Подскажи где его вырвать.
Re: [Модуль] Xiaomi miIO
1. У тебя тоже цикл внезапно останавливается?
2. Лог цикла выключен - Cycle debug - no
https://kb.smartliving.ru/logi-sistemy-i-moduley/
Но сначала выстави вменяемые периоды опроса. И чтобы они не особо пересекались со значением периодического поиска, а то там 60 сек, что в совокупности дает накладки разного характера.
log_2018-10-10-cycle_xiaomimiio
23:41:12 Starting periodic search for devices in the network (every 120 seconds)
23:41:13 Background search process is started
23:41:59 Request to update the properties of the device 10.0.1.46
23:41:59 Request to update the properties of the device 10.0.1.76
23:42:02 Queue command: {"ID":"245068","DEVICE_ID":"3","METHOD":"get_prop","DATA":"[\"power\",\"aqi\",\"average_aqi\",\"humidity\",\"temp_dec\",\"bright\",\"mode\",\"favorite_level\",\"filter1_life\",\"use_time\",\"purify_volume\",\"led\",\"buzzer\",\"child_lock\"]","ADDED":"2018-10-10 23:41:59","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"zhimi.airpurifier.ma2","IP":"10.0.1.46"}
Command to send - {"id":92041220,"method":"get_prop","params":["power","aqi","average_aqi","humidity","temp_dec","bright","mode","favorite_level","filter1_life","use_time","purify_volume","led","buzzer","child_lock"]}
Checking device status by 10.0.1.46
Timeout SO_RCVTIMEO successfully set
>>>>> Sending hello-packet to 10.0.1.46 with timeout 2
>>>>> Sent 32 bytes to socket
<<<<< Reply received from IP 10.0.1.46 , port 54321
32 bytes received
magic: 2131
length: 0020 --> 32 –±–∞–π—Ç
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
ts: 00084560 --> 542048 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:34:08
checksum: –ú–æ–π —Ç–æ–∫–µ–Ω
ts_server: 5bbe641a --> 1539204122 seconds --> 2018-10-10 23:42:02
timediff: -1538662074
Device 10.0.1.46 available
Using manually set token - –ú–æ–π —Ç–æ–∫–µ–Ω
>>>>> Sending packet to 10.0.1.46 with timeout 2
magic: 2131
length: 00f0 --> 240 –±–∞–π—Ç
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum: 7eb23960c4bdf7310e2138d8f0a1d66b
data: 15a364d0817dd5f1a64424c065c93a463c4e04320327e1c32f029f31cb89c215f057587db13eba8477e342eb2028c211c9796a3ef83c041f1dfe88a569e4d310494d82b11215dc0a0928e7b701e7cca6ee84aeda60795fb9fb7cd1439f2381bd7edd4885a9b9d39528d7679bf4ba0bc1d5c91f26fba945771fac94834d46741eb0afaedfb070d48b60a8616573a4b643cf4f3f225d0f54054210014817fe1a26134309d30903e048d153e03de50f04b1c2cb356a7532b65b5bbe4f4fc9c596c823846e7499004b3432d645cf090a8d6e
>>>>> Sent 240 bytes to socket
<<<<< Reply from IP 10.0.1.46 , port 54321
Read 128 bytes from socket
magic: 2131
length: 0080 --> 128 –±–∞–π—Ç
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum: c35c6acc0742b5d2b872f6f1a560bf6d
data: b16ce87870ae9e34dad1aaab7f4ac7147608dfe1f20e41adabc49187299f9b342b2bc266d18d5e915aa2bc97b6ba21f1c1480ac8479ad6b94c2f2ef813ac0a805d59b11dd0ec4b4912c7a640805d9d1c85366438fafbdb464a085e65ca0aa945
Data decrypted: {"result":["off",30,8,58,233,null,"idle",10,98,118800,3608,"on","on","off"],"id":92041220}
JSON data is vaild.
23:42:02 Reply: {"result":["off",30,8,58,233,null,"idle",10,98,118800,3608,"on","on","off"],"id":92041220}
23:42:02 Background processing of the response is started
23:42:02 Queue command: {"ID":"245069","DEVICE_ID":"4","METHOD":"get_status","DATA":"[]","ADDED":"2018-10-10 23:41:59","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92041221,"method":"get_status","params":[]}
Checking device status by 10.0.1.76
>>>>> Sending hello-packet to 10.0.1.76 with timeout 2
<<<<< Reply received from IP 10.0.1.76 , port 54321
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe641a --> 1539204122 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:42:02
checksum: ffffffffffffffffffffffffffffffff
timediff: 0
Device 10.0.1.76 available
>>>>> Sending packet to 10.0.1.76 with timeout 2
magic: 2131
length: 0060 --> 96 –±–∞–π—Ç
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum: f1dd5de482f42db52322c5e2dc8d4d7c
data: 24ca36d89eb3e780daf59e06e78bc58a8a6510ed1c1e7782bd4b1f46f5114a66656ea054c201235a34a46730270ed9a714921a0ebc39785e26078ebe9d064e31
>>>>> Sent 96 bytes to socket
Error reading from socket [10060] œÓÔ˚Ú͇ ÛÒÚ‡ÌÓ‚ËÚ¸ ÒÓ‰ËÌÂÌË ·˚· ·ÂÁÛÒÔ¯ÌÓÈ, Ú.Í. ÓÚ ‰Û„Ó„Ó ÍÓÏÔ¸˛Ú‡ Á‡ Ú·ÛÂÏÓ ‚ÂÏˇ Ì ÔÓÎÛ˜ÂÌ ÌÛÊÌ˚È ÓÚÍÎËÍ, ËÎË ·˚ÎÓ ‡ÁÓ‚‡ÌÓ ÛÊ ÛÒÚ‡ÌÓ‚ÎÂÌÌÓ ÒÓ‰ËÌÂÌË ËÁ-Á‡ Ì‚ÂÌÓ„Ó ÓÚÍÎË͇ ÛÊ ÔÓ‰Íβ˜ÂÌÌÓ„Ó ÍÓÏÔ¸˛Ú‡.
