http://192.168.88.42/objects/?object=KitchenHCSR501&op=m&m=MetodAlarm
http://192.168.88.42/objects/?object=KitchenHCSR501&op=set&p=alarm&v=1
Страница 192.168.88.42 не работает
Сайт 192.168.88.42 пока не может обработать этот запрос.
HTTP ERROR 500
[Sat Mar 11 18:54:51.003605 2017] [:error] [pid 25822] [client 192.168.88.57:47412] PHP Fatal error: Uncaught Error: Call to a member function setProperty() on null in /var/www/modules/objects/objects.class.php(514) : eval()'d code:1\nStack trace:\n#0 /var/www/modules/objects/objects.class.php(514): eval()\n#1 /var/www/modules/objects/objects.class.php(471): objects->callMethod('MetodAlarm', Array, 1)\n#2 /var/www/modules/objects/objects.class.php(754): objects->callMethod('MetodAlarm', Array)\n#3 /var/www/objects/index.php(138): objects->setProperty('alarm', '1')\n#4 {main}\n thrown in /var/www/modules/objects/objects.class.php(514) : eval()'d code on line 1
[Sat Mar 11 18:59:56.637868 2017] [:error] [pid 27727] [client 192.168.88.57:48020] PHP Fatal error: Uncaught Error: Call to a member function setProperty() on null in /var/www/modules/objects/objects.class.php(514) : eval()'d code:1\nStack trace:\n#0 /var/www/modules/objects/objects.class.php(514): eval()\n#1 /var/www/modules/objects/objects.class.php(471): objects->callMethod('MetodAlarm', Array, 1)\n#2 /var/www/objects/index.php(152): objects->callMethod('MetodAlarm', Array)\n#3 {main}\n thrown in /var/www/modules/objects/objects.class.php(514) : eval()'d code on line 1, referer: http://192.168.88.42/admin.php?pd=Y2xhc3Nlczp7aWQ9MzUsdmlld19tb2RlPWVkaXRfY2xhc3Nlcyx0YWI9b2JqZWN0cyxpbnN0YW5jZT1hZG19pz_cGFuZWw6e2FjdGlvbj1jbGFzc2VzfQ%3D%3Dpz_&md=objects&inst=&view_mode=edit_objects&id=82&tab=methods&overwrite=1&method_id=106
