71Gavrik71
Re: Образ для OrangePi PC,OrangePi Plus,OrangePi 2,OrangePi PC+
Сообщение 71Gavrik71 » Пн апр 16, 2018 11:18 pm
Подскажите в чем может быть печалька установлена на орандж пи +2 все работает с hdd но переодически все отваливается https://drive.google.com/file/d/1QMvxAj ... sp=sharing
алог апача
[Mon Apr 16 06:25:28.235193 2018] [mpm_prefork:notice] [pid 886] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Mon Apr 16 06:25:28.235353 2018] [core:notice] [pid 886] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 16 06:26:01.302739 2018] [:error] [pid 666] [client 127.0.0.1:41915] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; htmlMimeMail has a deprecated constructor in /var/www/lib/htmlMimeMail.class.php on line 23
[Mon Apr 16 06:26:01.303504 2018] [:error] [pid 666] [client 127.0.0.1:41915] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; Mail_mimePart has a deprecated constructor in /var/www/lib/htmlMimeMail.class.php on line 873
[Mon Apr 16 06:26:01.368826 2018] [:error] [pid 666] [client 127.0.0.1:41915] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; application has a deprecated constructor in /var/www/modules/application.class.php on line 11
[Mon Apr 16 11:00:02.529228 2018] [:error] [pid 5461] [client 127.0.0.1:47400] PHP Warning: Invalid argument supplied for foreach() in /var/www/modules/app_openweather/get_weather.inc.php on line 131
[Mon Apr 16 11:00:03.026587 2018] [:error] [pid 5461] [client 127.0.0.1:47400] PHP Warning: Invalid argument supplied for foreach() in /var/www/modules/app_openweather/get_weather.inc.php on line 131
[Mon Apr 16 11:00:03.476621 2018] [:error] [pid 5461] [client 127.0.0.1:47400] PHP Warning: Invalid argument supplied for foreach() in /var/www/modules/app_openweather/get_weather.inc.php on line 131
[Mon Apr 16 11:00:04.071698 2018] [:error] [pid 5461] [client 127.0.0.1:47400] PHP Warning: Invalid argument supplied for foreach() in /var/www/modules/app_openweather/get_weather.inc.php on line 131
[Mon Apr 16 11:00:04.550223 2018] [:error] [pid 5461] [client 127.0.0.1:47400] PHP Warning: Invalid argument supplied for foreach() in /var/www/modules/app_openweather/get_weather.inc.php on line 131
[Mon Apr 16 17:17:33.118581 2018] [mpm_prefork:notice] [pid 819] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Mon Apr 16 17:17:33.148912 2018] [core:notice] [pid 819] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 16 20:26:36.619207 2018] [:error] [pid 847] [client 127.0.0.1:39624] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; htmlMimeMail has a deprecated constructor in /var/www/lib/htmlMimeMail.class.php on line 23
[Mon Apr 16 20:26:36.914947 2018] [:error] [pid 847] [client 127.0.0.1:39624] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; Mail_mimePart has a deprecated constructor in /var/www/lib/htmlMimeMail.class.php on line 873
[Mon Apr 16 20:26:37.061134 2018] [:error] [pid 847] [client 127.0.0.1:39624] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; application has a deprecated constructor in /var/www/modules/application.class.php on line 11
через SSh в таком состоянии не подключается(
sav13
Сообщение sav13 » Вт апр 24, 2018 6:30 am
Всем привет
Поставил MD на OPiPC на чистый armbian.
Все хорошо, система конфигурится, устройства mysensors подключаются, но, до первого отключения питания.
Потом вроде конфигурация остается, но данные с mysensors не обновляются, хотя mysgw работает нормально и данные получает. Не спасает ни перезагрузка всего ПК, ни отдельных сервисов.
Если устройства удалить и создать заново, то они работаю ... до первого выключения питания
Что-то можно с этим сделать?
Orange PI PC + Mysensors + ESP8266/32 MQTT + miHome
Берендей
Сообщение Берендей » Пт апр 27, 2018 7:19 pm
Повторилась ситуация, которую я уже ранее описывал. После разворачивания на флешку ранее сохраненного образа, в нем невозможно зайти в консоль, пароль на root не принимается. Все остальное работает, но ни в webmin ни в консоль зайти не могу, пишет не правильный пароль.