23:42:04 Reply: {"error":"Device not answered"}
23:42:04 Background processing of the response is started
23:42:04 Queue command: {"ID":"245070","DEVICE_ID":"4","METHOD":"get_consumable","DATA":"[]","ADDED":"2018-10-10 23:42:00","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92041242,"method":"get_consumable","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe641c --> 1539204124 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:42:04
ts_server: 5bbe641c --> 1539204124 seconds --> 2018-10-10 23:42:04
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 00084562 --> 542050 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:34:10
checksum: 5ac617b52390813bb3e9bdac60f03ae8
data: 9d723554b049eec236092c39416193c3505a2037a57cd79869b7a86d6bec0eb48f346981bd3faa52784b4715b930a6449f1bd6b2e00b9f8c427ccdf9d7b17914
23:42:06 Reply: {"error":"Device not answered"}
23:42:06 Background processing of the response is started
23:42:06 Queue command: {"ID":"245071","DEVICE_ID":"4","METHOD":"get_custom_mode","DATA":"[]","ADDED":"2018-10-10 23:42:01","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92041263,"method":"get_custom_mode","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe641e --> 1539204126 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:42:06
ts_server: 5bbe641e --> 1539204126 seconds --> 2018-10-10 23:42:06
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 00084564 --> 542052 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:34:12
checksum: 38bed3ada53caddba8ff45e084c5e632
data: c27c48ac75331f0747f780fb5dcf129af4087f7178453bc628976621b3eaacc86e143bcd27a7c22bce9c5f275fd79bb77ac1f3f96a398f1b76e12d6f3df203e3
23:42:08 Reply: {"error":"Device not answered"}
23:42:08 Background processing of the response is started
23:43:00 Request to update the properties of the device 10.0.1.76
23:43:03 Queue command: {"ID":"245072","DEVICE_ID":"4","METHOD":"get_status","DATA":"[]","ADDED":"2018-10-10 23:43:00","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92041830,"method":"get_status","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe6456 --> 1539204182 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:43:02
ts_server: 5bbe6457 --> 1539204183 seconds --> 2018-10-10 23:43:03
timediff: -1
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum: a5661ab08dda666ff43a46faef52aeb0
data: a7d0de0e9c9f42b83508a237bbe3c4d082de74d80850398addc5c5da122a02f321d75d321310bece1452f08f7705b073926de792badc8086d348d149a7b80de7
timediff: -1
<<<<< Reply from IP 10.0.1.76 , port 54321
Read 240 bytes from socket
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum: 7d8ef8435dcc1d984de3e210c591e1ac
data: c9992bdfe166a173b026136732ba4c32820f44955be95b65856b6b98ff7e097b4c43641ff7d55c1177c299805c193c0a923824d59af2fb5d109190a16442776fff398f636c1c643bd8cd3f1f8ead53aac0da35b99177334e6330486dfb80952f9d36f6e25c77e08ffa92767a4526f9cea52056ca1dc53e7115a7f3035b3bb32c431f065823337e5a5087d0f97aeb374af9407cac6bd5cbea89a7a53d9181d8190b3a1ca7d453dd8ca8ec9431cdfd3083f20a8cf367bedf863f8e65240b1b3c20ddb1ba33125e5e69d81f270722f5a844
Data decrypted: {"result":[{"msg_ver":2,"msg_seq":2456,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92041830}
Invalid JSON data. Error: Control character error, possibly incorrectly encoded
Executing trim()
23:43:03 Reply: {"result":[{"msg_ver":2,"msg_seq":2456,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92041830}
23:43:03 Background processing of the response is started
23:43:03 Queue command: {"ID":"245073","DEVICE_ID":"4","METHOD":"get_consumable","DATA":"[]","ADDED":"2018-10-10 23:43:01","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92041831,"method":"get_consumable","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
