Привет.
Имеем ошибку:
http://*****************/admin.php?md=panel&action=market&ok_msg=Plugin+%27charts%27+%282019-11-27+17%3A43%3A37%29+installed.
144: Table './db_terminal/phistory' is marked as crashed and last (automatic?) repair failed
SHOW FIELDS FROM `phistory`
#0 /var/www/lib/mysqli.class.php(400): custom_error->__construct('144: Table './d...', 0)
#1 /var/www/lib/mysqli.class.php(189): mysql->Error('SHOW FIELDS FRO...', 0)
#2 /var/www/lib/mysqli.class.php(208): mysql->Exec('SHOW FIELDS FRO...')
#3 /var/www/lib/sqlFunctions.class.php(70): mysql->Select('SHOW FIELDS FRO...')
#4 /var/www/lib/sqlFunctions.class.php(219): SQLSelect('SHOW FIELDS FRO...')
#5 /var/www/lib/module.class.php(494): SQLGetFields('phistory')
#6 /var/www/modules/objects/objects.class.php(1215): module->dbInstall(' objects: ID in...')
#7 /var/www/lib/module.class.php(381): objects->dbInstall(' objects: ID in...')
#8 /var/www/modules/objects/objects.class.php(1101): module->install('')
#9 /var/www/lib/module.class.php(313): objects->install()
#10 /var/www/modules/objects/objects.class.php(28): module->checkInstalled()
#11 /var/www/modules/control_modules/control_modules.class.php(226) : eval()'d code(1): objects->__construct()
#12 /var/www/modules/control_modules/control_modules.class.php(226): eval()
#13 /var/www/lib/module.class.php(313): control_modules->install()
#14 /var/www/modules/control_modules/control_modules.class.php(22): module->checkInstalled()
#15 /var/www/admin.php(25): control_modules->__construct()
#16 {main}
... и таких 18 штук.
Что делать?
Проблемы с БД
- KVN
Re: Проблемы с БД
