Здравствуйте!
Купил розетку MI Smart Plug WiFi.
Токен получил с помощью MiHomeAdmin.
В МД (модуле) определилась как chuangmi.plug.v1, хотя в инфо сказано m3
{"result":{"life":358,"token":"ea73d4cd333cfeb5c7ee45bc51761edc","mac":"44:23:7C:52:62:D9","fw_ver":"1.3.0_0004","hw_ver":"ESP8266","model":"chuangmi.plug.m3","wifi_fw_ver":"1.5.0-dev(7f7a714)","ap":{"rssi":31,"ssid":"eov","bssid":"B4:FB:E4:8B:20:37"},"netif":{"localIp":"0.0.0.0","mask":"0.0.0.0","gw":"0.0.0.0"},"mmfree":11112},"id":1576201612}
При прямом wifi подключении к устройству нормально получаю info и могу управлять устройством из MiHomeAdmin.
После переключения на домашнюю сеть устройство перестает отвечать на запросы MiHomeAdmin->GetInfo (Bad Token, Timeout).
Модуль ведет себя аналогично.
Connection to device by IP 10.0.4.123 Debug status [1] Socked created Command to send - {"id":1576195608,"method":"miIO.info","params":[]} Checking device status by 10.0.4.123 Timeout SO_RCVTIMEO successfully set >>>>> Sending hello-packet to 10.0.4.123 with timeout 10 >>>>> Sent 32 bytes to socket <<<<< Reply received from IP 10.0.4.123 , port 54321 32 bytes received magic: 2131 length: 0020 --> 32 bytes unknown1: 00000000 devicetype: 0df5 serial: 98d9 ts: 0000060f --> 1551 seconds --> 1970-01-01 03:25:51 timediff: -1576194057 checksum: 00000000000000000000000000000000 ts_server: 5df2d618 --> 1576195608 seconds --> 2019-12-13 02:06:48 Device 10.0.4.123 available Timeout SO_RCVTIMEO successfully set Using manually set token - ea73d4cd333cfeb5c7ee45bc51761edc >>>>> Sending packet to 10.0.4.123 with timeout 10 magic: 2131 length: 0060 --> 96 bytes unknown1: 00000000 devicetype: 0df5 serial: 98d9 ts: 0000060f --> 1551 seconds --> 1970-01-01 03:25:51 timediff: -1576194057 checksum: 61dfc0c079a2cb00ab4e5487e1af97b9 ts_server: 5df2d618 --> 1576195608 seconds --> 2019-12-13 02:06:48 data: 64408f68f937459e57c25315059fcf78212abf24f1d68feedee363d19c4d00b05e22ed3d9066f425a18ff9e38b171bdc1f080ea913740e8493dea2e43961ef42 >>>>> Sent 96 bytes to socket <<<<< Reply from IP 10.0.4.123 , port 54321 Read 32 bytes from socket magic: 2131 length: 0060 --> 96 bytes unknown1: 00000000 devicetype: 0df5 serial: 98d9 ts: 0000060f --> 1551 seconds --> 1970-01-01 03:25:51 timediff: -1576194057 checksum: ffffffffffffffffffffffffffffffff data: Data decrypted: Invalid JSON data. Error: Syntax error Executing trim() Сведения miIO.info не получены.
Конечно, токен внесен в настройки модуля.
Кроме этого устройства, в сети нормально работает шлюз lumi.gateway.v3
Подскажите пожалуйста, куда копать?
