Лог Apache2
Добавлено: Чт авг 31, 2017 9:32 pm
Доброго всем времени.
Может кто подскажет как исправить ошибку.
В Apache2 в error.log при обращении к сайту сыпятся ошибки.
Google- в помощь ни чего не дала.
[Thu Aug 31 21:14:32 2017] [error] [client 192.168.1.33] PHP Warning: require(./modules/devices/system_checkstate.php): failed to open stream: No such file or directory in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:14:32 2017] [error] [client 192.168.1.33] PHP Fatal error: require(): Failed opening required './modules/devices/system_checkstate.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:19:34 2017] [error] [client 192.168.1.33] PHP Warning: require(./modules/devices/system_checkstate.php): failed to open stream: No such file or directory in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:19:34 2017] [error] [client 192.168.1.33] PHP Fatal error: require(): Failed opening required './modules/devices/system_checkstate.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:24:33 2017] [error] [client 192.168.1.33] PHP Warning: require(./modules/devices/system_checkstate.php): failed to open stream: No such file or directory in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:24:33 2017] [error] [client 192.168.1.33] PHP Fatal error: require(): Failed opening required './modules/devices/system_checkstate.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
