Значит так
sudo systemctl disable mysql
sudo systemctl enable mysql
Kostosso
Сообщение Kostosso »
Попробовал, не очень результат...
Система стартовала, но вот ошибки....
pi@Majordomo_Pi:~ $ sudo systemctl disable mysql
Synchronizing state of mysql.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install disable mysql
Removed /etc/systemd/system/mysqld.service.
Removed /etc/systemd/system/multi-user.target.wants/mariadb.service.
Removed /etc/systemd/system/mysql.service.
pi@Majordomo_Pi:~ $ sudo systemctl enable mysql
mysql.service is not a native service, redirecting to systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mysql
pi@Majordomo_Pi:~ $ sudo reboot
login as: pi
[email protected]'s password:
Linux Majordomo_Pi 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon May 7 17:05:12 2018 from 192.168.1.122
pi@Majordomo_Pi:~ $ sudo service mysql status
● mysql.service - LSB: Start and stop the mysql database server daemon
Loaded: loaded (/etc/init.d/mysql; generated; vendor preset: enabled)
Active: active (running) since Mon 2018-05-07 17:43:13 MSK; 4min 45s ago
Docs: man:systemd-sysv-generator(8)
Process: 467 ExecStart=/etc/init.d/mysql start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/mysql.service
├─649 /bin/bash /usr/bin/mysqld_safe
├─802 /usr/sbin/mysqld --basedir=/usr --datadir=/tmp/mysql --plugin-dir=/usr/lib/arm-linux-gnueabihf/mariadb18/plugin -
└─803 logger -t mysqld -p daemon error
May 07 17:43:13 Majordomo_Pi mysqld[803]: 2018-05-07 17:43:13 1996431360 [Note] Plugin 'FEEDBACK' is disabled.
May 07 17:43:13 Majordomo_Pi mysqld[803]: 2018-05-07 17:43:13 1996431360 [Note] Server socket created on IP: '127.0.0.1'.
May 07 17:43:13 Majordomo_Pi mysqld[803]: 2018-05-07 17:43:13 1988461376 [Warning] Failed to load slave replication state from tab
May 07 17:43:13 Majordomo_Pi mysqld[803]: 2018-05-07 17:43:13 1996431360 [Note] /usr/sbin/mysqld: ready for connections.
May 07 17:43:13 Majordomo_Pi mysqld[803]: Version: '10.1.23-MariaDB-9+deb9u1' socket: '/var/run/mysqld/mysqld.sock' port: 3306
May 07 17:43:13 Majordomo_Pi mysql[467]: Starting MariaDB database server: mysqld.
May 07 17:43:13 Majordomo_Pi systemd[1]: Started LSB: Start and stop the mysql database server daemon.
May 07 17:43:13 Majordomo_Pi mysqld[803]: 2018-05-07 17:43:13 1757209408 [ERROR] mysqld: Table './db_terminal/pvalues' is marked a
May 07 17:43:13 Majordomo_Pi mysqld[803]: 2018-05-07 17:43:13 1757209408 [Warning] Checking table: './db_terminal/pvalues'
May 07 17:43:13 Majordomo_Pi mysql[467]: ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
lines 1-20/20 (END)...skipping...
Celeron J1800 8gb, Ubuntu Server, ESP8266 на WiFi-IoT, Broadlink RMPro_SC1_SP3S_MP1
С телефона не удобно смотреть, но вроде почти всё ок...ругается на битую таблицу pvalues и на то что у него прав не хватает восстановить её. Запустите восстановление из интерфейса phpmyadmin
sigment
Сообщение sigment »
C Днем Победы!!!
Подскажите, есть ли какой то способ запустить MJD? Вчера падал, падал main, перегрузил, теперь висит на Hello World.
Если есть желающие помочь после запуска выяснить, что за ошибка у меня с main постоянно, готов дать доступ. Моих знаний не хватает. Жалко сцены терять, над которыми просидел не один час и даже день и много устройств Xiaomi добавлено.
MJD на малинке
Raspberry Pi3, Xiaomi, BroadLink, ESP8266
sigment
Сообщение sigment »
Hello World так и выдает, но страница с XRay была открыта до перезагрузки при обновлении ее вот что выдает
Warning: fopen(/var/www/html/debmes/2018-05-09_2018-05-09.log.log): failed to open stream: No such file or directory in /var/www/html/lib/general.class.php on line 175 <- Тут я полностью все удалял, но говорили, что ее можно чистить b я чистил ее не раз.
Warning: filesize(): stat failed for /var/www/html/debmes/2018-05-09_2018-05-09.log.log in /var/www/html/lib/general.class.php on line 177
Это в логе в папке Dembes
22:29:56 0.17640500 Running: mysql restore from file: /var/www/html/database_backup/db.sql
22:41:33 0.88414200 Running: mysql restore from file: /var/www/html/database_backup/db.sql
sigment
Сообщение sigment »
Еще есть 2018-05-09_error он огромный
https://yadi.sk/i/P_0-oCJv3VbM5S
sigment писал(а):Еще есть 2018-05-09_error он огромный
Зайти в phpmyadmin и восстановить (repair) все таблицы, которые поломались.
sigment
Сообщение sigment »
Это можно описать как это сделать? Если ковыряться с кодом, то моих знаний скорее всего не хватит.
Denis_k
Сообщение Denis_k »
sigment писал(а): Ср май 09, 2018 3:47 pm Это можно описать как это сделать? Если ковыряться с кодом, то моих знаний скорее всего не хватит.
вот с этого поста и дальше
MD на raspberry pi3
sigment писал(а):Это можно описать как это сделать? Если ковыряться с кодом, то моих знаний скорее всего не хватит.
Поиском по слову repair есть инструкции.
viewtopic.php?f=3&t=2015&p=17659#p17659
Починить нужно все таблицы, которые сломались.
