySensor
Сообщение dakipro »
Hi Ivan,
thank you for the plugin, it works very well.
Sorry I do not speak russian, but you can write in russian and I can google-translate it :)
I also get
10:43:49 working thread: cycle_webvars.php
PHP Warning:  socket_read(): unable to read from socket [10060]: A connection at
tempt failed because the connected party did not properly respond after a period
 of time, or established connection failed because connected host has failed to
respond.
 in C:\_majordomo\htdocs\modules\mysensor\phpMSTcp.php on line 72
I tried changing #define UIP_CONF_MAX_CONNECTIONS 2 on the gateway, but it didn't help.
I can ignore this error as everything is working fine, I have 4 sensors connected.
However, one thing happens from time to time, it is usually when I restart some of the nodes, for example if battery is empty, and when I connect the battery - then controller looses communication with the gateway and my CPU usage goes to 100%.
When this happens, I cannot send or receive any command to any of the nodes, and cycle-mysensors.php log is empty, it just says on every 15 minutes.
2015-12-10 04:11:55Disconnected
2015-12-10 04:11:55 Reconnect
2015-12-10 04:11:55 Connecting TCP
2015-12-10 04:11:55 Connected
2015-12-10 04:11:55 Connecting main
2015-12-10 04:11:55 Send: 0;0;3;0;14;Gateway startup complete
2015-12-10 04:11:55 Internal: Node:0; Sensor:0; Type:3; Ack:0; Sub:14; Msg:Gateway startup complete.
(a lot of errors mentioned above)
2015-12-10 04:26:56Disconnected
2015-12-10 04:26:56 Reconnect
2015-12-10 04:26:56 Connecting TCP
2015-12-10 04:26:56 Connected
2015-12-10 04:26:56 Connecting main
2015-12-10 04:26:56 Send: 0;0;3;0;14;Gateway startup complete
2015-12-10 04:26:57 Internal: Node:0; Sensor:0; Type:3; Ack:0; Sub:14; Msg:Gateway startup complete.
When this happens, I just restert majordomo and all works fine again (I do not need to restart gateway or anything).
Similar thing happens when I make a new sensor, I always have to restart majordomo and things work fine after that.
If I do not restart majordomo, then there is no communication for days.
I am running latest version of majordomo and mysensor plugin, running on the windows 7 laptop.
I can do some php, I work as php developer, do you have any idea how I can fix this, or how to test it?
Would it be possible just to restart majordomo if I see no communication with the gateway?
Thank you all for great controller and code!
Ivan
Re: Модуль MySensor
Сообщение Ivan »
Hello
I know about this problem
This problem is related to WebSocket
Set in config.php Define('DISABLE_WEBSOCKETS', 1);
We do everything to resolve this problem
Thank you for using our project
We are always happy to attract English-speaking users
Ivan
Re: Модуль MySensor
Сообщение Ivan »
dakipro писал(а):dakipro
Hello
dakipro
Re: Модуль MySensor
Сообщение dakipro »
Thank you for your answer. I put Define('DISABLE_WEBSOCKETS', 1); in the config.php, but problem is still there (I still get php notice and sometimes cpu locks to 100%).
Yesterday I was testing something and I noticed that after I connect some other controller to the same gateway (MYScontroller or domoticz) then cpu goes to 100% on the majordomo and communication with the sensors is lost.
When I kill php process that is taking too much cpu, then mysensors.php disappears from the cmd cycle.
I can test more if that helps :)
Anton_kulibin
Re: Модуль MySensor
Сообщение Anton_kulibin »
Хочу поделиться наблюдением с отваливанием ноды, т.е. после перезагрузки она отваливалась через час, два или через сутки. Что представляла нода, это блок питания 12В для Led ленты, на плате DC-DC преобразователь на 5В, Arduino Pro Mini, nrf24l01, мосфет для управления лентойи разъем для Motion сенсора.
Сначала грешил на гейт и на модуль Mysensors, но все остальные ноды работали отлично. Менял и Arduino и радио модули, даже антенну для радио модуля делал (модулей с усилителями-антеннами не было). Сделал удлинитель 15-20см для радио модуля и вынес его за коробку, и о чудо все заработало стабильно.
CONNECT
Ivan
Re: Модуль MySensor
Сообщение Ivan »
Вам не хватало силы сигнала. Как далеко от гейта до ноды?
Ставили ли вы доп кондер на питание?
Anton_kulibin
Re: Модуль MySensor
Ivan писал(а):Вам не хватало силы сигнала. Как далеко от гейта до ноды?
Ну я так и понял, вообще то не сильно далеко, до гейта напрямую метров 5 , но через пол и одно стену (пол и стены деревянные). Странно, но ведь есть ноды которые дальше удалены, но работают. Кондер всегда ставлю. Думал может какие нибудь помехи от блоков питания в коробке.
Буду репитеры делать, заказал пару радио модулей с аннтенками.
А ведь ноды сами могут выступать в виде репитера если указано gw.begin(incomingMessage, NODE_ID, true); и gw.process();.
Просто я все ноды не спящие делаю такими.
CONNECT
Ivan
Re: Модуль MySensor
Сообщение Ivan »
Да можно репитеры.
Много зависит от положения антены на гейте. У нее есть полярность
werwolfx
Re: Модуль MySensor
Сообщение werwolfx »
Может кто сталкивался в проблемой отсутствия связанных свойств у связанного объекта?
Ivan
Re: Модуль MySensor
Сообщение Ivan »
убедитесь что объект 1.
наберите thiscomputer в поиске