timediff: -1
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum: d7610da34258af11432b91c2fa78be3c
data: 8e52154b2f6390425b47260f40cbaf9a3deae03cd0e181dca4cbaafebaee8b4658c6e9bd4be81d90996c8792fbe8f3d309a57adcac5f95175a45b605f5172fc8
timediff: -1
Read 176 bytes from socket
magic: 2131
length: 00b0 --> 176 –±–∞–π—Ç
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum: 23a0d60a1c1384bc5391698d180c27c8
data: 1175e9aa68a1a0bb8c61d4ebb9fc2848b0ed20932c0a3911db6b0126263a42378e6beb2f37075fdd01a8098297bddc091cb2188b24be4314f4a770c7c2bc6f2a563dcdc8b87ccb087b9be37f23acf338c5ecbe4fefa6833b13ca97682207c948d9ba1cac86648630834c786f7b0d4c228fad761f2af600bffaa49c5ddcf996354019e63a66490df1c0d5774625063fe2
Data decrypted: {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92041831}
Executing trim()
23:43:03 Reply: {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92041831}
23:43:03 Queue command: {"ID":"245074","DEVICE_ID":"4","METHOD":"get_custom_mode","DATA":"[]","ADDED":"2018-10-10 23:43:02","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92041832,"method":"get_custom_mode","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
timediff: -1
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum: 893eb98541cf691bf5b7efa15a59a6f0
data: e4d8b8bfe3ab8ddcff6fdd726c8184e31ef597913dff2e9844e006e7f959fd87f9304485428f6b54a9c06c1bf68ed91951812d250692e57a93496ccb9b1ca6cb
timediff: -1
Read 64 bytes from socket
magic: 2131
length: 0040 --> 64 –±–∞–π—Ç
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum: d7daf49877e6c9ee7719e4d4e66e2f96
data: 2b44ac1e98b6565c719afbfe9dfc40fcd9eb88c55772227f258a287461a398aa
Data decrypted: {"result":[100],"id":92041832}
Executing trim()
23:43:03 Reply: {"result":[100],"id":92041832}
23:43:12 Starting periodic search for devices in the network (every 120 seconds)
23:43:13 Background search process is started
23:43:59 Request to update the properties of the device 10.0.1.46
23:44:00 Queue command: {"ID":"245075","DEVICE_ID":"3","METHOD":"get_prop","DATA":"[\"power\",\"aqi\",\"average_aqi\",\"humidity\",\"temp_dec\",\"bright\",\"mode\",\"favorite_level\",\"filter1_life\",\"use_time\",\"purify_volume\",\"led\",\"buzzer\",\"child_lock\"]","ADDED":"2018-10-10 23:43:59","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"zhimi.airpurifier.ma2","IP":"10.0.1.46"}
Command to send - {"id":92042400,"method":"get_prop","params":["power","aqi","average_aqi","humidity","temp_dec","bright","mode","favorite_level","filter1_life","use_time","purify_volume","led","buzzer","child_lock"]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
ts: 000845d7 --> 542167 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:36:07
ts_server: 5bbe6490 --> 1539204240 seconds --> 2018-10-10 23:44:00
timediff: -1538662073
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum: d908b1d97cdb2f424ee217776d8bcbae
data: 010cb4bccff025bf0841960e25d7d79a6b6cd5fda1fbd55cf520def6254bb5723ad509efbbd7de1638f2321c52559f467cacf1864888cbe5fab064ede19dad7689f34ceed40ff45c9d6f900b7c51a8bfa9646dc06d6e45fb0314fc0d6379325fa5e96b831f328efc79e27ef154399e234e65ce99aa84d54e2cf3032133d441fb219f0a0a273d614b4bcb4e5464272fa64200c10d687b9ccbe7474f7d0e07ef3e356f1f29f262eafd3096360e0d5555679161bd75defee39c216fa1d0e8cbb7e2aacdeb386eff84487f4c6d1264f9b002
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum: 7f9324163e30185ad987c105323b9f44
data: b16ce87870ae9e34dad1aaab7f4ac7147608dfe1f20e41adabc49187299f9b342b2bc266d18d5e915aa2bc97b6ba21f1c1480ac8479ad6b94c2f2ef813ac0a805d59b11dd0ec4b4912c7a640805d9d1caabe6177e03caa6ca0768b70181a81c5
Data decrypted: {"result":["off",30,8,58,233,null,"idle",10,98,118800,3608,"on","on","off"],"id":92042400}
JSON data is vaild.
