В каком именно логе?
[Модуль] Sonoff (dev_sonoff)
- yii
в логе модуля, включается в настройках, было про это не более 5ти страниц назад.
включение кнопкой на реле
20:39:02 0.53241800 [wss] +++ {"action":"update","deviceid":"10008ead01","apikey":"97a5aaa4-9958-43ec-b5ef-aeee2a467378","userAgent":"device","ts":0,"params":{"switch":"off"},"from":"device","seq":"32"}
20:38:56 0.81991500 [wss] +++ {"action":"update","deviceid":"10008ead01","apikey":"97a5aaa4-9958-43ec-b5ef-aeee2a467378","userAgent":"device","ts":0,"params":{"switch":"on"},"from":"device","seq":"31"}
включение\выключение в объекте sonoff
21:00:01 0.82837200 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"Hvnt9d7v","apkVesrion":"1.8","os":"ios","at":"82527f964aacb16b6249e7fe0e0d01cdff04d63d","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","ts":1569520801,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1569520801000}
21:00:01 0.52581600 [wss] --- {"action":"update","userAgent":"app","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","deviceid":"10008ead01","params":{"switch":"off"},"sequence":1569520801000}
20:59:26 0.82817300 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"ycUzI7ew","apkVesrion":"1.8","os":"ios","at":"82527f964aacb16b6249e7fe0e0d01cdff04d63d","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","ts":1569520766,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1569520766000}
20:59:26 0.60843100 [wss] --- {"action":"update","userAgent":"app","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","deviceid":"10008ead01","params":{"switch":"on"},"sequence":1569520766000}
включение кнопкой на сцене
21:01:12 0.04756800 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"9Y0xoEvV","apkVesrion":"1.8","os":"ios","at":"82527f964aacb16b6249e7fe0e0d01cdff04d63d","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","ts":1569520872,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1569520872000}
21:01:11 0.83122600 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"3QCqlylE","apkVesrion":"1.8","os":"ios","at":"82527f964aacb16b6249e7fe0e0d01cdff04d63d","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","ts":1569520871,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1569520871000}
21:01:11 0.79161800 [wss] --- {"action":"update","userAgent":"app","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","deviceid":"10008ead01","params":{"switch":"off"},"sequence":1569520871000}
21:01:11 0.57708000 [wss] --- {"action":"update","userAgent":"app","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","deviceid":"10008ead01","params":{"switch":"off"},"sequence":1569520871000}
21:01:09 0.08313400 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"5TFXVirq","apkVesrion":"1.8","os":"ios","at":"82527f964aacb16b6249e7fe0e0d01cdff04d63d","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","ts":1569520869,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1569520869000}
21:01:08 0.97477100 [wss] --- {"action":"userOnline","userAgent":"app","version":6,"nonce":"gUOgqhVj","apkVesrion":"1.8","os":"ios","at":"82527f964aacb16b6249e7fe0e0d01cdff04d63d","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","ts":1569520868,"model":"iPhone10,6","romVersion":"11.1.2","sequence":1569520868000}
21:01:08 0.86211300 [wss] --- {"action":"update","userAgent":"app","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","deviceid":"10008ead01","params":{"switch":"on"},"sequence":1569520868000}
21:01:08 0.72926200 [wss] --- {"action":"update","userAgent":"app","apikey":"6be51bcb-aee5-4de7-9906-b34afe10db35","deviceid":"10008ead01","params":{"switch":"on"},"sequence":1569520868000}
21:01:06 0.06660400 [wss] +++ {"action":"update","deviceid":"10008ead01","apikey":"97a5aaa4-9958-43ec-b5ef-aeee2a467378","userAgent":"device","ts":0,"params":{"rssi":-68},"from":"device"}
У вас вообще команды на включение не уходит. Это не отрабатывает что то ещё до модуля, в самой системе. Попробуйте, как выше писали, создать новый объект (можно даже не в классе ПУ), и пощелкать через него. В крайнем случае могу сам подключиться глянуть.
- yii
А еще меня смущает что с девайса и с md разные APIkey...
вот мой кусок лога, в обе стороны одинаковый APIkey, в модуле логин по дополнительному аккаунту для которого рассшарены девайсы с основного аккаунта, в ewelink - основной аккаунт
включение из md
14:21:51 0.13747500 [wss] --- {"action":"update","userAgent":"app","apikey":"b29ed8f7-2fbb-4590-8447-9cd6e1ec7f72","deviceid":"1000787394","params":{"switch":"on"},"sequence":1569568911000}
выключение из ewelink
14:23:14 0.64693600 [wss] +++ {"action":"update","deviceid":"1000787394","apikey":"b29ed8f7-2fbb-4590-8447-9cd6e1ec7f72","userAgent":"app","sequence":"1569569000745","ts":0,"params":{"switch":"off"},"tempRec":"1000787394"}
включение из md
Поразбирались тут с человеком...выяснилось что не включает только с доп. учетки, на которую девайсы расшарены. С основной всё работает. Так что вот, на заметку...в МД используйте пока основную учетку...а с доп.учеткой - надо трафик снифить, и смотреть чем пакеты отличаются...может из доп.учетки какие нить нестандартные параметры дополнительно летят...я хз.
- yii
все интереснее и интереснее... на всякий случай, напомню, что у меня мд живет на доп учетке, и все работает....nick7zmail писал(а): ↑Сб сен 28, 2019 10:43 pmвыяснилось что не включает только с доп. учетки, на которую девайсы расшарены. С основной всё работает. Так что вот, на заметку...
- samolet
Добрый день, у Модели
RFBridge
не срабатывает передача записанного кода, срабатывает только через приложение а с мд нету, Никита подскажи что в таком случае делать?
RFBridge
Ну вроде с одним человеком тестировали - работало на тот момент. У меня самого RFBridge нету, подсказать не могу к сожалению. Только снифить трафик от приложения, и искать отличие с тем, что отправляет МД.
