condition=RLEDМодератор: immortal
condition=RLEDпапка у меня называется "RULES".
СПАСИБО, РАБОТАЕТ!!!!!olehs писал(а): Пт фев 01, 2019 10:53 pm Ого, не понимаю как так произошло, но в правиле RULES/OFF ошибка в условии. Там должно быть простоКод: Выделить всё
condition=RLED
Starting...
SD initialization done.
MAC=34:ad:be:43:fe:68
Added input BUTTON on pin 2
Saved input BUTTON at 40 (17 bytes)
Stored 1 inputs (17 bytes)
Added output DIR on pin 255
Saved output DIR at 57 (7 bytes)
Added output LED on pin 23
Saved output LED at 64 (7 bytes)
Stored 2 outputs (14 bytes)
Saved rule /DIR at 71 (55 bytes)
Loaded rule: /DIR
Saved rule /HOLDDOWN at 126 (45 bytes)
Loaded rule: /HOLDDOWN
Saved rule /HOLDUP at 171 (34 bytes)
Loaded rule: /HOLDUP
Saved rule /OFF at 205 (26 bytes)
Loaded rule: /OFF
Saved rule /ON at 231 (27 bytes)
Loaded rule: /ON
Stored 5 rules (187 bytes)
Stored config to EEPROM (258 bytes)
Server started at 192.168.18.110
Started (free RAM: 4755)
Button BUTTON Pressed
Button BUTTON Released
Button BUTTON Click
Output LED On
Output DIR On
Status output LED State:On Value:0
Status output DIR State:On Value:0
Button BUTTON Click
Output LED Off
Status output LED State:Off Value:0
Button BUTTON Click
Output LED On
Output DIR On
Button BUTTON Hold
Button BUTTON Repeat
Output LED IncValue=5
Status output LED State:On Value:5
Status output LED State:On Value:10
Status output LED State:On Value:15
Status output LED State:On Value:20
Status output LED State:On Value:25
Status output LED State:On Value:30
Status output LED State:On Value:35
Status output LED State:On Value:40
Status output LED State:On Value:45
Status output LED State:On Value:50
Button BUTTON LongClick
Output DIR Toggle
Status output DIR State:Off Value:0
Starting...
Added input BUTTON on pin 7
Added output LED on pin 8
Loaded rule: /DIR
Loaded rule: /OFF
Loaded rule: /ON
Button BUTTON Click
Output LED On
Output DIR On
Button BUTTON Hold
Status output LED State:On Value:55
Status output LED State:On Value:60
Status output LED State:On Value:65
Status output LED State:On Value:70
Status output LED State:On Value:75
Status output LED State:On Value:80
Status output LED State:On Value:85
Status output LED State:On Value:90
Status output LED State:On Value:95
Status output LED State:On Value:100
Status output LED State:On Value:105
Status output LED State:On Value:110
Status output LED State:On Value:115
Status output LED State:On Value:120
Status output LED State:On Value:125
Status output LED State:On Value:130
Status output LED State:On Value:135
Status output LED State:On Value:140
Status output LED State:On Value:145
Status output LED State:On Value:150
Status output LED State:On Value:155
Status output LED State:On Value:160
Status output LED State:On Value:165
Status output LED State:On Value:170
Status output LED State:On Value:175
Status output LED State:On Value:180
Status output LED State:On Value:185
Status output LED State:On Value:190
Status output LED State:On Value:195
Status output LED State:On Value:200
Status output LED State:On Value:205
Status output LED State:On Value:210
Status output LED State:On Value:215
Output DIR Toggle
Button BUTTON Click
Output LED Off
Status output LED State:Off Value:215
Button BUTTON Click
Output LED On
Output DIR On
Button BUTTON Hold
Output DIR Toggle
Номер 8 тоже здесь, так что должно работать.PWM: 2 to 13 and 44 to 46. Provide 8-bit PWM output with the analogWrite() function.
