Зомби после обновления
Strangeman
Re: Зомби после обновления
Сообщение Strangeman » Вт янв 28, 2020 2:01 pm
У меня наблюдается проблема, но не так выражено.
903 ? S 14:44 \_ php -q ./scripts/cycle_mqtt.php --params a:0:{}
3617 ? Z 0:00 | \_ [php] <defunct>
3618 ? Z 0:00 | \_ [php] <defunct>
3619 ? Z 0:00 | \_ [php] <defunct>
3620 ? Z 0:00 | \_ [php] <defunct>
3621 ? Z 0:00 | \_ [php] <defunct>
3622 ? Z 0:00 | \_ [php] <defunct>
3623 ? Z 0:00 | \_ [php] <defunct>
3624 ? Z 0:00 | \_ [php] <defunct>
3625 ? Z 0:00 | \_ [php] <defunct>
3626 ? Z 0:00 | \_ [php] <defunct>
3627 ? Z 0:00 | \_ [php] <defunct>
3628 ? Z 0:00 | \_ [php] <defunct>
3629 ? Z 0:00 | \_ [php] <defunct>
Впрочем, это на тестовом Кубике.
На основном сервере вот так выглядит
1141 ? S 112:15 \_ php -q ./scripts/cycle_mqtt.php --params a:0:{}
29773 ? Z 0:00 | \_ [php] <defunct>
29774 ? Z 0:00 | \_ [php] <defunct>
29789 ? Z 0:00 | \_ [php] <defunct>
29790 ? Z 0:00 | \_ [php] <defunct>
29791 ? Z 0:00 | \_ [php] <defunct>
29792 ? Z 0:00 | \_ [php] <defunct>
29793 ? Z 0:00 | \_ [php] <defunct>
29794 ? Z 0:00 | \_ [php] <defunct>
29795 ? Z 0:00 | \_ [php] <defunct>
29796 ? Z 0:00 | \_ [php] <defunct>
29797 ? Z 0:00 | \_ [php] <defunct>
29798 ? Z 0:00 | \_ [php] <defunct>
29799 ? Z 0:00 | \_ [php] <defunct>
29800 ? Z 0:00 | \_ [php] <defunct>
29801 ? Z 0:00 | \_ [php] <defunct>
29802 ? Z 0:00 | \_ [php] <defunct>
29803 ? Z 0:00 | \_ [php] <defunct>
29804 ? Z 0:00 | \_ [php] <defunct>
29805 ? Z 0:00 | \_ [php] <defunct>
29806 ? Z 0:00 | \_ [php] <defunct>
29807 ? Z 0:00 | \_ [php] <defunct>
29808 ? Z 0:00 | \_ [php] <defunct>
29824 ? Z 0:00 | \_ [php] <defunct>
29825 ? Z 0:00 | \_ [php] <defunct>
29826 ? Z 0:00 | \_ [php] <defunct>
29827 ? Z 0:00 | \_ [php] <defunct>
29828 ? Z 0:00 | \_ [php] <defunct>
29829 ? Z 0:00 | \_ [php] <defunct>
29830 ? Z 0:00 | \_ [php] <defunct>
29831 ? Z 0:00 | \_ [php] <defunct>
29832 ? Z 0:00 | \_ [php] <defunct>
29833 ? Z 0:00 | \_ [php] <defunct>
29834 ? Z 0:00 | \_ [php] <defunct>
29835 ? Z 0:00 | \_ [php] <defunct>
29837 ? Z 0:00 | \_ [php] <defunct>
diver
Сообщение diver » Сб фев 15, 2020 12:34 pm
Крайняя пачка обновлений системы, судя по всему, пофиксила зомби. Понаблюдаем еще.
Traktor
Сообщение Traktor » Сб фев 15, 2020 10:54 pm
Падают цыклы( после загрузки
alx69
Сообщение alx69 » Вс фев 16, 2020 2:28 pm
Подтверждаю. У меня полечилось. Все зомби ушли, то всех скриптов.
CONNECT
alx69
Сообщение alx69 » Пт фев 28, 2020 12:04 pm
Опять зомби. Уже неделю наблюдаю. Даже не могу понять после чего. Возможно, опять после последнего обновления от 14.02.2020
CONNECT
Stor
Сообщение Stor » Ср мар 04, 2020 12:13 am
Странно, у меня все норм. Обновления от 02/14/2020
Система Ubuntu 64.
root@nuc:~$ ps axf|grep php
26573 pts/8    S+     0:00              \_ grep --color=auto php
 4086 ?        Ss    43:29 /usr/bin/php /var/www/cycle.php
 6917 ?        S      8:11  \_ php -q ./scripts/cycle_execs.php --params a:0:{}
 6935 ?        S      4:49  \_ php -q ./scripts/cycle_nut.php --params a:0:{}
 6939 ?        S     18:36  \_ php -q ./scripts/cycle_bletool.php --params a:0:{}
 6940 ?        S      3:02  \_ php -q ./scripts/cycle_webvars.php --params a:0:{}
 6942 ?        S     10:19  \_ php -q ./scripts/cycle_phistory.php --params a:0:{}
 6943 ?        S     30:00  \_ php -q ./scripts/cycle_telegram.php --params a:0:{}
 6944 ?        S     20:30  \_ php -q ./scripts/cycle_sysinfo.php --params a:0:{}
 6968 ?        S     10:49  \_ php -q ./scripts/cycle_main.php --params a:0:{}
 6988 ?        S      3:07  \_ php -q ./scripts/cycle_ping.php --params a:0:{}
 7052 ?        S     18:44  \_ php -q ./scripts/cycle_cron.php --params a:0:{}
 7056 ?        S     17:28  \_ php -q ./scripts/cycle_xiaomimiio.php --params a:0:{}
 7066 ?        S     18:08  \_ php -q ./scripts/cycle_states.php --params a:0:{}
 7090 ?        S      9:48  \_ php -q ./scripts/cycle_scheduler.php --params a:0:{}
 7092 ?        S     32:11  \_ php -q ./scripts/cycle_wscache.php --params a:0:{}
10538 ?        S     33:56  \_ php -q ./scripts/cycle_mqtt.php --params a:0:{}
26832 ?        S      3:44  \_ php -q ./scripts/cycle_bluetoothdevices.php --params a:0:{}
26863 ?        S      4:19  \_ php -q ./scripts/cycle_xiaomihome.php --params a:0:{}
28317 ?        S      8:01  \_ php -q ./scripts/cycle_sys_date_format.php --params a:0:{}
29111 ?        S      5:54  \_ php -q ./scripts/cycle_websockets.php --params a:0:{}
20670 ?        Ss     0:00  |   \_ php-fpm: master process (/usr/local/etc/php-fpm.conf)
20896 ?        S      0:01  |       \_ php-fpm: pool www
20897 ?        S      0:00  |       \_ php-fpm: pool www
21282 ?        S      0:00  |       \_ php-fpm: pool www