23:44:00 Reply: {"result":["off",30,8,58,233,null,"idle",10,98,118800,3608,"on","on","off"],"id":92042400}
23:44:00 Background processing of the response is started
23:44:00 Request to update the properties of the device 10.0.1.76
23:44:03 Queue command: {"ID":"245076","DEVICE_ID":"4","METHOD":"get_status","DATA":"[]","ADDED":"2018-10-10 23:44:00","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92042430,"method":"get_status","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe6493 --> 1539204243 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:44:03
ts_server: 5bbe6493 --> 1539204243 seconds --> 2018-10-10 23:44:03
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 000845da --> 542170 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:36:10
checksum: 6694ef9df120d587abb22518344e05f4
data: 88c1eb59c55ec3446e01f83b7aff6fbb07da277e0b17fbf341ad9f75eb172ec360b6a058243b14932c00927404fd1e418547bba2941666b46923e85ac5d550fc
23:44:05 Reply: {"error":"Device not answered"}
23:44:05 Background processing of the response is started
23:44:05 Queue command: {"ID":"245077","DEVICE_ID":"4","METHOD":"get_consumable","DATA":"[]","ADDED":"2018-10-10 23:44:01","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92042451,"method":"get_consumable","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe6495 --> 1539204245 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:44:05
ts_server: 5bbe6495 --> 1539204245 seconds --> 2018-10-10 23:44:05
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 000845dc --> 542172 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:36:12
checksum: 9ff11f638e89335781beecbae8fcce98
data: b29a26204c8da77dbbc974d5b3d5a4e66c54d27dc16d8c9bf362984dafabe43d03119d67a6e5029448f1a146ff2a6d62aec0cb96ddcbe7f379775fcb0f2289a2
23:44:07 Reply: {"error":"Device not answered"}
23:44:07 Background processing of the response is started
23:44:07 Queue command: {"ID":"245078","DEVICE_ID":"4","METHOD":"get_custom_mode","DATA":"[]","ADDED":"2018-10-10 23:44:02","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92042472,"method":"get_custom_mode","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe6497 --> 1539204247 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:44:07
ts_server: 5bbe6497 --> 1539204247 seconds --> 2018-10-10 23:44:07
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 000845de --> 542174 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:36:14
checksum: 743994b89f3ccb027f994b81e3bcd58a
data: a9a67974704394ed05973193bc3c87550f35f9ee8ffdc9ab03ca5307e79c94cf552a9deda20bdfbd7f9914a4379245e8a0e1f0c374fae328ad495ab71493ac27
23:44:09 Reply: {"error":"Device not answered"}
23:44:09 Background processing of the response is started
23:45:00 Request to update the properties of the device 10.0.1.76
23:45:03 Queue command: {"ID":"245079","DEVICE_ID":"4","METHOD":"get_status","DATA":"[]","ADDED":"2018-10-10 23:45:00","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92043030,"method":"get_status","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe64cf --> 1539204303 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:45:03
ts_server: 5bbe64cf --> 1539204303 seconds --> 2018-10-10 23:45:03
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 00084616 --> 542230 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:37:10
checksum:
data: 5c05113e26d1862de3341ea46df100703f2159ce52fbbd1e2af1efcae6a7dc58022137246db357e2f93fed0630cc674db299aaa3faa282dd3c4a453eac8317ce
23:45:05 Reply: {"error":"Device not answered"}
23:45:05 Background processing of the response is started
23:45:05 Queue command: {"ID":"245080","DEVICE_ID":"4","METHOD":"get_consumable","DATA":"[]","ADDED":"2018-10-10 23:45:01","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92043051,"method":"get_consumable","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe64d1 --> 1539204305 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:45:05
ts_server: 5bbe64d1 --> 1539204305 seconds --> 2018-10-10 23:45:05
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 00084618 --> 542232 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:37:12
checksum:
data: a5034e60e32445f5e4cc8436c6e6d0b12e02e62817e6d0600da1f30bc155dd81d904f43d5989028bf970827cad18819bf9e211be6839159171a930c075a94fff
23:45:07 Reply: {"error":"Device not answered"}
23:45:07 Background processing of the response is started
23:45:07 Queue command: {"ID":"245081","DEVICE_ID":"4","METHOD":"get_custom_mode","DATA":"[]","ADDED":"2018-10-10 23:45:02","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92043072,"method":"get_custom_mode","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe64d3 --> 1539204307 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:45:07
ts_server: 5bbe64d3 --> 1539204307 seconds --> 2018-10-10 23:45:07
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 0008461a --> 542234 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:37:14
checksum:
data: 356dc052ab87e044fe2560b8f14954db7f74457ce710b37c489682008324464b9c011eb54a37aaa4f0df4fc9dca2567713583c2afa11e03f59dd8de674be6ba8
23:45:09 Reply: {"error":"Device not answered"}
23:45:09 Background processing of the response is started
23:45:12 Starting periodic search for devices in the network (every 120 seconds)
23:45:13 Background search process is started
23:45:59 Request to update the properties of the device 10.0.1.46
23:46:00 Queue command: {"ID":"245082","DEVICE_ID":"3","METHOD":"get_prop","DATA":"[\"power\",\"aqi\",\"average_aqi\",\"humidity\",\"temp_dec\",\"bright\",\"mode\",\"favorite_level\",\"filter1_life\",\"use_time\",\"purify_volume\",\"led\",\"buzzer\",\"child_lock\"]","ADDED":"2018-10-10 23:45:59","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"zhimi.airpurifier.ma2","IP":"10.0.1.46"}
Command to send - {"id":92043600,"method":"get_prop","params":["power","aqi","average_aqi","humidity","temp_dec","bright","mode","favorite_level","filter1_life","use_time","purify_volume","led","buzzer","child_lock"]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
ts: 0008464f --> 542287 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:38:07
ts_server: 5bbe6508 --> 1539204360 seconds --> 2018-10-10 23:46:00
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum: 3
data: 99ac43eab114d2decd9274379717b35cd7ab2e4863f357eed48c6af19119af0779bb7ed7bd6c1b4d3ee3bf3b1779e51f760c108bd3e42ae0e39a10354443df25e85991d4e66f55b2ef8ab145f132441ead6e27a71b1d4ef234696e5217314e71007f66141db445a56b65821340afaca05e2ef73a51b736fd5aa9eb3a83073d01750adfaa128e88c91e57d6fcedb1bb86eb57bce20adc7138d4d9218282523d90c0bc0e81f079129b30c6669677d5a5815153c99102dc315b66302f8c9facb19272fafbc1c9a1b139a8b0fe71eafa4bd4
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum:
data: b16ce87870ae9e34dad1aaab7f4ac714aa365d8276adb0da2a83821b856a08e598c4c31e3b076c10defbddb7b41cc29c0ccccbe58b6915ca04931b843e661be57fa4b7bd4c6d90a8f05d2834d77a1010b7cca3beb50a818fd0ce9a987dd03abe
Data decrypted: {"result":["off",23,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92043600}
JSON data is vaild.
