Сообщение directman66 » Ср апр 01, 2020 12:19 pm
Denis_k писал(а):
Ср апр 01, 2020 11:58 am
в итоге пару дней работы модуля без сбоев, потом сбой всей системы (причину не выяснил), перезагрузка и аналогичная ситуация с постоянной остановкой модуля
1585731314: /opt/zigbee2mqtt/data/log/2020-04-01.07-42-43/log.txt
debug 2020-04-01 11:52:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:47:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:42:45: Saving state to file /opt/zigbee2mqtt/data/state.json
warn 2020-04-01 11:41:52: Soft resetted ZNP due to timeout
warn 2020-04-01 11:41:52: Soft reset timeout triggered
debug 2020-04-01 11:37:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:32:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:27:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:22:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:17:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:12:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:07:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 11:02:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:57:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:52:45: Saving state to file /opt/zigbee2mqtt/data/state.json
warn 2020-04-01 10:51:52: Soft resetted ZNP due to timeout
warn 2020-04-01 10:51:52: Soft reset timeout triggered
debug 2020-04-01 10:47:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:42:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:37:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:32:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:27:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:22:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:17:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:12:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:07:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 10:02:45: Saving state to file /opt/zigbee2mqtt/data/state.json
warn 2020-04-01 10:01:52: Soft resetted ZNP due to timeout
warn 2020-04-01 10:01:51: Soft reset timeout triggered
debug 2020-04-01 09:57:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:52:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:47:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:42:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:37:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:32:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:27:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:22:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:17:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:12:45: Saving state to file /opt/zigbee2mqtt/data/state.json
warn 2020-04-01 09:11:51: Soft resetted ZNP due to timeout
warn 2020-04-01 09:11:51: Soft reset timeout triggered
debug 2020-04-01 09:07:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 09:02:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:57:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:52:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:47:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:42:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:37:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:32:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:27:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:22:45: Saving state to file /opt/zigbee2mqtt/data/state.json
info 2020-04-01 08:21:51: MQTT publish: topic 'zigbee2mqtt/0x00158d000410c4ae', payload '{"battery":91,"voltage":2985,"contact":true,"linkquality":113}'
debug 2020-04-01 08:21:51: Received Zigbee message from '0x00158d000410c4ae', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":2985,"3":30,"4":17320,"5":23,"6":[0,851982],"10":0,"100":0}}' from endpoint 1 with groupID 0
debug 2020-04-01 08:17:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:12:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:07:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 08:02:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 07:57:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 07:52:45: Saving state to file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 07:47:45: Saving state to file /opt/zigbee2mqtt/data/state.json
info 2020-04-01 07:43:13: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.11.0","commit":"e140cf5","coordinator":{"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200128}},"log_level":"debug","permit_join":false}'
info 2020-04-01 07:43:13: Zigbee: disabling joining new devices.
