Попробуй обновится - и покажи что после команды выводит в ХРЕЙ - где начало фразы MAG250
[Простое устройство] Приставка MAG 255
- tarasfrompir
Re: [Простое устройство] Приставка MAG 255
обновился, нажатие различных кнопок виртуального пульта ничего не пишет в лог,в xray:
11:01:43 0.26153300 (2020-01-06_threads.log) Adding cycle_onvif to auto-recovery list
11:01:12 0.65740400 (2020-01-06_threads.log) Starting service cycle_onvif (./scripts/cycle_onvif.php)
11:00:43 0.14703200 (2020-01-06_threads.log) Thread closed: cycle_onvif
11:00:42 0.13711500 (2020-01-06_threads.log) Result:
11:00:42 0.12910200 (2020-01-06_threads.log) Executing: kill -9 5890
11:00:42 0.13807100 (2020-01-06.log) Closing thread: exec php -q ./scripts/cycle_onvif.php --params "a:0:{}" > /dev/null 2>&1
11:00:42 0.12857000 (2020-01-06_threads.log) Force closing service cycle_onvif (id: 30)
11:00:42 0.10544200 (2020-01-06_threads.log) Got control command 'restart' for cycle_onvif
11:00:42 0.12887200 (2020-01-06_threads.log) Closing thread 5890 (exec php -q ./scripts/cycle_onvif.php --params "a:0:{}" > /dev/null 2>&1)
11:00:41 0.51215600 (2020-01-06_terminals.log) Processing HOURLY: {"BREAK":false}
11:00:39 0.00559500 (2020-01-06_reinstall.log) Installing thumb ...
11:00:39 0.06750100 (2020-01-06_reinstall.log) Installing xray ...
11:00:39 0.05455200 (2020-01-06_reinstall.log) Installing webvars ...
11:00:39 0.04436600 (2020-01-06_reinstall.log) Installing watchfolders ...
11:00:39 0.02386500 (2020-01-06_reinstall.log) Installing users ...
11:00:39 0.00787100 (2020-01-06_reinstall.log) Installing usbdevices ...
11:00:39 0.09060800 (2020-01-06_reinstall.log) Installing yandex_tts ...
11:00:39 0.09825900 (2020-01-06_reinstall.log) Installing yandexhome ...
11:00:38 0.43464400 (2020-01-06_reinstall.log) Installing pvalues ...
11:00:38 0.13506100 (2020-01-06_reinstall.log) Installing objects ...
11:00:38 0.16301000 (2020-01-06_reinstall.log) Installing onewire ...
11:00:38 0.21382000 (2020-01-06_reinstall.log) Installing onvif ...
11:00:38 0.25278200 (2020-01-06_reinstall.log) Installing optimizer ...
11:00:38 0.25751300 (2020-01-06_reinstall.log) Installing patterns ...
11:00:38 0.26427400 (2020-01-06_reinstall.log) Installing pinghosts ...
11:00:38 0.84437300 (2020-01-06_reinstall.log) Installing textfiles ...
11:00:38 0.83526400 (2020-01-06_reinstall.log) Installing terminals ...
11:00:38 0.81877900 (2020-01-06_reinstall.log) Installing telegram ...
11:00:38 0.80490700 (2020-01-06_reinstall.log) Installing system_errors ...
11:00:38 0.42044600 (2020-01-06_reinstall.log) Installing properties ...
11:00:38 0.78727800 (2020-01-06_reinstall.log) Installing soundfiles ...
11:00:38 0.73227100 (2020-01-06_reinstall.log) Installing skins ...
11:00:38 0.66200900 (2020-01-06_reinstall.log) Installing shoutrooms ...
11:00:38 0.65601000 (2020-01-06_reinstall.log) Installing shoutbox ...
11:00:38 0.64791200 (2020-01-06_reinstall.log) Installing settings ...
11:00:38 0.64148200 (2020-01-06_reinstall.log) Installing security_rules ...
