Добавлено: Вт фев 08, 2022 5:40 pm
В качестве шлюза используется zigbee2mqtt, система стоит на win10. Согласен по поводу датчиков, иногда действительно криво подцеплялись, но тут я его раза 4 удалял и добавлял...
В топиках все корректно:
Zigbee2MQTT:info 2022-02-08 17:30:15: Logging to console and directory: 'C:\_majordomo\htdocs\modules\zigbee2mqtt\data\log\2022-02-08.17-30-14' filename: log.txt
Zigbee2MQTT:info 2022-02-08 17:30:15: Starting Zigbee2MQTT version 1.18.3 (commit #unknown)
Zigbee2MQTT:info 2022-02-08 17:30:15: Starting zigbee-herdsman (0.13.92)
Zigbee2MQTT:info 2022-02-08 17:30:26: zigbee-herdsman started
Zigbee2MQTT:info 2022-02-08 17:30:26: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 2022-02-08 17:30:26: Currently 1 devices are joined:
Zigbee2MQTT:info 2022-02-08 17:30:26: 0x00158d0006ec67e3 (0x00158d0006ec67e3): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
Zigbee2MQTT:warn 2022-02-08 17:30:26: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2022-02-08 17:30:26: Allowing new devices to join.
Zigbee2MQTT:warn 2022-02-08 17:30:26: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info 2022-02-08 17:30:26: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2022-02-08 17:30:26: Connecting to MQTT server at mqtt://localhost
Zigbee2MQTT:info 2022-02-08 17:30:27: Connected to MQTT server
Zigbee2MQTT:info 2022-02-08 17:30:27: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2022-02-08 17:30:27: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"},"log_level":"info","network":{"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":true,"version":"1.18.3"}'
Zigbee2MQTT:info 2022-02-08 17:30:52: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00158d0006ec67e3","ieee_address":"0x00158d0006ec67e3"},"type":"device_announce"}'
Zigbee2MQTT:info 2022-02-08 17:30:52: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"0x00158d0006ec67e3"},"type":"device_announced"}'
Zigbee2MQTT:info 2022-02-08 17:30:53: MQTT publish: topic 'zigbee2mqtt/0x00158d0006ec67e3', payload '{"battery":100,"contact":false,"linkquality":234,"temperature":34,"voltage":3015}'
