gps и доступ извне
Re: Модуль GPS-трекер
А как можно подключить трекер gps103b?
Вот описание строки, которую выдает трекер:
0 1 2 3 4 5 6 7 8 9 10 11
imei:359587017470123,tracker,1010181025,00420777123456,F,092548.000,A,5004.5399,N,01426.7352,E,0.58,;
0=imei 359587017470123
1=tracker - message, alive packet are send with "tracker" other msg are "help me=|ac alarm|acc alarm|door alarm" in every 3min
2=1010181025 its looks like date 18.10.2010 10:25
3=00420777123456 authorised phone number
4=F - GPS signal indicator F = full | L = low
5=092548.000 - FIX Time (UTC): hhmmss.ss 09:25:48
6=A - Data validity, A = Valid, V = Invalid
7=5004.5399 latitude: ddmm.mmmm - 50 degress 04.5399 minutes
8=N - N/S Indicator - N= northern, S= southern
9=01426.7352 - longitude: dddmm.mmmm - 014 degrees, 26.5153 minutes
10=E - E/W Indicator - W= western, E= eastern
11=0.58 - Speed over ground, Knots
Message from tracker when ARM mode set and door`s open
imei:359587017470123,door alarm,1010181112,00420777123456,F,101216.000,A,5004.5502,N,01426.7268,E,0.00,;
Message from tracker when ARM mode set and acc is connected
imei:359587017470123,acc alarm,1010181112,00420777123456,F,101256.000,A,5004.5485,N,01426.7260,E,0.00,;
Message from tracker when AC lost
imei:359587017470123,ac alarm,1010181113,00420777123456,F,101321.000,A,5004.5534,N,01426.7273,E,0.00,;
Message from tracker when SOS button is press for 3sec, msg every 3min
imei:359587017470123,help me,1010181104,00420777123456,F,100411.000,A,5004.5396,N,01426.7280,E,0.00,;
Setting parameters by GPRS:
1-description
2-command to send to GPS
3-acknowledgemnt from GPS
To clear/stop SOS messages
**,imei:359587017470123,E
imei:359587017470123,et,1010181049,00420777123456,F,094922.000,A,5004.5335,N,01426.7305,E,0.00,;
set ARM
**,imei:359587017470123,L
imei:359587017470123,lt,1010181025,00420777123456,F,092548.000,A,5004.5399,N,01426.7352,E,0.00,;
DisARM
**,imei:359587017470123,M
imei:359587017470123,mt,1010181029,00420777123456,F,092913.000,A,5004.5392,N,01426.7344,E,0.00,;
Set speed alarm 60km/h
**,imei:359587017470123,H,060
imei:359587017470123,ht,1010181032,00420777123456,F,093203.000,A,5004.5378,N,01426.7328,E,0.00,;
Set move alarm
**,imei:359587017470123,G
imei:359587017470123,gt,1010181046,00420777123456,F,094657.000,A,5004.5251,N,01426.7298,E,0.00,;
Cut oil,stop engine
**,imei:359587017470123,J
imei:359587017470123,jt,1010181051,00420777123456,F,095123.000,A,5004.5234,N,01426.7295,E,0.00,;
Resume engine
**,imei:359587017470123,K
imei:359587017470123,kt,1010181052,00420777123456,F,095256.000,A,5004.5635,N,01426.7346,E,0.58,;
multitrack30s
**,imei:359587017470123,C,30s
multitrack1minute
**,imei:359587017470123,C,01m
singletrack
**,imei:359587017470123,B
Передача идет по протоколу TCP.
1-description
set ARM
DisARM
Set move alarm
Cut oil,stop engine
Resume engine
multitrack30s
multitrack1minute
singletrack
- sergejey
- Site Admin
А куда он её выдаёт? В каком виде прописывается сервер?mirsum писал(а):А как можно подключить трекер gps103b?
Re: Время GPS трекер
Ну для этого достаточно причинAmarok писал(а):А зачем big brother если есть таскер?
1. Попробовать все варианты (интересно удобство работы, жор аккумулятора и т.д.)
2. Таскер платный. Покупать его всем домочадцам не очень так сказать...
3. Таскер как я понял из обзоров работает нормально только с 4.х версией андроида, на 5 очень много нужного еще не работает а может не заработает никогда. (поправьте если я не прав) в следствии чего покупать продукт который не выполняет нужный функционал смысла особого нет.
Может еще что всплывет...
В текстовом виде на какой нибудь выделенный белый адрес и порт, принятые данные надо как-то захватить и распарсить.sergejey писал(а):А куда он её выдаёт? В каком виде прописывается сервер?mirsum писал(а):А как можно подключить трекер gps103b?
Таскер сжирает аккомулятор за сутки. Пока альтернатив нет. Только увеличивать время между отправками
Если бы только Таскер так жрал аккумулятор... Видимо тут больше проблема жора в модуле gps
- sergejey
- Site Admin
У меня стоит отправка данных из таскера раз в 15 минут + при входе/выходе из "знакомых" сот. В принципе, более или менее такой алгоритм устраивает.Ivan писал(а):Таскер сжирает аккомулятор за сутки. Пока альтернатив нет. Только увеличивать время между отправками
Bolik.Stav
Закинул себе в машину простой телефончик на андройде,на сервер отправляются данные раз в минуту ( чтобы машина когда едет быстро,данные были более точными и конкретными )
Но вот проблем,gps постоянно прыгает и получается что машина на парковке сама ползает туда-сюда.
Подскажите как можно сделать отображение не траектории и сотен точек за день,а что бы карта обновлялась сразу при получении очередных данных от трекера.
- Безымянный.png (56.5 КБ) 13799 просмотров
Господа а вот еще вопрос, координаты у всех всегда верные? Сегодня утром пока еще спал, выдало мне координаты километрах в 200 от места фактического пребывания да еще скорость показывал в 233 км\ч. Ткнул в карту глянуть где это, какая то тайга не пролазная
Кто же знает где вы по ночам бродите?eygen писал(а):пока еще спал,
Majordomo на Orange Pi Zero.
