https://prnt.sc/n7geaz
при нажатии на изображение
https://prnt.sc/n7gg8q
лог апача
[Thu Apr 04 13:00:03.510046 2019] [:error] [pid 19972] [client 127.0.0.1:42648] PHP Fatal error: Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 13:46:17.083936 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning: scandir(/var/www/html/cms/cached/nvr/cam1/): failed to open dir: No such file or directory in /var/www/html/modules/camshoter/camshoter.clas$
[Thu Apr 04 13:46:17.083999 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning: scandir(): (errno 2): No such file or directory in /var/www/html/modules/camshoter/camshoter.class.php on line 1113, referer: http://192.168$
[Thu Apr 04 13:46:17.084011 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning: array_diff(): Argument #1 is not an array in /var/www/html/modules/camshoter/camshoter.class.php on line 1113, referer: http://192.168.0.251$
[Thu Apr 04 13:46:17.084020 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning: Invalid argument supplied for foreach() in /var/www/html/modules/camshoter/camshoter.class.php on line 1114, referer: http://192.168.0.251/a$
[Thu Apr 04 13:46:17.084037 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning: rmdir(/var/www/html/cms/cached/nvr/cam1/): No such file or directory in /var/www/html/modules/camshoter/camshoter.class.php on line 1117, re$
[Thu Apr 04 14:00:03.216394 2019] [:error] [pid 19967] [client 127.0.0.1:33586] PHP Fatal error: Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 15:00:03.275777 2019] [:error] [pid 18504] [client 127.0.0.1:52452] PHP Fatal error: Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 16:00:03.687982 2019] [:error] [pid 21264] [client 127.0.0.1:43612] PHP Fatal error: Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 17:00:03.689726 2019] [:error] [pid 21264] [client 127.0.0.1:34732] PHP Fatal error: Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
"ID": "1",
"NAME": "Admin"
"USERNAME": "",
"META": ""
16:56:41 0.59004100
$online=ping(processTitle("192.168.0.24"));
if ($online)
{SQLexec("update camshoter_devices set ONLINE=1, LASTPING2=1554386201 where IPADDR='192.168.0.24'");}
else
{SQLexec("update camshoter_devices set ONLINE=0, LASTPING2=1554386201 where IPADDR='192.168.0.24'");}
16:56:41 0.59046100 total:1
16:56:41 0.59060500 camshoter storage dir:/var/www/html/cms/cached/nvr/cam1/2019-04-04/
16:56:41 0.59067000 camshoter storage cnt:9
16:56:41 0.59073000 camshoter upfoler:2019-04-04
16:56:41 0.59079200 camshoter upfoler1:cam1
16:56:41 0.59124200 вызван getusers /var/www/html/cms/cached/nvr/last/
16:56:41 0.59137100 $upfoler last
16:56:41 0.59143500 $upfoler1 nvr
16:56:41 0.59152000 .
16:56:41 0.59159900 ..
16:56:41 0.59170100 cam1.jpg
16:56:41 0.59184600 [
"FILE": "last\/cam1.jpg",
"SIZETHMB": 300,
"ID": null,
"USERS": [
"ID": "1",
"NAME": "Admin"
"USERNAME": "",
"META": ""
16:56:41 0.59214300 select ID,NAME,ADMIN ,(SELECT count(*) FROM camshoter_devices where ID='1' and TELEGRAMUSERS like CONCAT('%',tlg_user.ID,'%' ) ) as ACCESS_USER from tlg_user
16:56:41 0.59251000 [
"ID": "1",
"NAME": "keeper ",
"ADMIN": "1",
"ACCESS_USER": "0"
https://prnt.sc/n7gj4f
система
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
подскажите в чем может быть дело
