Версия от 09/19/2013 19:12
Добавлено: Пт сен 20, 2013 6:30 am
Только у меня после обновления от 09/19/2013 19:12 Алиса перестала говорить?
Sep 20, 2013 09:54:18 http://127.0.0.1/admin.php?pd=c2NyaXB0czp7aW5zdGFuY2U9YWRtfQ%3D%3Dpz_cGFuZWw6e2FjdGlvbj1zY3JpcHRzfQ%3D%3Dpz_&md=scripts&inst=adm&view_mode=run_script&id=12
Error:
1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
SELECT * FROM commands WHERE LINKED_OBJECT LIKE 'netping_o1' AND LINKED_PROPERTY LIKE 'status' AND
Warning: mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in D:\_majordomo\htdocs\lib\htmlMimeMail.class.php on line 691
$tables = array('commands', 'owproperties', 'snmpproperties', 'zwave_properties', 'mqtt');
if (!is_array($no_linked) && $no_linked)
$no_linked=array();
foreach($tables as $t)
$no_linked[$k]='0';
elseif (is_array($no_linked))
if (!isset($no_linked[$k]))
$no_linked[$k]='1';
else
$no_linked=array();
$no_linked[$k]='1';
$commands = SQLSelect("SELECT * FROM commands WHERE LINKED_OBJECT LIKE '" . DBSafe($this->object_title) . "' AND LINKED_PROPERTY LIKE '" . DBSafe($property) . "' AND " . $no_linked['commands']);
$snmpdevices = SQLSelect("SELECT ID FROM snmpproperties WHERE LINKED_OBJECT LIKE '" . DBSafe($this->object_title) . "' AND LINKED_PROPERTY LIKE '" . DBSafe($property) . "' AND " . $no_linked['snmpproperties']);
$total = count($snmpdevices);
if ($total)
if (isset($snmpdevices))
