<?php
* Project Config
* @package MajorDoMo
* @author Serge Dzheigalo <
jey@tut.by>
http://smartliving.ru/
* @version 1.1
define('ENVIRONMENT', 'dev');
switch (ENVIRONMENT)
case 'dev':
error_reporting(-1);
ini_set('display_errors', 1);
break;
case 'prod':
error_reporting(E_ALL ^ E_NOTICE ^ E_DEPRECATED ^ E_STRICT);
ini_set('display_errors', 0);
break;
default:
header('HTTP/1.1 503 Service Unavailable.', TRUE, 503);
exit('The application env is incorrect');
Define('DB_HOST', 'localhost');
Define('DB_NAME', 'db_terminal');
Define('DB_USER', 'root');
Define('DB_PASSWORD', '');
Define('DIR_TEMPLATES', "./templates/");
Define('DIR_MODULES', "./modules/");
Define('DEBUG_MODE', 1);
Define('UPDATES_REPOSITORY_NAME', 'smarthome');
Define('PROJECT_TITLE', 'MajordomoSL');
Define('PROJECT_BUGTRACK', "
bugtrack@smartliving.ru");
date_default_timezone_set('UTC');
if (isset($_ENV["COMPUTERNAME"]) && $_ENV["COMPUTERNAME"])
Define('COMPUTER_NAME', strtolower($_ENV["COMPUTERNAME"]));
else
// Your computer name (optional)
Define('COMPUTER_NAME', 'mycomp');
Define('DOC_ROOT', dirname(__FILE__)); // Your htdocs location (should be detected automatically)
Define('SERVER_ROOT', '/var/www/');
Define('PATH_TO_PHP', 'php');
// Define('PATH_TO_MYSQLDUMP', SERVER_ROOT."/server/mysql/bin/mysqldump");
if (isset($_ENV["S2G_BASE_URL"]) && $_ENV["S2G_BASE_URL"])
Define('BASE_URL', $_ENV["S2G_BASE_URL"]);
else
// Your base URL:port (!!!)
Define('BASE_URL', '127.0.0.1:80');
Define('ROOT', DOC_ROOT."/");
Define('ROOTHTML', "/");
Define('PROJECT_DOMAIN', $_SERVER['SERVER_NAME']);
// 1-wire OWFS server
//Define('ONEWIRE_SERVER', 'tcp://localhost:8234');
Define('HOME_NETWORK', '192.168.1.*'); // home network (optional)
/* Define('EXT_ACCESS_USERNAME', 'user'); // access details for external network (internet)
Define('EXT_ACCESS_PASSWORD', 'password');
/// (Optional)
//Define('DROPBOX_SHOPPING_LIST', 'c:/data/dropbox/list.txt');