23:46:00 Reply: {"result":["off",23,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92043600}
23:46:00 Background processing of the response is started
23:46:00 Request to update the properties of the device 10.0.1.76
23:46:03 Queue command: {"ID":"245083","DEVICE_ID":"4","METHOD":"get_status","DATA":"[]","ADDED":"2018-10-10 23:46:00","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92043630,"method":"get_status","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe650b --> 1539204363 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:46:03
ts_server: 5bbe650b --> 1539204363 seconds --> 2018-10-10 23:46:03
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 00084652 --> 542290 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:38:10
checksum:
data: c3a483f3ee555b6565aec9aea85d42a50b3c52531f110b9cba5889d0254a57bc6268ac43d3a44a7334b870b1dc1922d2c7273796bcb23666af0b88a4161e0470
23:46:05 Reply: {"error":"Device not answered"}
23:46:06 Background processing of the response is started
23:46:06 Queue command: {"ID":"245084","DEVICE_ID":"4","METHOD":"get_consumable","DATA":"[]","ADDED":"2018-10-10 23:46:01","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92043661,"method":"get_consumable","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe650d --> 1539204365 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:46:05
ts_server: 5bbe650e --> 1539204366 seconds --> 2018-10-10 23:46:06
timediff: -1
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: ccf55fded61286f24f2261a9aaf5d20f2b935e052f8957f15f870aed77e8765757204ced41bbfc672d5ec1bd00fb9c8a2d964ce7961a3ed70e83af10959b27e8
timediff: -1
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: 1175e9aa68a1a0bb8c61d4ebb9fc2848b0ed20932c0a3911db6b0126263a42378e6beb2f37075fdd01a8098297bddc091cb2188b24be4314f4a770c7c2bc6f2a563dcdc8b87ccb087b9be37f23acf338c5ecbe4fefa6833b13ca97682207c948d9ba1cac86648630834c786f7b0d4c228fad761f2af600bffaa49c5ddcf9963525ac046582975c9a4c38f4b494b55475
Data decrypted: {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92043661}
Executing trim()
23:46:06 Reply: {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92043661}
23:46:06 Queue command: {"ID":"245085","DEVICE_ID":"4","METHOD":"get_custom_mode","DATA":"[]","ADDED":"2018-10-10 23:46:02","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92043662,"method":"get_custom_mode","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
timediff: -1
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: 00298d746b1744b4b7c4eb3c6d115bb0fca6c478c311b884dfaef0610648f42de192423a1643ee9c4dbe1570df8770cc2e635dc4cb2f41a89c7dd5efcffc6e04
timediff: -1
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: 2b44ac1e98b6565c719afbfe9dfc40fc9055688ad97c1fc7078aa189e32eb20e
Data decrypted: {"result":[100],"id":92043662}
Executing trim()
23:46:06 Reply: {"result":[100],"id":92043662}
23:46:56 Running cycle_xiaomimiio.php
23:46:56 Init miIO
23:46:56 Bind IP - 10.0.1.5
23:46:56 Discover period - 180 seconds
23:46:56 Cycle debug - yes
23:46:56 DebMes debug - yes
23:46:56 miIO-Lib debug - yes
Broadband discovery mode
Debug status [1]
Socked created
23:46:56 Starting periodic search for devices in the network (every 180 seconds)
23:46:57 Background search process is started
23:47:00 Request to update the properties of the device 10.0.1.76
23:47:03 Queue command: {"ID":"245086","DEVICE_ID":"4","METHOD":"get_status","DATA":"[]","ADDED":"2018-10-10 23:47:00","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92044230,"method":"get_status","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe6547 --> 1539204423 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:47:03
ts_server: 5bbe6547 --> 1539204423 seconds --> 2018-10-10 23:47:03
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: f0d7ab971dc5a84f474349fe117ce159b0f7c684ff9a0ef6c7d6c711317aadb7a0c4fc6ed58100eb22b15ada1c6fe66f13a482c9b523b133eb34a3e3d9643ffb