Образ ARMBIAN 5.36 пароль на root указываю orangepipc...
OrangePI PC/ARMBIAN 5.36 + DS3231+433Mhz. Esp8266(ArduinoIDE). Arduino MEGA2560 + Oregon THGN132N.
Sonoff RF Bridge + sensors
radiomanoff
Сообщение radiomanoff » Вс апр 29, 2018 9:42 pm
Всем привет, присоединяюсь к сообществу.
Поставил на Orange Pi PC образ ARMBIAN 5.36 user-built Ubuntu 16.04.3 LTS 3.4.113-sun8i от 05.12.2017 , но нет звука Алисы. Попробовал править etc/asound.conf , пока безрезультатно."Dingdon" есть, после него тишина...
Что интересно в сборке DietPi , все работает. Алиса разговаривает , правда после правки etc/asound.conf (как указано в описании) . Первый раз стыкаюсь с DietPi, понравился (на мой взгляд) очень приятный интерфейс в консоли. Судя по ихнему сайту они не поддерживают Orange Pi , видимо кто-то из сообщества сам собирал, спасибо Людям.
А да. Яндекс TTS удалил , установил RHVoice TTS по инструкции в обе зборки. В обоих системах обновляюсь через браузер. В DietPi звук Алисы есть, в ARMBIAN нет.
Я бы так и остался на DietPi, но хочу к "апельсинке" подключать дисплей TFT c библиотекой fbtft - https://github.com/notro/fbtft/issues/512 и выводить туда инфу, с нужных мне датчиков, по типу RPiMonitor. Есть идея все оформить в виде переносных часов с динамиком и дисплеем с подключкой через WiFi к "домашней" щитовой. Ну а далее Modbus и ля-ля-ля...
Некоторые наработки с дисплеями уже имеются и что самое интересное поддерживаются в ARMBIAN с "коробки" в отличии от DietPi
Последний раз редактировалось radiomanoff Пн май 07, 2018 10:16 pm, всего редактировалось 1 раз.
Берендей
Сообщение Берендей » Вт май 01, 2018 1:25 pm
Можно как кто изменить пароль на root?
Пользователь orangepi и его пароль orangepi тоже не принимается...
Напрягает, что не могу войти в консоль после восстановления образа на флешку
radiomanoff
Сообщение radiomanoff » Вт май 01, 2018 5:08 pm
У меня работает 100%.
У меня проблема в другом, звука Алисы нет. Яндекс tts я удалил, поскольку в Украине яндекса нет, установил RHVoice TTS, в Armbian голос Алисы отсутствует, зато в сборке DietPi на том-же "железе" (OrangePiPC) очень даже работает..
Берендей
Сообщение Берендей » Вт май 01, 2018 5:30 pm
У меня тоже все работало, но после восстановления системы из образа пароли слетели. Я не силен в Линуксе, и не представляю сути проблемы, но факт остаётся фактом. И это не в первый раз, такое уже происходило на старом имиджем.
А вот с Алисой все нормально, я тоже из Украины, и ставил offline движок.
immortal
Сообщение immortal » Ср май 02, 2018 5:26 pm
для работы голоса надо чтобы мд запускался не от root для этого надо смотре ть скрипт запуска мд.
что значит после восстановления системы из образа? это как?
пароль root меняется командой
passwd root
За это сообщение автора immortal поблагодарил:
radiomanoff (Пт май 04, 2018 8:17 pm)
Берендей
Сообщение Берендей » Чт май 03, 2018 8:28 am
Ситуация следующая, повторилась уже второй раз:
C флэшки с рабочей системой, с известным, и 100% рабочим паролем на root, был сделан образ, так сказать экстремальный бэкап.
Через некоторое время этот образ был развернут обратно на эту же флэшку.
Все работает, но пароль на root не принимается.
Я не могу зайти ни в консоль ни в webmin.
Образ делал через Win32diskImager.
leikocid
Сообщение leikocid » Сб май 05, 2018 12:39 pm
Добрый день!, образ от декабря 2017, все работало норм, сейчас при попытке зайти окно Hello, world! :) выбора языка и темы, при нажатии cotinue>>> просто сбрасывается параметр и та же страница(
