[Модуль] Camshoter (camshoter)
vitar78
Re: [Модуль] Camshoter (camshoter)
Сообщение vitar78 » Чт апр 04, 2019 5:09 pm
плагин почему то не показывает скриншоты
https://prnt.sc/n7geaz
при нажатии на изображение
https://prnt.sc/n7gg8q
лог апача
[Thu Apr 04 13:00:03.510046 2019] [:error] [pid 19972] [client 127.0.0.1:42648] PHP Fatal error:  Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 13:46:17.083936 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning:  scandir(/var/www/html/cms/cached/nvr/cam1/): failed to open dir: No such file or directory in /var/www/html/modules/camshoter/camshoter.clas$
[Thu Apr 04 13:46:17.083999 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning:  scandir(): (errno 2): No such file or directory in /var/www/html/modules/camshoter/camshoter.class.php on line 1113, referer: http://192.168$
[Thu Apr 04 13:46:17.084011 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning:  array_diff(): Argument #1 is not an array in /var/www/html/modules/camshoter/camshoter.class.php on line 1113, referer: http://192.168.0.251$
[Thu Apr 04 13:46:17.084020 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning:  Invalid argument supplied for foreach() in /var/www/html/modules/camshoter/camshoter.class.php on line 1114, referer: http://192.168.0.251/a$
[Thu Apr 04 13:46:17.084037 2019] [:error] [pid 18504] [client 192.168.0.2:55510] PHP Warning:  rmdir(/var/www/html/cms/cached/nvr/cam1/): No such file or directory in /var/www/html/modules/camshoter/camshoter.class.php on line 1117, re$
[Thu Apr 04 14:00:03.216394 2019] [:error] [pid 19967] [client 127.0.0.1:33586] PHP Fatal error:  Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 15:00:03.275777 2019] [:error] [pid 18504] [client 127.0.0.1:52452] PHP Fatal error:  Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 16:00:03.687982 2019] [:error] [pid 21264] [client 127.0.0.1:43612] PHP Fatal error:  Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
[Thu Apr 04 17:00:03.689726 2019] [:error] [pid 21264] [client 127.0.0.1:34732] PHP Fatal error:  Uncaught Error: Call to a member function save() on null in /var/www/html/lib/module.class.php:583\nStack trace:\n#0 /var/www/html/modules$
лог модуля
                "ID": "1",
                "NAME": "Admin"
        "USERNAME": "",
        "META": ""
16:56:41 0.59004100
$online=ping(processTitle("192.168.0.24"));
if ($online)
{SQLexec("update camshoter_devices set ONLINE=1, LASTPING2=1554386201 where IPADDR='192.168.0.24'");}
else
{SQLexec("update camshoter_devices set ONLINE=0, LASTPING2=1554386201 where IPADDR='192.168.0.24'");}
16:56:41 0.59046100 total:1
16:56:41 0.59060500 camshoter storage dir:/var/www/html/cms/cached/nvr/cam1/2019-04-04/
16:56:41 0.59067000 camshoter storage cnt:9
16:56:41 0.59073000 camshoter upfoler:2019-04-04
16:56:41 0.59079200 camshoter upfoler1:cam1
16:56:41 0.59124200 вызван getusers /var/www/html/cms/cached/nvr/last/
16:56:41 0.59137100 $upfoler last
16:56:41 0.59143500 $upfoler1 nvr
16:56:41 0.59152000 .
16:56:41 0.59159900 ..
16:56:41 0.59170100 cam1.jpg
16:56:41 0.59184600 [
        "FILE": "last\/cam1.jpg",
        "SIZETHMB": 300,
        "ID": null,
        "USERS": [
                "ID": "1",
                "NAME": "Admin"
        "USERNAME": "",
        "META": ""
16:56:41 0.59214300 select ID,NAME,ADMIN ,(SELECT  count(*)   FROM camshoter_devices   where ID='1' and TELEGRAMUSERS  like CONCAT('%',tlg_user.ID,'%' )  )  as ACCESS_USER  from tlg_user
16:56:41 0.59251000 [
        "ID": "1",
        "NAME": "keeper ",
        "ADMIN": "1",
        "ACCESS_USER": "0"
по пути файл изображения есть и он нормальный не битый
https://prnt.sc/n7gj4f
система
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
подскажите в чем может быть дело
lihodeev
Сообщение lihodeev » Сб апр 06, 2019 5:04 pm
два вопроса - как можно получить предыдущую версию camshuter (догадываюсь почему у меня не заработала) и второй ошибка -http://192.168.1.2/admin.php?pd=cGFuZWw ... r&inst=adm&
1064: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '' at line 1
select * from users where ID=
только у меня или у всех при - Путь к фотографии пользователя -добавить, нажимаю птичку(галочку) - получаю упомянутую ошибку
Raspberry 3, AMS 16, arduinka 2560, Orange pi Zero, Broadlink RM3, Xiaomi Mi Robot Vacuum SKV4000GL
Сообщение directman66 » Сб апр 06, 2019 9:48 pm
Сейчас накатываю себе новую чистую систему и пройдусь по всем модулям, проверю что не работает.
Molostov (Сб апр 27, 2019 1:12 am)
lihodeev
Сообщение lihodeev » Пн май 13, 2019 9:45 pm
модуль заброшен?
Step40
Сообщение Step40 » Вт май 14, 2019 7:12 am
А зачем он? если теперь ПУ камера умеет это делать?
lihodeev
Сообщение lihodeev » Вт май 14, 2019 6:01 pm
13) Добавлено распознавание объектов с помощью сервиса vision от mail.ru. Необходимо зарегистрироваться на сайте https://mcs.mail.ru/ и после активации аккаунта на странице https://mcs.mail.ru/app/services/machin ... ng/vision/ получить токен с разрешениями (Объекты, Лица). Далее полученный токен необходимо сохранить на вкладке настройки.
Я что то пропустил с простыми устройствами??
Сообщение directman66 » Вт май 14, 2019 6:03 pm
В этом модуле есть возможность сохранять фото, записывать видео, отправлять в телеграм, slack или по электронной почте. Инициализация события может быть привязана к любому объекту. Есть просмотрщик и фильтровщик. Родные камеры из ПУ с хранением фото в истории постоянно перестают работать. Отлавливали баги с Сергеем. Имхо решение пока далеко от идеала.
Сообщение directman66 » Вт май 14, 2019 6:04 pm
Что-то поменялось на сервсисе майла, я пока не тестировал.
Zaezd2008
Сообщение Zaezd2008 » Пт июн 07, 2019 9:54 pm
Есть подвижки по модулю? Очень интересно продолжение, у меня с тех тор как он появился на свет так и не работало какое либо распознавание, но повторюсь, идея огонь.
Сообщение directman66 » Сб июн 08, 2019 8:56 am
Все будет) количество донатов определяет очередность развития проектов. Сам я пока больше заинтересован в усовершенствовании модуля zigbee2mqtt https://connect.smartliving.ru/tasks/355.html.
Molostov (Пн июн 10, 2019 6:30 pm)