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: c9992bdfe166a173b026136732ba4c32820f44955be95b65856b6b98ff7e097b2f2b63691be96b9974ba8ab464071fbe6183076b9f79ab0819767cddd9d8cd5755938d98bd4b759e83d13afb031c3ab1263d37aaed600536de97dcc6050dd0b91b878c95272364092a7eb37ab5641b2284bb218de003d1bdba5dbef17d83c3b63aaa4682058918fe0034e31dce7b854b16f2b42fc56ee81936b99a4023e4c7e329aaaf3944348d4ef90d513f6e52c5d31b7188e393b5341614cef98b9ced965ae0247d5524debfebaa10339d392f0e67
Data decrypted: {"result":[{"msg_ver":2,"msg_seq":2465,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92044230}
Executing trim()
23:47:03 Reply: {"result":[{"msg_ver":2,"msg_seq":2465,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92044230}
23:47:03 Background processing of the response is started
23:47:03 Queue command: {"ID":"245087","DEVICE_ID":"4","METHOD":"get_consumable","DATA":"[]","ADDED":"2018-10-10 23:47:01","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92044231,"method":"get_consumable","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: 8256e63ab70dbcd70052298a37d670a73dfe3746d81f8a2ece04b5e9e0d312a429e7ad854c002cb4b1b0d0cd7296df99bccbbeb1b60901096a1ce64c33784200
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: 1175e9aa68a1a0bb8c61d4ebb9fc2848b0ed20932c0a3911db6b0126263a42378e6beb2f37075fdd01a8098297bddc091cb2188b24be4314f4a770c7c2bc6f2a563dcdc8b87ccb087b9be37f23acf338c5ecbe4fefa6833b13ca97682207c948d9ba1cac86648630834c786f7b0d4c228fad761f2af600bffaa49c5ddcf99635ef3dc0d116b7590793156b1bd669967e
Data decrypted: {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92044231}
Executing trim()
23:47:03 Reply: {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92044231}
23:47:03 Queue command: {"ID":"245088","DEVICE_ID":"4","METHOD":"get_custom_mode","DATA":"[]","ADDED":"2018-10-10 23:47:02","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92044232,"method":"get_custom_mode","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: 696efc024be67c0869173b9ba6fcab018f0886b8e913670b00cd4fba560ebfd7f880b8e6e388fc6d9503c87e8039ff929c2d1c52490431c9cabdd0cd739f927b
timediff: 0
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
checksum:
data: 2b44ac1e98b6565c719afbfe9dfc40fce15c7a06a238c55aee87d0ab9c0d20b0
Data decrypted: {"result":[100],"id":92044232}
Executing trim()
23:47:03 Reply: {"result":[100],"id":92044232}
23:47:59 Request to update the properties of the device 10.0.1.46
23:48:00 Queue command: {"ID":"245089","DEVICE_ID":"3","METHOD":"get_prop","DATA":"[\"power\",\"aqi\",\"average_aqi\",\"humidity\",\"temp_dec\",\"bright\",\"mode\",\"favorite_level\",\"filter1_life\",\"use_time\",\"purify_volume\",\"led\",\"buzzer\",\"child_lock\"]","ADDED":"2018-10-10 23:47:59","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"zhimi.airpurifier.ma2","IP":"10.0.1.46"}
Command to send - {"id":92044800,"method":"get_prop","params":["power","aqi","average_aqi","humidity","temp_dec","bright","mode","favorite_level","filter1_life","use_time","purify_volume","led","buzzer","child_lock"]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
ts: 000846c7 --> 542407 —Å–µ–∫—É–Ω–¥ --> 1970-01-07 09:40:07
ts_server: 5bbe6581 --> 1539204481 seconds --> 2018-10-10 23:48:01
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum:
data: 4a41c5194df18ecfb5a58151703bd42457b1b8a7bd7e7b97ca6536f50bf0d99d1caaf86901f49fd1902d639a579c3d051576f47b74038d0f692021c6d2b4ffe4329d68467c2df3efd6e83f3beab08e526db79fb10174f01e3d811f5b5cf5d916a6e500faf03041e996f3cea25e28ada55c9729e2c63a8b6c349a56cc16bb31ecda61b26d643f1d91d1ebf23a6b48c22db3141c08758ae592a9a7c8e62d3a2a16cc26b04660c4bddc9a4ebfd8e552ffb9b8e30d19e31efda86e7f0292c3fc7262f9ac128a91b45f42a785d6181f9bad16
magic: 2131
unknown1: 00000000
devicetype: 02d1
serial: 6ddc
checksum:
data: b16ce87870ae9e34dad1aaab7f4ac7145cfc34a153e2c0f77324fcaeb99fec9bbd3546f87d320b27749ad2bd1387dce75109751782ef08497efef210f33f1cdf395fffe75f4e60e91c5de04459938f742b1f15ee9c4d567f8f073484d68e51cb
Data decrypted: {"result":["off",32,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92044800}
JSON data is vaild.
