добавил в идеи, может когда нибудь соберусь сделать, если будет востребовано
UPD: добавлена локализация
надо удалить backup_temp в папке C:\BackupPlug писал(а): Ср апр 11, 2018 11:08 am Сегодня стал выдавать ошибку:
Working on backup.
Create temp directory C:\Backup\backup_temp\ ... Warning: mkdir(): File exists in C:\_majordomo\htdocs\modules\backup\backup.class.php on line 288 Error
какие настройки заданы? особенно интересуют настройки на вкладке "настройки резервной копии"Alex77 писал(а): Ср апр 11, 2018 10:00 pm Warning: copy(/var/www/html/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_te in /var/www/html/modules/backup/backup.class.php on line 464
Имя каталога не трогал поставил все галочки включая Резервировать базу данных:Eraser писал(а): Чт апр 12, 2018 7:40 amкакие настройки заданы? особенно интересуют настройки на вкладке "настройки резервной копии"Alex77 писал(а): Ср апр 11, 2018 10:00 pm Warning: copy(/var/www/html/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_temp/backup_te in /var/www/html/modules/backup/backup.class.php on line 464
яндекс диск через webdav
include(DIR_MODULES . 'backup/backup.class.php');
$backup_module = new backup();
$backup_module->create_backup();Да.Alex77 писал(а): ...
я правильно понял что бы программно сделать бекап надо так
include(DIR_MODULES . 'backup/backup.class.php'); $backup_module = new backup(); $backup_module->create_backup();