debug 2020-04-01 07:43:13: Received MQTT message on 'zigbee2mqtt/bridge/config/permit_join' with data 'false'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/sensor/0x00158d000410c4ae/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00158d000410c4ae","json_attributes_topic":"zigbee2mqtt/0x00158d000410c4ae","name":"0x00158d000410c4ae_linkquality","unique_id":"0x00158d000410c4ae_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000410c4ae"],"name":"0x00158d000410c4ae","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/sensor/0x00158d000410c4ae/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/0x00158d000410c4ae","json_attributes_topic":"zigbee2mqtt/0x00158d000410c4ae","name":"0x00158d000410c4ae_battery","unique_id":"0x00158d000410c4ae_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000410c4ae"],"name":"0x00158d000410c4ae","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/binary_sensor/0x00158d000410c4ae/contact/config', payload '{"payload_on":false,"payload_off":true,"value_template":"{{ value_json.contact }}","device_class":"door","state_topic":"zigbee2mqtt/0x00158d000410c4ae","json_attributes_topic":"zigbee2mqtt/0x00158d000410c4ae","name":"0x00158d000410c4ae_contact","unique_id":"0x00158d000410c4ae_contact_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000410c4ae"],"name":"0x00158d000410c4ae","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/sensor/0x00158d00045d0200/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00158d00045d0200","json_attributes_topic":"zigbee2mqtt/0x00158d00045d0200","name":"0x00158d00045d0200_linkquality","unique_id":"0x00158d00045d0200_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00045d0200"],"name":"0x00158d00045d0200","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/sensor/0x00158d00045d0200/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/0x00158d00045d0200","json_attributes_topic":"zigbee2mqtt/0x00158d00045d0200","name":"0x00158d00045d0200_battery","unique_id":"0x00158d00045d0200_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00045d0200"],"name":"0x00158d00045d0200","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/sensor/0x00158d00045d0200/pressure/config', payload '{"unit_of_measurement":"hPa","device_class":"pressure","value_template":"{{ value_json.pressure }}","state_topic":"zigbee2mqtt/0x00158d00045d0200","json_attributes_topic":"zigbee2mqtt/0x00158d00045d0200","name":"0x00158d00045d0200_pressure","unique_id":"0x00158d00045d0200_pressure_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00045d0200"],"name":"0x00158d00045d0200","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/sensor/0x00158d00045d0200/humidity/config', payload '{"unit_of_measurement":"%","device_class":"humidity","value_template":"{{ value_json.humidity }}","state_topic":"zigbee2mqtt/0x00158d00045d0200","json_attributes_topic":"zigbee2mqtt/0x00158d00045d0200","name":"0x00158d00045d0200_humidity","unique_id":"0x00158d00045d0200_humidity_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00045d0200"],"name":"0x00158d00045d0200","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'homeassistant/sensor/0x00158d00045d0200/temperature/config', payload '{"unit_of_measurement":"°C","device_class":"temperature","value_template":"{{ value_json.temperature }}","state_topic":"zigbee2mqtt/0x00158d00045d0200","json_attributes_topic":"zigbee2mqtt/0x00158d00045d0200","name":"0x00158d00045d0200_temperature","unique_id":"0x00158d00045d0200_temperature_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00045d0200"],"name":"0x00158d00045d0200","sw_version":"Zigbee2mqtt 1.11.0","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
info 2020-04-01 07:42:48: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.11.0","commit":"e140cf5","coordinator":{"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200128}},"log_level":"debug","permit_join":true}'
info 2020-04-01 07:42:48: MQTT publish: topic 'zigbee2mqtt/0x00158d000410c4ae', payload '{"battery":91,"voltage":2985,"contact":true,"linkquality":110}'
info 2020-04-01 07:42:48: MQTT publish: topic 'zigbee2mqtt/0x00158d00045d0200', payload '{"battery":100,"voltage":3025,"temperature":25.1,"humidity":31.45,"pressure":984.3,"linkquality":102}'
info 2020-04-01 07:42:48: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
info 2020-04-01 07:42:48: Connected to MQTT server
info 2020-04-01 07:42:48: Connecting to MQTT server at mqtt://192.168.1.100:1883
debug 2020-04-01 07:42:48: Soft reset timeout set to 3000 seconds
info 2020-04-01 07:42:48: Zigbee: allowing new devices to join.
warn 2020-04-01 07:42:48: Set `permit_join` to `false` once you joined all devices.
warn 2020-04-01 07:42:48: Allowing new devices to join.
warn 2020-04-01 07:42:48: `permit_join` set to `true` in configuration.yaml.