23:48:01 Reply: {"result":["off",32,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92044800}
23:48:01 Background processing of the response is started
23:48:01 Request to update the properties of the device 10.0.1.76
23:48:04 Queue command: {"ID":"245090","DEVICE_ID":"4","METHOD":"get_status","DATA":"[]","ADDED":"2018-10-10 23:48:01","TOKEN":"–ú–æ–π —Ç–æ–∫–µ–Ω","DEVICE_TYPE":"roborock.vacuum.s5","IP":"10.0.1.76"}
Command to send - {"id":92044840,"method":"get_status","params":[]}
32 bytes received
magic: 2131
unknown1: 00000000
devicetype: 05bf
serial: d1a5
ts: 5bbe6583 --> 1539204483 —Å–µ–∫—É–Ω–¥ --> 2018-10-10 23:48:03
ts_server: 5bbe6584 --> 1539204484 seconds --> 2018-10-10 23:48:04
timediff: -1
2018-10-10_xiaomimiio
23:41:12 0.08089200 Starting periodic search for devices in the network
23:41:12 0.08259700 Run miIO-discover command
23:41:22 0.11589700 End miIO-discover command
23:41:22 0.11604300 Reply = {"devices":["{\"devicetype\":\"05bf\",\"serial\":\"d1a5\",\"token\":\"ffffffffffffffffffffffffffffffff\",\"ip\":\"10.0.1.76\"}","{\"devicetype\":\"02d1\",\"serial\":\"6ddc\",\"token\":\"Мой токен\",\"ip\":\"10.0.1.46\"}"]}
23:41:22 0.11640400 Current count of devices 2
23:41:22 0.11672700 Update the ip address and the token for the device 10.0.1.76
23:41:22 0.11750600 Update the ip address and the token for the device 10.0.1.46
23:41:22 0.11796700 Current count of offline devices 0
23:41:22 0.11850200 Periodic search for devices in the network is finished
23:42:02 0.45812500 Incoming message from 3 (get_prop): {"result":["off",30,8,58,233,null,"idle",10,98,118800,3608,"on","on","off"],"id":92041220}
23:42:04 0.51447100 Incoming message from 4 (get_status): {"error":"Device not answered"}
23:42:06 0.60027500 Incoming message from 4 (get_consumable): {"error":"Device not answered"}
23:42:08 0.62299300 Incoming message from 4 (get_custom_mode): {"error":"Device not answered"}
23:43:03 0.07163100 Incoming message from 4 (get_status): {"result":[{"msg_ver":2,"msg_seq":2456,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92041830}
23:43:03 0.15520100 Incoming message from 4 (get_consumable): {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92041831}
23:43:03 0.23331000 Incoming message from 4 (get_custom_mode): {"result":[100],"id":92041832}
23:43:12 0.36066900 Starting periodic search for devices in the network
23:43:12 0.36221200 Run miIO-discover command
23:43:22 0.38941000 End miIO-discover command
23:43:22 0.38955500 Reply = {"devices":["{\"devicetype\":\"05bf\",\"serial\":\"d1a5\",\"token\":\"ffffffffffffffffffffffffffffffff\",\"ip\":\"10.0.1.76\"}","{\"devicetype\":\"02d1\",\"serial\":\"6ddc\",\"token\":\"Мой токен\",\"ip\":\"10.0.1.46\"}"]}
23:43:22 0.38991900 Current count of devices 2
23:43:22 0.39023400 Update the ip address and the token for the device 10.0.1.76
23:43:22 0.39101900 Update the ip address and the token for the device 10.0.1.46
23:43:22 0.39160200 Current count of offline devices 0
23:43:22 0.39172300 Periodic search for devices in the network is finished
23:44:00 0.80278400 Incoming message from 3 (get_prop): {"result":["off",30,8,58,233,null,"idle",10,98,118800,3608,"on","on","off"],"id":92042400}
23:44:05 0.84051800 Incoming message from 4 (get_status): {"error":"Device not answered"}
23:44:07 0.87552100 Incoming message from 4 (get_consumable): {"error":"Device not answered"}
23:44:09 0.92084700 Incoming message from 4 (get_custom_mode): {"error":"Device not answered"}
23:45:05 0.38909700 Incoming message from 4 (get_status): {"error":"Device not answered"}
23:45:07 0.41499900 Incoming message from 4 (get_consumable): {"error":"Device not answered"}
23:45:09 0.49498900 Incoming message from 4 (get_custom_mode): {"error":"Device not answered"}
23:45:12 0.56496400 Starting periodic search for devices in the network
23:45:12 0.56618900 Run miIO-discover command
23:45:22 0.60605300 End miIO-discover command
23:45:22 0.60627300 Reply = {"devices":["{\"devicetype\":\"05bf\",\"serial\":\"d1a5\",\"token\":\"ffffffffffffffffffffffffffffffff\",\"ip\":\"10.0.1.76\"}","{\"devicetype\":\"02d1\",\"serial\":\"6ddc\",\"token\":\"Мой токен\",\"ip\":\"10.0.1.46\"}"]}
23:45:22 0.60679500 Current count of devices 2
23:45:22 0.60719500 Update the ip address and the token for the device 10.0.1.76
23:45:22 0.61460400 Update the ip address and the token for the device 10.0.1.46
23:45:22 0.61504900 Current count of offline devices 0
23:45:22 0.61520900 Periodic search for devices in the network is finished
23:46:00 0.94642900 Incoming message from 3 (get_prop): {"result":["off",23,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92043600}
23:46:06 0.01275200 Incoming message from 4 (get_status): {"error":"Device not answered"}
23:46:06 0.07212100 Incoming message from 4 (get_consumable): {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92043661}
23:46:06 0.18828200 Incoming message from 4 (get_custom_mode): {"result":[100],"id":92043662}
23:46:56 0.41649400 Starting periodic search for devices in the network
23:46:56 0.41773600 Run miIO-discover command
23:47:03 0.47544400 Incoming message from 4 (get_status): {"result":[{"msg_ver":2,"msg_seq":2465,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92044230}
