Docker MajorDoMo
alecseyyy
Re: Docker MajorDoMo
Сообщение alecseyyy » Вс дек 08, 2019 11:07 am
Что-то поправили? Есть смысл пробовать заново устанавливать?
champloo
Сообщение champloo » Ср дек 18, 2019 11:23 am
alecseyyy писал(а):
Вт ноя 26, 2019 10:54 pm
Digest: sha256:c396eb803be99041e69eed84b0eb880d5474a6b2c1fd5a84268ce0420088d20d
Status: Downloaded newer image for mariadb:latest
Creating docker-majordomo_majordomo_1 ...
Creating docker-majordomo_mysql_1     ...
Creating docker-majordomo_majordomo_1 ... done
ERROR: for docker-majordomo_mysql_1  a bytes-like object is required, not 'str'
ERROR: for mysql  a bytes-like object is required, not 'str'
Traceback (most recent call last):
  File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 261, in _raise_for_status
    response.raise_for_status()
  File "/usr/local/lib/python3.6/dist-packages/requests/models.py", line 940, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http+docker://localhost/v1.22/containers/3188675346a3a84aa4f987cd6c4d91d7c4cafbdb7a26a5bb45b4ad63e208740d/start
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.6/dist-packages/compose/service.py", line 625, in start_container
    container.start()
  File "/usr/local/lib/python3.6/dist-packages/compose/container.py", line 241, in start
    return self.client.start(self.id, **options)
  File "/usr/local/lib/python3.6/dist-packages/docker/utils/decorators.py", line 19, in wrapped
    return f(self, resource_id, *args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/docker/api/container.py", line 1095, in start
    self._raise_for_status(res)
  File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 263, in _raise_for_status
    raise create_api_error_from_http_exception(e)
  File "/usr/local/lib/python3.6/dist-packages/docker/errors.py", line 31, in create_api_error_from_http_exception
    raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 500 Server Error: Internal Server Error ("b'driver failed programming external connectivity on endpoint docker-majordomo_mysql_1 (0a4f046914cd534c65f31dd05651b11e9a324073f7916e2ceae4610ab7b334f5): Error starting userland proxy: listen tcp 0.0.0.0:3306: bind: address already in use'")
  File "/usr/local/bin/docker-compose", line 8, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.6/dist-packages/compose/cli/main.py", line 72, in main
    command()
  File "/usr/local/lib/python3.6/dist-packages/compose/cli/main.py", line 128, in perform_command
    handler(command, command_options)
  File "/usr/local/lib/python3.6/dist-packages/compose/cli/main.py", line 1107, in up
    to_attach = up(False)
  File "/usr/local/lib/python3.6/dist-packages/compose/cli/main.py", line 1103, in up
    cli=native_builder,
  File "/usr/local/lib/python3.6/dist-packages/compose/project.py", line 570, in up
    get_deps,
  File "/usr/local/lib/python3.6/dist-packages/compose/parallel.py", line 112, in parallel_execute
    raise error_to_reraise
  File "/usr/local/lib/python3.6/dist-packages/compose/parallel.py", line 210, in producer
    result = func(obj)
  File "/usr/local/lib/python3.6/dist-packages/compose/project.py", line 556, in do
    renew_anonymous_volumes=renew_anonymous_volumes,
  File "/usr/local/lib/python3.6/dist-packages/compose/service.py", line 546, in execute_convergence_plan
    scale, detached, start
  File "/usr/local/lib/python3.6/dist-packages/compose/service.py", line 467, in _execute_convergence_create
    "Creating"
    result = func(obj)
  File "/usr/local/lib/python3.6/dist-packages/compose/service.py", line 465, in <lambda>
    lambda service_name: create_and_start(self, service_name.number),
  File "/usr/local/lib/python3.6/dist-packages/compose/service.py", line 457, in create_and_start
    self.start_container(container)
  File "/usr/local/lib/python3.6/dist-packages/compose/service.py", line 627, in start_container
    if "driver failed programming external connectivity" in ex.explanation:
TypeError: a bytes-like object is required, not 'str'
Makefile:32: recipe for target 'up' failed
make: *** [up] Error 1
что-то не работает + в docker создало еще одну сеть + 3188675346a3_docker-majordomo_mysql_1 + docker-majordomo_mysql_1 + docker-majordomo_majordomo_1
Очень сыро!
Эта проблема связана с докером. Ищите решение в интернете. У вас почему то, докер работает через http, хотя должен через сокет.
By design...
champloo
Сообщение champloo » Ср дек 18, 2019 11:24 am
Только что взял и по инструкции всё взлетело на тестовой тачке.
Планировал добавить пару сервисных контейнеров.
Проблема явно не в "сырости" у вас. А не следованию инструкции.
За это сообщение автора champloo поблагодарил:
directman66 (Ср дек 18, 2019 1:56 pm)
By design...
alecseyyy
Сообщение alecseyyy » Чт дек 19, 2019 5:07 pm
Ну я не специалист, не могу судить что и как. Попробую всё снести и с нуля установить. Homeassistant я установил и всё работает. только вот он мне не нравится.
Делаю сейчас всё с 0 (снёс полностью docker со всеми контейнерами). Разве есть нормальная инструкция по установке?
502 Bad Gateway
nginx
champloo
Сообщение champloo » Пн дек 23, 2019 5:33 pm
502 Bad Gateway
nginx
после нового года запишу видео поэтапных шагах.
В данный момент нет времени.
By design...
alecseyyy
Сообщение alecseyyy » Вт дек 24, 2019 8:33 am
очень ждём
djprizrak
Сообщение djprizrak » Ср янв 01, 2020 8:34 pm
С помощью напильника, удалось запустить MajorDoMo в контейнере, очень понравилось идея контейнеров, хочу остаться на такой системе.
Но когда как будто всё заработало, столкнулся с проблемой вывода звука на сервере. Это будет реализовано?
champloo
Сообщение champloo » Пн янв 13, 2020 1:54 pm
Обязательно. Начал разгребаться с завалами, сделаем всё, что бы максимально довести до ума.
Как освобожу время.
alecseyyy (Ср янв 15, 2020 1:42 pm)
By design...
champloo
Сообщение champloo » Вт янв 21, 2020 2:08 pm
Новый патч вышел от nick7zmail
Что нового:
1. Перевели под debian 10 buster
2. Обновили nginx конфигурацию.
3. Добавили недостающей библиотеки gd
Рекомендую всем обновится.
By design...
alecseyyy
Сообщение alecseyyy » Чт янв 23, 2020 5:33 pm
Что нового:
а с инструкцией как? у меня не работает :(
2020-01-23 14:32:32,856 INFO success: nginx entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-01-23 14:32:34,358 INFO exited: nginx (exit status 1; not expected)
2020-01-23 14:32:34,797 INFO spawned: 'nginx' with pid 614
2020-01-23 14:32:35,813 INFO success: nginx entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-01-23 14:32:37,315 INFO exited: nginx (exit status 1; not expected)
2020-01-23 14:32:38,319 INFO spawned: 'nginx' with pid 615
2020-01-23 14:32:39,337 INFO success: nginx entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-01-23 14:32:40,839 INFO exited: nginx (exit status 1; not expected)
2020-01-23 14:32:41,844 INFO spawned: 'nginx' with pid 616
2020-01-23 14:32:42,861 INFO success: nginx entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