11:00:38 0.62962400 (2020-01-06_reinstall.log) Installing scripts ...
11:00:38 0.61602000 (2020-01-06_reinstall.log) Installing scenes ...
11:00:38 0.40004000 (2020-01-06_reinstall.log) Installing plans ...
11:00:38 0.57093900 (2020-01-06_reinstall.log) Installing rss_channels ...
11:00:38 0.78050500 (2020-01-06_reinstall.log) Installing snmpdevices ...
11:00:38 0.61330600 (2020-01-06_reinstall.log) Installing saverestore ...
11:00:38 0.98440400 (2020-01-06_reinstall.log) Installing thermostats ...
11:00:37 0.95835400 (2020-01-06_reinstall.log) Installing modbus ...
11:00:37 0.27601200 (2020-01-06_reinstall.log) Installing history ...
11:00:37 0.33317600 (2020-01-06_reinstall.log) Installing knxdevices ...
11:00:37 0.35730800 (2020-01-06_reinstall.log) Installing layouts ...
11:00:37 0.43889700 (2020-01-06_reinstall.log) Installing linkedobject ...
11:00:37 0.44613800 (2020-01-06_reinstall.log) Installing locations ...
11:00:37 0.47032700 (2020-01-06_reinstall.log) Installing market ...
11:00:37 0.31852800 (2020-01-06_reinstall.log) Installing jobs ...
11:00:37 0.47714300 (2020-01-06_reinstall.log) Installing master ...
11:00:37 0.99682000 (2020-01-06_reinstall.log) Installing myblocks ...
11:00:37 0.99143900 (2020-01-06_reinstall.log) Installing mqtt ...
11:00:37 0.51715600 (2020-01-06_reinstall.log) Installing methods ...
11:00:36 0.90916400 (2020-01-06_reinstall.log) Installing events ...
11:00:36 0.87187500 (2020-01-06_reinstall.log) Installing devices ...
11:00:36 0.84371300 (2020-01-06_reinstall.log) Installing dev_broadlink ...
11:00:36 0.85859100 (2020-01-06_reinstall.log) Installing dev_sonoff ...
11:00:34 0.81537200 (2020-01-06.log) Installing/updating plugin SMagXXXdevice (2020-01-05 20:56:23)
- tarasfrompir
попробуй на гугл хром браузере сделать все это - а не дргугом браузереdmw писал(а): ↑Пн янв 06, 2020 10:17 amобновился, нажатие различных кнопок виртуального пульта ничего не пишет в лог,в xray:СпойлерПоказать11:01:43 0.26153300 (2020-01-06_threads.log) Adding cycle_onvif to auto-recovery list
на нем и делал. что мы там должны увидеть?tarasfrompir писал(а): ↑Пн янв 06, 2020 12:50 pmпопробуй на гугл хром браузере сделать все это - а не дргугом браузере
- tarasfrompir
Правда не работало - чего так хзdmw писал(а): ↑Вт янв 07, 2020 9:40 amна нем и делал. что мы там должны увидеть?tarasfrompir писал(а): ↑Пн янв 06, 2020 12:50 pmпопробуй на гугл хром браузере сделать все это - а не дргугом браузере
Переделал на сработку методов а не не через свойства - пробуй...
У меня заработало. Не все кнопки правда работают.
А как запилить управление голосом ?
- tarasfrompir
оно уже запилено - в терминале вводь команды
типа "включи канал 1"
выбери из нижнего
"нажми|включи канал|выбери канал|канал|клацни"
или
"добавить громкость|добавить громкости|добавить звук|добавь звук"
"'убавить громкость|убавить громкости|убавить звук|убавь звук"
все есть в - файле htdocs\languages\SMagXXXdevice_ru - для русского
- Dgeday (Ср янв 08, 2020 3:46 pm)
- tarasfrompir
По поводу кнопок - какие не работают ?
- tarasfrompir
А голосовое управление работает ?