23:47:03 0.52919500 Incoming message from 4 (get_consumable): {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92044231}
23:47:03 0.59167800 Incoming message from 4 (get_custom_mode): {"result":[100],"id":92044232}
23:47:06 0.44498700 End miIO-discover command
23:47:06 0.44515400 Reply = {"devices":["{\"devicetype\":\"05bf\",\"serial\":\"d1a5\",\"token\":\"ffffffffffffffffffffffffffffffff\",\"ip\":\"10.0.1.76\"}","{\"devicetype\":\"02d1\",\"serial\":\"6ddc\",\"token\":\"Мой токен\",\"ip\":\"10.0.1.46\"}"]}
23:47:06 0.44549200 Current count of devices 2
23:47:06 0.44578600 Update the ip address and the token for the device 10.0.1.76
23:47:06 0.44658700 Update the ip address and the token for the device 10.0.1.46
23:47:06 0.44733900 Current count of offline devices 0
23:47:06 0.44750900 Periodic search for devices in the network is finished
23:48:01 0.05455600 Incoming message from 3 (get_prop): {"result":["off",32,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92044800}
23:48:04 0.13115700 Incoming message from 4 (get_status): {"result":[{"msg_ver":2,"msg_seq":2468,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92044840}
23:48:04 0.21782500 Incoming message from 4 (get_consumable): {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92044841}
23:48:04 0.28385100 Incoming message from 4 (get_custom_mode): {"result":[100],"id":92044842}
23:49:04 0.85993200 Incoming message from 4 (get_status): {"result":[{"msg_ver":2,"msg_seq":2471,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92045440}
23:49:04 0.91440900 Incoming message from 4 (get_consumable): {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92045441}
23:49:04 0.96136700 Incoming message from 4 (get_custom_mode): {"result":[100],"id":92045442}
23:49:56 0.49722800 Starting periodic search for devices in the network
23:49:56 0.49853700 Run miIO-discover command
23:50:06 0.52440400 End miIO-discover command
23:50:06 0.52478200 Reply = {"devices":["{\"devicetype\":\"02d1\",\"serial\":\"6ddc\",\"token\":\"Мой токен\",\"ip\":\"10.0.1.46\"}"]}
23:50:06 0.52516000 Current count of devices 2
23:50:06 0.52545900 Update the ip address and the token for the device 10.0.1.46
23:50:06 0.52594900 Current count of offline devices 1
23:50:06 0.52607800 Device 10.0.1.76 is offline
23:50:06 0.53442600 Periodic search for devices in the network is finished
23:50:06 0.54203900 Incoming message from 3 (get_prop): {"result":["off",22,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92046000}
23:50:06 0.96970300 Incoming message from 4 (get_status): {"error":"Device not answered"}
23:50:08 0.99511800 Incoming message from 4 (get_consumable): {"error":"Device not answered"}
23:50:09 0.06493500 Incoming message from 4 (get_custom_mode): {"result":[100],"id":92046082}
23:51:04 0.52234700 Incoming message from 4 (get_status): {"result":[{"msg_ver":2,"msg_seq":2476,"state":8,"battery":100,"clean_time":2128,"clean_area":36377500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":1}],"id":92046640}
23:51:04 0.56773000 Incoming message from 4 (get_consumable): {"result":[{"main_brush_work_time":54095,"side_brush_work_time":54095,"filter_work_time":54095,"sensor_dirty_time":54095}],"id":92046641}
23:51:04 0.63136500 Incoming message from 4 (get_custom_mode): {"result":[100],"id":92046642}
23:52:00 0.60142000 Incoming message from 3 (get_prop): {"result":["off",31,8,58,232,null,"idle",10,98,118800,3608,"on","on","off"],"id":92047200}
23:52:06 0.73813000 Incoming message from 4 (get_status): {"error":"Device not answered"}
23:52:08 0.87069700 Incoming message from 4 (get_consumable): {"error":"Device not answered"}
23:52:10 0.95715800 Incoming message from 4 (get_custom_mode): {"error":"Device not answered"}
23:52:56 0.32277200 Starting periodic search for devices in the network
23:52:56 0.32423000 Run miIO-discover command
23:53:06 0.35534200 End miIO-discover command
23:53:06 0.35548800 Reply = {"devices":["{\"devicetype\":\"02d1\",\"serial\":\"6ddc\",\"token\":\"Мой токен\",\"ip\":\"10.0.1.46\"}"]}
23:53:06 0.35586600 Current count of devices 2
23:53:06 0.35616400 Update the ip address and the token for the device 10.0.1.46
23:53:06 0.35666300 Current count of offline devices 1
23:53:06 0.35678600 Device 10.0.1.76 is offline
23:53:06 0.35719000 Periodic search for devices in the network is finished
23:53:06 0.38026700 Incoming message from 4 (get_status): {"error":"Device not answered"}
23:53:08 0.41103000 Incoming message from 4 (get_consumable): {"error":"Device not answered"}
23:53:10 0.46180700 Incoming message from 4 (get_custom_mode): {"error":"Device not answered"}
А попробуй в файле modules/xiaomimiio/lib/miio.class.php в строке 30 $send_timeout выставить не 2, а, допустим, 5.
Поменял, прошло 2,5 часа пылесос ни разу не ушел в офлайн.
Я пойду пака по другому пути. Расставил на оборудование время опроса. Попробую пока так. Если не поможет значит вариант выше.
- 2018-10-11_13-14-29.png (34.74 КБ) 4545 просмотров
Может токены не стоит выставлять на всеобщее обозрение?dksobol писал(а): Чт окт 11, 2018 1:16 pm Я пойду пака по другому пути. Расставил на оборудование время опроса. Попробую пока так. Если не поможет значит вариант выше.
Они только внутри домашней сети актуальны. Из инета они бесполезны.
