[Модуль] Sonoff (dev_sonoff)
samolet
Сообщение samolet » Чт май 02, 2019 9:04 am
Время падения цикла одинаковое практически, от 2 но не больше 3 минут
09:00:59 0.19296700 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
09:00:01 0.70126900 Не удалось обновить курс валют
08:58:13 0.98554000 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:55:29 0.56166300 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:52:44 0.62728600 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:50:00 0.65098900 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:47:16 0.27444700 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:44:32 0.41490900 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:41:47 0.19244700 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:39:02 0.05295600 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:36:17 0.03981100 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:33:32 0.95309100 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:30:49 0.04055500 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:28:04 0.85697600 Closing thread: c:/_majordomo/server/php/php.exe -q ./scripts/cycle_dev_sonoff.php --params "a:0:{}" > NUL
08:25:19 0.68281800 Closing thread: c:/_majord
вот это что за параметр ??? params "a:0:{}" > NUL
VAndrey
Сообщение VAndrey » Пт май 03, 2019 11:08 pm
Парни, ну как у вас обстановка? У меня то работает модуль, то нет. Не врубаюсь - почему?
Давайте уговорим Никиту дать нам секретный код, как временную меру пока решается проблема пинг-понга, которым можно будет передергивать обновление данных в кроне...
yii
Сообщение yii » Сб май 04, 2019 5:38 am
У меня прекрасно работает по http.
Вы бы версию модуля указали.
Прошлый который только по http у меня работал без проблем.
Новый с тестовыми веб сокетами не работает в режиме веб сокетов, но так же прекрасно как и предыдущий работает по http, поэтому жду очередного обновления вебсокетов, а пока по прежнему без каких либо проблем использую http.
PHP нужно 7.x, c 5.x не работает (лично прошел через это в момент появления первых версий модуля)
VAndrey
Сообщение VAndrey » Сб май 04, 2019 10:03 am
Версия от 13 апреля. Последняя. РНР седьмая версия. Но работает через раз.
yii
Сообщение yii » Сб май 04, 2019 4:20 pm
Эта же версия модуля и PHP, на raspberry образ 3.31 + обновления, в http режиме работает без ошибок
samolet
Сообщение samolet » Вс май 05, 2019 11:14 pm
я конечно все понимаю, но почему после последнего обновления системы пошел глюк в модуле соноф??????????? Это хорошо что я сохраняю папку мажорика целиком, так вот до 13.04.2019 года все было хорошо, после этой даты начались опять ложные срабатывания, не ну чесное слово, Сергею надо как-то за этим следить, ведь это он же постоянно обновы шлет, при чем не всегда удачные.
yii
Сообщение yii » Пн май 06, 2019 4:08 am
Вот поэтому сам MD обновляю тока с предварительным бакапом примерно раз в 3 месяца :)
Stan
Сообщение Stan » Вт май 07, 2019 6:18 pm
я конечно все понимаю, но почему после последнего обновления системы пошел глюк в модуле соноф???????????...
А если на мастер версию перейти? Не?
samolet
Сообщение samolet » Ср май 08, 2019 7:22 am
так и загружена стабильная мастер версия, пока я ее откатил до 13 апреля, и все хорошо работает.
chelovert
Сообщение chelovert » Ср май 08, 2019 2:07 pm
всем привет. не знаю, обсуждалось или нет. не перечитывал все 63 страницы форума, но почему не сделать модуль , который работает через локалку? ( я пока только начал разбираться с sonoff , так что если есть такой модуль для majordomo, то тыкните пальцем плз) sonoff basic например нормально работает по http . принимает POST запрос с json , в котором не нужны никакие apikey итп... тупо принимает команду на вкл, выкл...