info 2020-04-01 07:42:48: 0x00158d000410c4ae (0x00158d000410c4ae): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
info 2020-04-01 07:42:48: 0x00158d00045d0200 (0x00158d00045d0200): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
info 2020-04-01 07:42:48: Currently 2 devices are joined:
debug 2020-04-01 07:42:48: Zigbee network parameters: {"panID":6754,"extendedPanID":"0x00124b001940c125","channel":26}
info 2020-04-01 07:42:48: Coordinator firmware version: '{"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200128}}'
info 2020-04-01 07:42:48: zigbee-herdsman started
debug 2020-04-01 07:42:45: Using zigbee-herdsman with settings: '{"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[26],"networkKey":"HIDDEN"},"databasePath":"/opt/zigbee2mqtt/data/database.db","databaseBackupPath":"/opt/zigbee2mqtt/data/database.db.backup","backupPath":"/opt/zigbee2mqtt/data/coordinator_backup.json","serialPort":{"baudRate":115200,"rtscts":true,"path":"/dev/ttyACM0"}}'
info 2020-04-01 07:42:45: Starting zigbee-herdsman...
info 2020-04-01 07:42:45: Starting zigbee2mqtt version 1.11.0 (commit #e140cf5)
debug 2020-04-01 07:42:45: Loaded state from file /opt/zigbee2mqtt/data/state.json
debug 2020-04-01 07:42:43: Removing old log directory '/opt/zigbee2mqtt/data/log/2020-03-27.07-30-51'
Проверяйте питание и состояние носителя информации. Малина?
У меня на стац. компьютере с убунтой 18.04 система работает стабильно уже 5 месяцев без падения. В докере аналогично.
Denis_k
Сообщение Denis_k » Ср апр 01, 2020 2:34 pm
Да, малина. С питанием изменений не было, карту обновлял некоторое время назад. "Будем посмотреть"
Другие причины маловероятны?
MD на raspberry pi3
yurasvas
Сообщение yurasvas » Чт апр 02, 2020 8:29 pm
Друзья привет! Не могу настроить выключатели livolo TI0001. В приложении zigbee2mgtt их видно,кнопки вкл и вкл работают,но как только начинаю привязывать объект,работает только на выключение! Свойство: Status-статус,метод Switch-Switch! Может кто сталкивался с такой проблемой?
VOVA_iS
Сообщение VOVA_iS » Чт апр 02, 2020 8:56 pm
оставь только статус
yurasvas
Сообщение yurasvas » Чт апр 02, 2020 9:15 pm
А в самом выключателе все правильно прописал? Так 4 графы где привязка идет и + state графа
Сообщение directman66 » Пт апр 03, 2020 7:50 am
Внимание!!! Многие вопросы работы модуля освещены в данной заметке https://connect.smartliving.ru/profile/ ... og429.html
Вырезка из заметки:
** Также стоит отметить, что для "Простых устройств" типа реле, димеер и т.д. лучше привязывать метод switch, тогда логика управления будет соблюдена. Для датчиков нужно привязывать соотстветсвующие метрики. Одновременная привязка метода и метрики будет вызываться одновременно.
За это сообщение автора directman66 поблагодарили (всего 2):
Denis_k (Пт апр 03, 2020 8:46 am) • Nail (Пт апр 03, 2020 10:49 am)
SVCH
Сообщение SVCH » Пн апр 06, 2020 5:51 pm
Добрый день! Нужна помощь. Пытаюсь прошить стик СС2531. ОС Win10. Программа SmartRF Flash programmer не видит устройство.
iden
Сообщение iden » Вт апр 07, 2020 4:23 am
мало информации, сложно помочь. кириллицу лучше исключить.
в диспетчере устройств определяется, дебагер и стик в USB воткнули? тут посмотрите
SVCH
Сообщение SVCH » Вт апр 07, 2020 9:19 am
Стик определяется, а вот дебагер нет. Выходит дебагер неисправнен???
iden
Сообщение iden » Вт апр 07, 2020 10:41 am
я не могу вам сказать, никто не сможет. в телеграмме обсуждалось как то, помню один случай. вот группа телеграмм там можно спросить https://t.me/zigbeer
Неизвестно, например, устанавливался ли драйвер для дебагера?! ссылку выше я вам дал, делайте как там описано.
